RTEMS 6.1
cpuimpl.h
2
9/*
10 * Copyright (C) 2013, 2016 embedded brains GmbH & Co. KG
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34#ifndef _RTEMS_SCORE_CPUIMPL_H
35#define _RTEMS_SCORE_CPUIMPL_H
36
37#include <rtems/score/cpu.h>
38
55#define CPU_PER_CPU_CONTROL_SIZE 0
56
73#define CPU_THREAD_LOCAL_STORAGE_VARIANT 10
74
75#ifndef ASM
76
77#ifdef __cplusplus
78extern "C" {
79#endif
80
91typedef struct {
92 /* CPU specific per-CPU state */
94
102register struct Per_CPU_Control *_CPU_Per_CPU_current asm( "rX" );
103
111#define _CPU_Get_current_per_CPU_control() ( _CPU_Per_CPU_current )
112
121#define _CPU_Get_thread_executing() ( _CPU_Per_CPU_current->executing )
122
123/* end of Fatal Error manager macros */
124
137void _CPU_Context_volatile_clobber( uintptr_t pattern );
138
154void _CPU_Context_validate( uintptr_t pattern );
155
161static inline void _CPU_Instruction_illegal( void )
162{
163 __asm__ volatile ( ".word 0" );
164}
165
171static inline void _CPU_Instruction_no_operation( void )
172{
173 __asm__ volatile ( "nop" );
174}
175
186static inline void _CPU_Use_thread_local_storage(
188)
189{
190 (void) context;
191}
192
201static inline void *_CPU_Get_TLS_thread_pointer(
203)
204{
205 (void) context;
206 return NULL;
207}
208
209#ifdef __cplusplus
210}
211#endif
212
213#endif /* ASM */
214
217#endif /* _RTEMS_SCORE_CPUIMPL_H */
rtems_termios_device_context * context
Definition: console-config.c:62
The CPU specific per-CPU control.
Definition: cpuimpl.h:91
Thread register context.
Definition: cpu.h:173
Per CPU Core Structure.
Definition: percpu.h:384
