| int | BSP_irq_disable_at_i8259s (const rtems_irq_number irqLine) |
| | function to disable a particular irq at 8259 level.
| int | BSP_irq_enable_at_i8259s (const rtems_irq_number irqLine) |
| | function to enable a particular irq at 8259 level.
int | BSP_irq_enabled_at_i8259s (const rtems_irq_number irqLine) |
| | function to check if a particular irq is enabled at 8259 level.
| int | BSP_irq_ack_at_i8259s (const rtems_irq_number irqLine) |
| | function to acknowledge a particular irq at 8259 level.
void | BSP_i8259s_init (void) |
void | bsp_show_interrupt_regs (void) |
int | BSP_i8259s_int_process () |
This file was based upon the powerpc and the i386.
