RTEMS 6.1
mmu.h
1#ifndef RTEMS_VIRTEX5_MMU_H
2#define RTEMS_VIRTEX5_MMU_H
10/*
11 * Authorship
12 * ----------
13 * This software was created by
14 * Till Straumann <strauman@slac.stanford.edu>, 2005-2007,
15 * Stanford Linear Accelerator Center, Stanford University.
16 * and was transcribed for the PPC 440 by
17 * R. Claus <claus@slac.stanford.edu>, 2012,
18 * Stanford Linear Accelerator Center, Stanford University,
19 *
20 * Acknowledgement of sponsorship
21 * ------------------------------
22 * This software was produced by
23 * the Stanford Linear Accelerator Center, Stanford University,
24 * under Contract DE-AC03-76SFO0515 with the Department of Energy.
25 *
26 * Government disclaimer of liability
27 * ----------------------------------
28 * Neither the United States nor the United States Department of Energy,
29 * nor any of their employees, makes any warranty, express or implied, or
30 * assumes any legal liability or responsibility for the accuracy,
31 * completeness, or usefulness of any data, apparatus, product, or process
32 * disclosed, or represents that its use would not infringe privately owned
33 * rights.
34 *
35 * Stanford disclaimer of liability
36 * --------------------------------
37 * Stanford University makes no representations or warranties, express or
38 * implied, nor assumes any liability for the use of this software.
39 *
40 * Stanford disclaimer of copyright
41 * --------------------------------
42 * Stanford University, owner of the copyright, hereby disclaims its
43 * copyright and all other rights in this software. Hence, anyone may
44 * freely use it for any purpose without restriction.
45 *
46 * Maintenance of notices
47 * ----------------------
48 * In the interest of clarity regarding the origin and status of this
49 * SLAC software, this and all the preceding Stanford University notices
50 * are to remain affixed to any copy or derivative of this software made
51 * or distributed by the recipient and are to be affixed to any copy of
52 * software made or distributed by the recipient that contains a copy or
53 * derivative of this software.
54 *
55 * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
56 */
57
58#include <rtems.h>
59#include <inttypes.h>
60#include <stdio.h>
61
62#ifdef __cplusplus
63extern "C" {
64#endif
65
76/* Some routines require or return an index 'key'.
77 */
78typedef int bsp_tlb_idx_t;
79
80/* Cache the relevant TLB entries so that we can make sure the user cannot
81 * create conflicting (overlapping) entries. Keep them public for informational
82 * purposes.
83 */
84typedef struct {
85 struct {
86 uint32_t pad:24;
87 uint32_t tid:8;
88 } id;
89 struct {
90 uint32_t epn:22;
91 uint32_t v:1;
92 uint32_t ts:1;
93 uint32_t size:4;
94 uint32_t tpar:4;
95 } w0;
96 struct {
97 uint32_t rpn:22;
98 uint32_t par1:2;
99 uint32_t pad:4;
100 uint32_t erpn:4;
101 } w1;
102 struct {
103 uint32_t par2:2;
104 uint32_t pad1:14;
105 uint32_t att:4;
106 uint32_t wimge:5;
107 uint32_t pad2:1;
108 uint32_t perm:6;
109 } w2;
111
112#define NTLBS 64
113
114extern bsp_tlb_entry_t* bsp_mmu_cache;
115
116// These constants will have to be shifted right by 20 bits before
117// being inserted the high word of the TLB.
118
119#define MMU_M_SIZE_1K (0x00000000U)
120#define MMU_M_SIZE_4K (0x08000000U)
121#define MMU_M_SIZE_16K (0x10000000U)
122#define MMU_M_SIZE_64K (0x18000000U)
123#define MMU_M_SIZE_256K (0x20000000U)
124#define MMU_M_SIZE_1M (0x28000000U)
125#define MMU_M_SIZE_16M (0x38000000U)
126#define MMU_M_SIZE_256M (0x48000000U)
127#define MMU_M_SIZE_MIN (MMU_M_SIZE_1K)
128#define MMU_M_SIZE_MAX (MMU_M_SIZE_256M)
129#define MMU_M_SIZE (0x78000000U)
130#define MMU_V_SIZE (27)
131
132// These constants have the same bit positions they'll occupy
133// in low word of the TLB.
134
135#define MMU_M_ATTR_USER0 (0x00010000U)
136#define MMU_M_ATTR_USER1 (0x00008000U)
137#define MMU_M_ATTR_USER2 (0x00004000U)
138#define MMU_M_ATTR_USER3 (0x00002000U)
139#define MMU_M_ATTR (0x0001e000U)
140#define MMU_V_ATTR (13)
141
142#define MMU_M_PROP_WRITE_THROUGH (0x00001000U)
143#define MMU_M_PROP_UNCACHED (0x00000800U)
144#define MMU_M_PROP_MEM_COHERENT (0x00000400U)
145#define MMU_M_PROP_GUARDED (0x00000200U)
146#define MMU_M_PROP_LITTLE_ENDIAN (0x00000100U)
147#define MMU_M_PROP (0x00000f00U)
148#define MMU_V_PROP (8)
149
150#define MMU_M_PERM_USER_EXEC (0x00000020U)
151#define MMU_M_PERM_USER_WRITE (0x00000010U)
152#define MMU_M_PERM_USER_READ (0x00000008U)
153#define MMU_M_PERM_SUPER_EXEC (0x00000004U)
154#define MMU_M_PERM_SUPER_WRITE (0x00000002U)
155#define MMU_M_PERM_SUPER_READ (0x00000001U)
156#define MMU_M_PERM (0x0000003fU)
157#define MMU_V_PERM (0)
158
159
160/*
161 * Dump (cleartext) content info from cached TLB entries
162 * to a file (stdout if f==NULL).
