RTEMS 6.1
mon-prmisc.c File Reference
Print misc stuff for the monitor dump routines. More...
#include <rtems/monitor.h>
#include <rtems/assoc.h>
#include <ctype.h>
#include <inttypes.h>
void rtems_monitor_separator (void)
uint32_t rtems_monitor_pad (uint32_t destination_column, uint32_t current_column)
int rtems_monitor_dump_decimal (uint32_t num)
int rtems_monitor_dump_addr (const void *addr)
int rtems_monitor_dump_hex (uint32_t num)
int rtems_monitor_dump_id (rtems_id id)
int rtems_monitor_dump_name (rtems_id id)
int rtems_monitor_dump_priority (rtems_task_priority priority)
int rtems_monitor_dump_state (States_Control state)
int rtems_monitor_dump_attributes (rtems_attribute attributes)
int rtems_monitor_dump_modes (rtems_mode modes)
int rtems_monitor_dump_events (rtems_event_set events)
Each routine returns the number of characters it output.
