RTEMS 6.1
regs.h
1
7/*
8 * regs.S -- standard MIPS register names.
9 *
10 * Copyright (c) 1995 Cygnus Support
11 *
12 * The authors hereby grant permission to use, copy, modify, distribute,
13 * and license this software and its documentation for any purpose, provided
14 * that existing copyright notices are retained in all copies and that this
15 * notice is included verbatim in any distributions. No written agreement,
16 * license, or royalty fee is required for any of the authorized uses.
17 * Modifications to this software may be copyrighted by their authors
18 * and need not follow the licensing terms described here, provided that
19 * the new terms are clearly indicated on the first page of each file where
20 * they apply.
21 */
22
35#define zero $0
36#define z0 $0
37#define v0 $2
38#define v1 $3
39#define a0 $4
40#define a1 $5
41#define a2 $6
42#define a3 $7
43#define t0 $8
44#define t1 $9
45#define t2 $10
46#define t3 $11
47#define t4 $12
48#define t5 $13
49#define t6 $14
50#define t7 $15
51#define s0 $16
52#define s1 $17
53#define s2 $18
54#define s3 $19
55#define s4 $20
56#define s5 $21
57#define s6 $22
58#define s7 $23
59#define t8 $24
60#define t9 $25
61#define k0 $26
62#define k1 $27
63#define gp $28
64#define sp $29
65#define fp $30
66#define ra $31
67#define pc $pc
68
69#define fp0 $f0
70#define fp1 $f1
71
79#define K0BASE 0x80000000
80#ifndef __mips64
81#define K1BASE 0xA0000000
82#else
83#define K1BASE 0xFFFFFFFFA0000000LL
84#endif
85
88#define PHYS_TO_K1(a) ((unsigned)(a) | K1BASE)
89
95#define C0_COUNT $9
96#define C0_SR $12
97#define C0_CAUSE $13
98#define C0_EPC $14
99#define C0_CONFIG $16
100
108#define SR_CU1 0x20000000
109#define SR_FR 0x04000000
110#define SR_BEV 0x00400000
111#define SR_PE 0x00100000
112
113#define SR_KX 0x00000080
114#define SR_SX 0x00000040
115#define SR_UX 0x00000020
116
125#define CACHE_I (0)
126#define CACHE_D (1)
127#define CACHE_SI (2)
128#define CACHE_SD (3)
129
130#define INDEX_INVALIDATE (0)
131#define INDEX_LOAD_TAG (1)
132#define INDEX_STORE_TAG (2)
133#define CREATE_DIRTY_EXCLUSIVE (3)
134#define HIT_INVALIDATE (4)
135#define CACHE_FILL (5)
136#define HIT_WRITEBACK_INVALIDATE (5)
137#define HIT_WRITEBACK (6)
138#define HIT_SET_VIRTUAL (7)
139
140#define BUILD_CACHE_OP(o,c) (((o) << 2) | (c))
141
149#define INDEX_INVALIDATE_I BUILD_CACHE_OP(INDEX_INVALIDATE,CACHE_I)
150#define INDEX_WRITEBACK_INVALIDATE_D BUILD_CACHE_OP(INDEX_INVALIDATE,CACHE_D)
151#define INDEX_INVALIDATE_SI BUILD_CACHE_OP(INDEX_INVALIDATE,CACHE_SI)
152#define INDEX_WRITEBACK_INVALIDATE_SD BUILD_CACHE_OP(INDEX_INVALIDATE,CACHE_SD)
153
154#define INDEX_LOAD_TAG_I BUILD_CACHE_OP(INDEX_LOAD_TAG,CACHE_I)
155#define INDEX_LOAD_TAG_D BUILD_CACHE_OP(INDEX_LOAD_TAG,CACHE_D)
156#define INDEX_LOAD_TAG_SI BUILD_CACHE_OP(INDEX_LOAD_TAG,CACHE_SI)
157#define INDEX_LOAD_TAG_SD BUILD_CACHE_OP(INDEX_LOAD_TAG,CACHE_SD)
158
159#define INDEX_STORE_TAG_I BUILD_CACHE_OP(INDEX_STORE_TAG,CACHE_I)
160#define INDEX_STORE_TAG_D BUILD_CACHE_OP(INDEX_STORE_TAG,CACHE_D)
161#define INDEX_STORE_TAG_SI BUILD_CACHE_OP(INDEX_STORE_TAG,CACHE_SI)
162#define INDEX_STORE_TAG_SD BUILD_CACHE_OP(INDEX_STORE_TAG,CACHE_SD)
163
164#define CREATE_DIRTY_EXCLUSIVE_D BUILD_CACHE_OP(CREATE_DIRTY_EXCLUSIVE,CACHE_D)
165#define CREATE_DIRTY_EXCLUSIVE_SD BUILD_CACHE_OP(CREATE_DIRTY_EXCLUSIVE,CACHE_SD)
166
167#define HIT_INVALIDATE_I BUILD_CACHE_OP(HIT_INVALIDATE,CACHE_I)
168#define HIT_INVALIDATE_D BUILD_CACHE_OP(HIT_INVALIDATE,CACHE_D)
169#define HIT_INVALIDATE_SI BUILD_CACHE_OP(HIT_INVALIDATE,CACHE_SI)
170#define HIT_INVALIDATE_SD BUILD_CACHE_OP(HIT_INVALIDATE,CACHE_SD)
171
172#define CACHE_FILL_I BUILD_CACHE_OP(CACHE_FILL,CACHE_I)
173#define HIT_WRITEBACK_INVALIDATE_D BUILD_CACHE_OP(HIT_WRITEBACK_INVALIDATE,CACHE_D)
174#define HIT_WRITEBACK_INVALIDATE_SD BUILD_CACHE_OP(HIT_WRITEBACK_INVALIDATE,CACHE_SD)
175
176#define HIT_WRITEBACK_I BUILD_CACHE_OP(HIT_WRITEBACK,CACHE_I)
177#define HIT_WRITEBACK_D BUILD_CACHE_OP(HIT_WRITEBACK,CACHE_D)
178#define HIT_WRITEBACK_SD BUILD_CACHE_OP(HIT_WRITEBACK,CACHE_SD)
179
180#define HIT_SET_VIRTUAL_SI BUILD_CACHE_OP(HIT_SET_VIRTUAL,CACHE_SI)
181#define HIT_SET_VIRTUAL_SD BUILD_CACHE_OP(HIT_SET_VIRTUAL,CACHE_SD)
182
187/*> EOF regs.S <*/