163 */
164void
165bsp_mmu_dump_cache(FILE *f);
166
167/* Read a TLB entry from the hardware and store the settings in the
168 * bsp_mmu_cache[] structure.
169 *
170 * The routine can perform this operation quietly or
171 * print information to a file.
172 *
173 * 'key': TLB entry index.
174 * 'quiet': perform operation silently (no info printed) if nonzero.
175 * 'f': open FILE where to print information. May be NULL, in
176 * which case 'stdout' is used.
177 *
178 * RETURNS:
179 * 0: success; TLB entry is VALID
180 * +1: success but TLB entry is INVALID
181 * < 0: error (-1: invalid argument)
182 * (-2: driver not initialized)
183 */
184int
185bsp_mmu_update(bsp_tlb_idx_t key, bool quiet, FILE *f);
186
187/* Initialize cache. Should be done only once although this is not enforced.
188 *
189 * RETURNS: zero on success, nonzero on error; in this case the driver will
190 * refuse to change TLB entries (other than disabling them).
191 */
192int
193bsp_mmu_initialize(void);
194
195/* Find first free TLB entry by examining all entries' valid bit. The first
196 * entry without the valid bit set is returned.
197 *
198 * RETURNS: A free TLB entry number. -1 if no entry can be found.
199 */
200bsp_tlb_idx_t
201bsp_mmu_find_first_free(void);
202
203/* Write a TLB entry (can also be used to disable an entry).
204 *
205 * The routine checks against the cached data in bsp_mmu_cache[]
206 * to prevent the user from generating overlapping entries.
207 *
208 * 'idx': TLB entry # to manipulate
209 * 'ea': Effective address (must be page aligned)
210 * 'pa': Physical address (must be page aligned)
211 * 'sz': Page size selector; page size is 1024 * 2^(2*sz) bytes.
212 * 'sz' may also be one of the following:
213 * - page size in bytes ( >= 1024 ); the selector
214 * value is then computed by this routine.
215 * However, 'sz' must be a valid page size
216 * or -1 will be returned.
217 * - a value < 0 to invalidate/disable the
218 * TLB entry.
219 * 'flgs': Page's User-defined flags, permissions and WIMGE page attributes
220 * 'tid': Translation ID
221 * 'ts': Translation Space
222 * 'erpn': Extended Real Page Number
223 *
224 * RETURNS: 0 on success, nonzero on error:
225 *
226 * >0: requested mapping would overlap with
227 * existing mapping in another entry. Return
228 * value gives conflicting entry + 1; i.e.,
229 * if a value of 4 is returned then the request
230 * conflicts with existing mapping in entry 3.
231 * -1: invalid argument
232 * -3: driver not initialized (or initialization failed).
233 * <0: other error
234 */
235bsp_tlb_idx_t
236bsp_mmu_write(bsp_tlb_idx_t idx, uint32_t ea, uint32_t pa, int sz,
237 uint32_t flgs, uint32_t tid, uint32_t ts, uint32_t erpn);
238
239/* Check if a ea/tid/ts/sz mapping overlaps with an existing entry.
240 *
241 * 'ea': The Effective Address to match against
242 * 'sz': The 'logarithmic' size selector; the page size
243 * is 1024*2^(2*sz).
244 * 'tid': Translation ID
245 * 'ts': Translation Space
246 *
247 * RETURNS:
248 * >= 0: index of TLB entry that already provides a mapping
249 * which overlaps within the ea range.
250 * -1: SUCCESS (no conflicting entry found)
251 * <=-2: ERROR (invalid input)
252 */
253bsp_tlb_idx_t
254bsp_mmu_match(uint32_t ea, int sz, uint32_t tid, uint32_t ts);
255
256/* Find TLB index that maps 'ea/tid/ts' combination
257 *
258 * 'ea': Effective address to match against
259 * 'tid': Translation ID
260 * 'ts': Translation Space
261 *
262 * RETURNS: index 'key'; i.e., the index number.
263 *
264 * On error (no mapping) -1 is returned.
265 */
266bsp_tlb_idx_t
267bsp_mmu_find(uint32_t ea, uint32_t tid, uint32_t ts);
268
269/* Mark TLB entry as invalid ('disabled').
270 *
271 * 'key': TLB entry index.
272 *
273 * RETURNS: zero on success, nonzero on error (TLB unchanged).
274 *
275 * NOTE: If a TLB entry is disabled the associated
276 * entry in bsp_tlb_cache[] is also marked as disabled.
277 */
278int
279bsp_mmu_invalidate(bsp_tlb_idx_t key);
280
283#ifdef __cplusplus
284};
285#endif
286
287#endif
Provide printf() PRIxxx Constante Beyond Standards.
Definition: mmu.h:84
uint32_t tpar
Definition: mmu.h:94
uint32_t pad1
Definition: mmu.h:104
uint32_t pad2
Definition: mmu.h:107
uint32_t par1
Definition: mmu.h:98
uint32_t ts
Definition: mmu.h:92
uint32_t wimge
Definition: mmu.h:106
