RTEMS 6.1
psim.h
1/*
2 * PSIM addresses and constants based upon the configuration
3 * of devices used in the script provided by RTEMS.
4 */
5
6#ifndef __PSIM_h
7#define __PSIM_h
8
9/*
10 * RAM Information
11 */
12
13extern char RamBase[];
14extern char RamSize[];
15
16/*
17 * RamBase/RamSize is defined by the linker script;
18 * CPP symbols are AFAIK unused and deprecated.
19 */
20#define PSIM_RAM_SIZE ((unsigned long)RamSize)
21#define PSIM_RAM_BASE ((void*)RamBase)
22
23/*
24 * NVRAM/RTC Structure and Information
25 */
26
27#define PSIM_RTC_FREEZE 0xc0
28#define PSIM_RTC_UPDATE 0x00
29
30typedef struct {
31 volatile uint8_t Control; /* 0x04 */
32 volatile uint8_t Second; /* 0x05 */
33 volatile uint8_t Minute; /* 0x06 */
34 volatile uint8_t Hour; /* 0x07 */
35 volatile uint8_t Day; /* 0x08 */
36 volatile uint8_t Date; /* 0x09 */
37 volatile uint8_t Month; /* 0x0a */
38 volatile uint8_t Year; /* 0x0b */
40
41/*
42 * System V IPC Semaphore -- Read Only
43 */
44
45typedef struct {
46 volatile uint32_t obtain_value; /* 0x00 */
47 volatile uint32_t lock; /* 0x04 */
48 volatile uint32_t unlock; /* 0x08 */
50
51typedef struct {
52 /* 0x0c000000 - 0x0c007FFF - AMD 29F040 */
53 volatile uint8_t Flash[ 512 * 1024 ];
54
55 /* 0x0c080000 - 0x0c0FFFFF - NVRAM/NVRAM */
56 volatile uint8_t nvram[ 512 * 1024 ];
57
58 /* 0x0c100000 - 0x0c100007 - NVRAM/RTC */
59 psim_rtc_t RTC;
60
61 /* 0x0c100008 - 0x0c10000F - NVRAM/RTC */
62 uint8_t gap1[8];
63
64 /* 0x0c100010 - 0x0c10001b - System V IPC Semaphore */
65 psim_sysv_sem_t Semaphore;
66
67 /* 0x0c10001c - 0x0c10001f - NVRAM/RTC */
68 uint8_t gap2[4];
69
70 /* 0x0c100020 - 0x0c10005F - Ethernet */
71 volatile uint8_t Ethtap[ 64 ];
72
73 /* 0x0c100060 - 0x0c10FFFF - NVRAM/RTC */
74 uint8_t gap3[65440];
75
76 /* 0x0c110000 - 0x0c12FFFF - System V IPC Shared Memory */
77 uint8_t SharedMemory[ 128 * 1024 ];
78
79 /* 0x0c130000 - 0x0c170000 - OpenPIC IRQ Controller */
80 volatile uint8_t OpenPIC[ 256 * 1024 ];
81
83
84/*
85 * Data Structure Overlay for Registers. See linkcmds for placement.
86 */
87extern psim_registers_t PSIM;
88
89#endif
90/* end of include file */
Definition: openpic.h:166
Definition: psim.h:51
Definition: psim.h:30
Definition: psim.h:45
