RTEMS 6.1
tm27.h
1/*
2 * @file
3 * @ingroup powerpc_gen5200
4 * @brief Implementations for interrupt mechanisms for Time Test 27
5 */
6
7/*
8 * The license and distribution terms for this file may be
9 * found in the file LICENSE in this distribution or at
10 * http://www.rtems.org/license/LICENSE.
11 */
12
13#ifndef _RTEMS_TMTEST27
14#error "This is an RTEMS internal file you must not include directly."
15#endif
16
17#ifndef __tm27_h
18#define __tm27_h
19
20#include <bsp/fatal.h>
21#include <bsp/irq.h>
22
23/*
24 * Stuff for Time Test 27
25 */
26
27#define MUST_WAIT_FOR_INTERRUPT 1
28
29static void nullFunc(void) {}
30
31static rtems_irq_connect_data clockIrqData = {BSP_DECREMENTER,
32 0,
33 (rtems_irq_enable) nullFunc,
34 (rtems_irq_disable) nullFunc,
35 (rtems_irq_is_enabled) nullFunc};
36
37static inline void Install_tm27_vector( rtems_interrupt_handler handler )
38{
39 clockIrqData.hdl = handler;
40 if (!BSP_install_rtems_irq_handler (&clockIrqData)) {
41 printk("Error installing clock interrupt handler!\n");
42 bsp_fatal(MPC5200_FATAL_TM27_IRQ_INSTALL);
43 }
44}
45
46#define Cause_tm27_intr() \
47 do { \
48 uint32_t _clicks = 8; \
49 __asm__ volatile( "mtdec %0" : "=r" ((_clicks)) : "r" ((_clicks)) ); \
50 } while (0)
51
52#define Clear_tm27_intr() \
53 do { \
54 uint32_t _clicks = 0xffffffff; \
55 __asm__ volatile( "mtdec %0" : "=r" ((_clicks)) : "r" ((_clicks)) ); \
56 } while (0)
57
58#define Lower_tm27_intr() \
59 do { \
60 uint32_t _msr = 0; \
61 _ISR_Set_level( 0 ); \
62 __asm__ volatile( "mfmsr %0 ;" : "=r" (_msr) : "r" (_msr) ); \
63 _msr |= 0x8002; \
64 __asm__ volatile( "mtmsr %0 ;" : "=r" (_msr) : "r" (_msr) ); \
65 } while (0)
66
67#endif
This header file provides fatal codes for RTEMS_FATAL_SOURCE_BSP.
void(* rtems_interrupt_handler)(void *)
Interrupt handler routines shall have this type.
Definition: intr.h:1030
Definition: irq.h:64
