RTEMS
6.1
bsps
m68k
mrm332
include
mrm332.h
1
/* mrm332.h
2
3
4
#ifndef _MRM332_H_
5
#define _MRM332_H_
6
7
/* SIM_MM (SIM Module Mapping) determines the location of the control
8
register block. When MM=0, register addresses range fom 0x7ff000 to
9
0x7FFFFF. When MM=1, register addresses range from 0xfff000 to
10
0xffffff. */
11
#define SIM_MM 1
12
13
/* Interrupt related definitions */
14
#define SIM_IARB 15
15
#define QSM_IARB 10
16
17
#define MRM_PIV 64
18
#define ISRL_PIT 4
/* zero disables PIT */
19
20
#define EFI_QIVR 66
/* 66=>SCI and 67=>QSPI interrupt */
21
#define ISRL_QSPI 0
22
23
#define EFI_SPINT 24
/* spurious interrupt */
24
#define EFI_INT1 25
/* CTS interrupt */
25
#define ISRL_SCI 6
26
27
/* System Clock definitions */
28
#define XTAL 32768.0
/* crystal frequency in Hz */
29
30
/* Specify the CPU frequency. Do not specify a faster clock than your */
31
/* CPU is rated for! */
32
#if 0
33
/* Default MRM clock rate (8.388688 MHz) set by CPU32: */
34
#define MRM_W 0
/* system clock parameters */
35
#define MRM_X 0
36
#define MRM_Y 0x3f
37
#endif
38
39
#if 0
40
/* 16.77722 MHz: */
41
#define MRM_W 1
42
#define MRM_X 1
43
#define MRM_Y 0x0f
44
#endif
45
46
#if 1
47
/* 25.16582 MHz: */
48
#define MRM_W 1
49
#define MRM_X 1
50
#define MRM_Y 0x17
51
#define SET_EDIV
52
#endif
53
54
#define SYS_CLOCK (XTAL*4.0*(MRM_Y+1)*(1 << (2*MRM_W+MRM_X)))
55
#define SCI_BAUD 19200
/* RS232 Baud Rate */
56
57
/* macros/functions */
58
59
#ifndef ASM
60
61
62
* This prototype really should have the noreturn attribute but
63
* that causes a warning. Not sure how to fix that.
64
65
/* static void reboot(void) __attribute__ ((noreturn)); */
66
static
void
reboot(
void
67
__inline__
static
void
reboot() {__asm__ (
"trap #15; .word 0x0063"
68
69
#endif
/* ASM */
70
71
#endif
/* _MRM_H_ */
