RTEMS 6.1
milkymist_tmu.h
1
7/* milkymist_tmu.h
8 *
9 * Milkymist TMU driver for RTEMS
10 *
11 * The license and distribution terms for this file may be
12 * found in the file LICENSE in this distribution or at
13 * http://www.rtems.org/license/LICENSE.
14 *
15 * COPYRIGHT (c) 2010 Sebastien Bourdeauducq
16 */
17
25#ifndef __MILKYMIST_TMU_H_
26#define __MILKYMIST_TMU_H_
27
28#ifdef __cplusplus
29extern "C" {
30#endif
31
32/* Ioctls */
33#define TMU_EXECUTE 0x5400
34#define TMU_EXECUTE_NONBLOCK 0x5401
35#define TMU_EXECUTE_WAIT 0x5402
36
37struct tmu_vertex {
38 int x;
39 int y;
40} __attribute__((packed));
41
42struct tmu_td {
43 unsigned int flags;
44 unsigned int hmeshlast;
45 unsigned int vmeshlast;
46 unsigned int brightness;
47 unsigned short chromakey;
48 struct tmu_vertex *vertices;
49 unsigned short *texfbuf;
50 unsigned int texhres;
51 unsigned int texvres;
52 unsigned int texhmask;
53 unsigned int texvmask;
54 unsigned short *dstfbuf;
55 unsigned int dsthres;
56 unsigned int dstvres;
57 int dsthoffset;
58 int dstvoffset;
59 unsigned int dstsquarew;
60 unsigned int dstsquareh;
61 unsigned int alpha;
62
63 bool invalidate_before;
64 bool invalidate_after;
65};
66
67#define TMU_BRIGHTNESS_MAX (63)
68#define TMU_MASK_NOFILTER (0x3ffc0)
69#define TMU_MASK_FULL (0x3ffff)
70#define TMU_FIXEDPOINT_SHIFT (6)
71#define TMU_ALPHA_MAX (63)
72#define TMU_MESH_MAXSIZE (128)
73
74#define TMU_FLAG_CHROMAKEY (2)
75#define TMU_FLAG_ADDITIVE (4)
76
77rtems_device_driver tmu_initialize(
80 void *arg
81);
82
83rtems_device_driver tmu_control(
86 void *arg
87);
88
89#define TMU_DRIVER_TABLE_ENTRY {tmu_initialize, \
90NULL, NULL, NULL, NULL, tmu_control}
91
94#ifdef __cplusplus
95}
96#endif
97
98#endif /* __MILKYMIST_TMU_H_ */
uint32_t rtems_device_major_number
This integer type represents the major number of devices.
Definition: io.h:103
uint32_t rtems_device_minor_number
This integer type represents the minor number of devices.
Definition: io.h:115
rtems_status_code
Definition: status.h:85
Definition: xnandpsu_onfi.h:185
Definition: milkymist_tmu.h:42
Definition: milkymist_tmu.h:37
