RTEMS 6.1
power.h
2
3/*
4 * Copyright (c) 2016 embedded brains GmbH & Co. KG
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25 * POSSIBILITY OF SUCH DAMAGE.
26 */
27
28#ifndef LIBBSP_ARM_ATSAM_POWER_H
29#define LIBBSP_ARM_ATSAM_POWER_H
30
31#include <sys/types.h>
32
33#include <stdint.h>
34
35#ifdef __cplusplus
36extern "C"{
37#endif /* __cplusplus */
38
42typedef enum {
46 ATSAM_POWER_INIT,
50 ATSAM_POWER_ON,
54 ATSAM_POWER_OFF
55} atsam_power_state;
56
60typedef struct atsam_power_control {
64 void (*handler)(
65 const struct atsam_power_control *control,
66 atsam_power_state state
67 );
71 union {
72 void *arg;
73 struct {
74 uint8_t first;
75 uint8_t last;
76 } peripherals;
79
137void atsam_power_change_state(
138 const atsam_power_control *controls,
139 size_t n,
140 atsam_power_state state
141);
142
154void atsam_power_handler_peripheral(
155 const atsam_power_control *controls,
156 atsam_power_state state
157);
158
170void atsam_power_handler_clock_driver(
171 const atsam_power_control *controls,
172 atsam_power_state state
173);
174
187void atsam_power_handler_rtc_driver(
188 const atsam_power_control *controls,
189 atsam_power_state state
190);
191
197void atsam_power_handler_sleep_mode(
198 const atsam_power_control *controls,
199 atsam_power_state state
200);
201
209void atsam_power_handler_wait_mode(
210 const atsam_power_control *controls,
211 atsam_power_state state
212);
213
220#define ATSAM_POWER_PERIPHERAL(f, l) \
221 { \
222 .handler = atsam_power_handler_peripheral, \
223 .data = { .peripherals = { .first = f, .last = l } } \
224 }
225
226#define ATSAM_POWER_HANDLER(h, a) \
227 { \
228 .handler = h, \
229 .data = { .arg = a } \
230 }
231
232#define ATSAM_POWER_CLOCK_DRIVER \
233 { .handler = atsam_power_handler_clock_driver }
234
235#define ATSAM_POWER_SLEEP_MODE \
236 { .handler = atsam_power_handler_sleep_mode }
237
238#define ATSAM_POWER_WAIT_MODE \
239 { .handler = atsam_power_handler_wait_mode }
240
246typedef struct {
252 uint32_t interval;
253} atsam_power_data_rtc_driver;
254
262#define ATSAM_POWER_RTC_DRIVER(a) \
263 { \
264 .handler = atsam_power_handler_rtc_driver, \
265 .data = { .arg = a } \
266 }
267
268#ifdef __cplusplus
269}
270#endif /* __cplusplus */
271
272#endif /* LIBBSP_ARM_ATSAM_POWER_H */
Control structure for power control handling.
Definition: power.h:60
void(* handler)(const struct atsam_power_control *control, atsam_power_state state)
Data pointer to the handler with its desired state.
Definition: power.h:64
union atsam_power_control::@7 data
Data chunk that is used by the handler.
Definition: intercom.c:87
