RTEMS
6.1
score
cpu
or1k
include
score
cpu_asm.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
13
14
* COPYRIGHT (c) 1989-1999.
15
* On-Line Applications Research Corporation (OAR).
16
17
18
* modification, are permitted provided that the following conditions
19
* are met:
20
* 1. Redistributions of source code must retain the above copyright
21
* notice, this list of conditions and the following disclaimer.
22
* 2. Redistributions in binary form must reproduce the above copyright
23
* notice, this list of conditions and the following disclaimer in the
24
* documentation and/or other materials provided with the distribution.
25
26
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
27
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
30
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36
* POSSIBILITY OF SUCH DAMAGE.
37
38
39
40
#ifndef _RTEMS_SCORE_CPU_ASM_H
41
#define _RTEMS_SCORE_CPU_ASM_H
42
43
/* pull in the generated offsets */
44
45
46
#include <rtems/score/offsets.h>
47
48
49
50
* Hardware General Registers
51
52
53
/* put something here */
54
55
56
* Hardware Floating Point Registers
57
58
59
60
61
62
* Hardware Control Registers
63
64
65
66
67
68
* Calling Convention
69
70
71
72
73
74
* Temporary registers
75
76
77
78
79
80
* Floating Point Registers - SW Conventions
81
82
83
84
85
86
* Temporary floating point registers
87
88
89
90
91
#endif
92
93
/* end of file */
