RTEMS 6.1
cpu_asm.h
2
13/*
14 *
15 *
16 * COPYRIGHT (c) 1989-1999.
17 * On-Line Applications Research Corporation (OAR).
18 *
19 * Redistribution and use in source and binary forms, with or without
20 * modification, are permitted provided that the following conditions
21 * are met:
22 * 1. Redistributions of source code must retain the above copyright
23 * notice, this list of conditions and the following disclaimer.
24 * 2. Redistributions in binary form must reproduce the above copyright
25 * notice, this list of conditions and the following disclaimer in the
26 * documentation and/or other materials provided with the distribution.
27 *
28 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
29 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
30 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
31 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
32 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
33 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
34 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
35 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
36 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
37 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
38 * POSSIBILITY OF SUCH DAMAGE.
39 *
40 */
41
42#ifndef _RTEMS_SCORE_CPU_ASM_H
43#define _RTEMS_SCORE_CPU_ASM_H
44
45/* pull in the generated offsets */
46
47#include <rtems/score/offsets.h>
48
49/*
50 * Hardware General Registers
51 */
52
53/* put something here */
54
55/*
56 * Hardware Floating Point Registers
57 */
58
59/* put something here */
60
61/*
62 * Hardware Control Registers
63 */
64
65/* put something here */
66
67/*
68 * Calling Convention
69 */
70
71/* put something here */
72
73/*
74 * Temporary registers
75 */
76
77/* put something here */
78
79/*
80 * Floating Point Registers - SW Conventions
81 */
82
83/* put something here */
84
85/*
86 * Temporary floating point registers
87 */
88
89/* put something here */
90
91#endif
92
93/* end of file */
