RTEMS 6.1
pwdgrp.h
2
3/*
4 * Copyright (c) 2014 embedded brains GmbH & Co. KG
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25 * POSSIBILITY OF SUCH DAMAGE.
26 */
27
28#ifndef _RTEMS_LIBCSUPPORT_PWDGRP_H
29#define _RTEMS_LIBCSUPPORT_PWDGRP_H
30
31#include <grp.h>
32#include <pwd.h>
33#include <stdio.h>
34
35#ifdef __cplusplus
36extern "C" {
37#endif /* __cplusplus */
38
39void _libcsupport_pwdgrp_init(void);
40
41int _libcsupport_scanpw(
42 FILE *fp,
43 struct passwd *pwd,
44 char *buffer,
45 size_t bufsize
46);
47
49 FILE *fp,
50 struct group *grp,
51 char *buffer,
52 size_t bufsize
53);
54
55#ifdef __cplusplus
56}
57#endif /* __cplusplus */
58
59#endif /* _RTEMS_LIBCSUPPORT_PWDGRP_H */
#define fp
frame-pointer *‍/
Definition: regs.h:65
int _libcsupport_scangr(FILE *fp, struct group *grp, char *buffer, size_t bufsize)
Definition: pwdgrp.c:252
