RTEMS 6.1
no_cpu.h
2
3/* no_cpu.h
4 *
5 * This file sets up basic CPU dependency settings based on
6 * compiler settings. For example, it can determine if
7 * floating point is available. This particular implementation
8 * is specified to the NO CPU port.
9 *
10 *
11 * COPYRIGHT (c) 1989-1999.
12 * On-Line Applications Research Corporation (OAR).
13 *
16 * are met:
22 *
34 *
35 */
36
37#ifndef _RTEMS_SCORE_NO_CPU_H
38#define _RTEMS_SCORE_NO_CPU_H
39
40#ifdef __cplusplus
41extern "C" {
42#endif
43
44/*
45 * This file contains the information required to build
46 * RTEMS for a particular member of the NO CPU family.
47 * It does this by setting variables to indicate which
48 * implementation dependent features are present in a particular
49 * member of the family.
50 *
51 * This is a good place to list all the known CPU models
52 * that this port supports and which RTEMS CPU model they correspond
53 * to.
54 */
55
56#if defined(rtems_multilib)
57/*
58 * Figure out all CPU Model Feature Flags based upon compiler
59 * predefines.
60 */
61
62#define CPU_MODEL_NAME "rtems_multilib"
63#define NOCPU_HAS_FPU 1
64
65#elif defined(no_cpu)
66
67#define CPU_MODEL_NAME "no_cpu_model"
68#define NOCPU_HAS_FPU 1
69
70#else
71
72#error "Unsupported CPU Model"
73
74#endif
75
76/*
77 * Define the name of the CPU family.
78 */
79
80#define CPU_NAME "NO CPU"
81
82#ifdef __cplusplus
83}
84#endif
85
86#endif /* _RTEMS_SCORE_NO_CPU_H */
