RTEMS
6.1
include
passwd.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
9
10
* COPYRIGHT (C) 2007 On-Line Applications Research Corporation (OAR).
11
12
13
* modification, are permitted provided that the following conditions
14
* are met:
15
* 1. Redistributions of source code must retain the above copyright
16
* notice, this list of conditions and the following disclaimer.
17
* 2. Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in the
19
* documentation and/or other materials provided with the distribution.
20
21
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31
* POSSIBILITY OF SUCH DAMAGE.
32
33
34
/* Define a default password for telnetd here.
35
* NOTES:
36
* - this can be overridden at run-time by setting
37
* the "TELNETD_PASSWD" environment variable.
38
* As soon as that variable is set, the new password
39
* is effective - no need to restart telnetd.
40
* - this must be set to an _encrypted_ password, NOT
41
* the cleartext. Use the 'genpw' utility to generate
42
* a password string:
43
44
* 1) Compile 'genpw.c' for the HOST, i.e.
45
* cc -o genpw genpw.c -lcrypt
46
* 1) delete an old password definition from this file.
47
* 2) run './genpw >> passwd.h'. This will append
48
* a new definition to this file.
49
50
* - if no password is defined here, no authentication
51
* is needed, i.e. telnet is open to the world.
52
53
* T. Straumann <strauman@slac.stanford.edu>
54
55
56
/* #undef TELNETD_DEFAULT_PASSWD */
57
/* Default password: 'rtems' */
58
#define TELNETD_DEFAULT_PASSWD "tduDcyLX12owo"
