RTEMS 6.1
cpuimpl.h
2
9/*
10 * Copyright (c) 2013 embedded brains GmbH & Co. KG
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34#ifndef _RTEMS_SCORE_CPUIMPL_H
35#define _RTEMS_SCORE_CPUIMPL_H
36
37#include <rtems/score/cpu.h>
38
49#define CPU_PER_CPU_CONTROL_SIZE 0
50
51#define CPU_THREAD_LOCAL_STORAGE_VARIANT 10
52
53#ifndef ASM
54
55#ifdef __cplusplus
56extern "C" {
57#endif
58
59void _CPU_Context_volatile_clobber( uintptr_t pattern );
60
61void _CPU_Context_validate( uintptr_t pattern );
62
63static inline void _CPU_Instruction_illegal( void )
64{
65 __asm__ volatile ( ".word 0" );
66}
67
68static inline void _CPU_Instruction_no_operation( void )
69{
70 __asm__ volatile ( "nop" );
71}
72
73static inline void _CPU_Use_thread_local_storage(
75)
76{
77 register uint32_t r23 __asm__( "r23" );
78
79 r23 = context->r23;
80
81 /* Make sure that the register assignment is not optimized away */
82 __asm__ volatile ( "" : : "r" ( r23 ) );
83}
84
85static inline void *_CPU_Get_TLS_thread_pointer(
87)
88{
89 return (void *) context->r23;
90}
91
92#ifdef __cplusplus
93}
94#endif
95
96#endif /* ASM */
97
100#endif /* _RTEMS_SCORE_CPUIMPL_H */
rtems_termios_device_context * context
Definition: console-config.c:62
Thread register context.
Definition: cpu.h:173
