RTEMS 6.1
mcp7940m-rtc.h
2
11/*
12 * Copyright (C) 2023 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBCHIP_MCP7940M_RTC_H
37#define LIBCHIP_MCP7940M_RTC_H
38
39#include <libchip/i2c-rtc.h>
40
41#ifdef __cplusplus
42extern "C" {
43#endif /* __cplusplus */
44
67 struct i2c_rtc_base base;
68
70 bool crystal;
71};
72
74int mcp7940m_hw_init(struct i2c_rtc_base *base);
75
76#define MCP7940M_RTC_INITIALIZER(i2c_path, i2c_address, has_crystal) { \
77 .base = I2C_RTC_INITIALIZER( \
78 i2c_path, \
79 i2c_address, \
80 0, \
81 I2C_RTC_ORDER_sec_min_hour_wkday_day_month_year, \
82 "mcp7940", \
83 mcp7940m_hw_init), \
84 .crystal = has_crystal, \
85 }
86
87#define MCP7940M_RTC_TBL_ENTRY(dev_name, mcp7940m_rtc_ctx) \
88 I2C_RTC_TBL_ENTRY(dev_name, mcp7940m_rtc_ctx)
89
92#ifdef __cplusplus
93}
94#endif /* __cplusplus */
95
96#endif /* LIBCHIP_MCP7940M_RTC_H */
Definition: mcp7940m.c:68
This file provides the interfaces of Shared_tod_i2c_rtc.
Definition: i2c-rtc.h:98
Definition: mcp7940m-rtc.h:66
bool crystal
Definition: mcp7940m-rtc.h:70
