RTEMS 6.1
mcdma_glue.h
2
3/*
4 * RTEMS generic mcf548x BSP
5 *
6 * This file declares glue functions to the Freescale Mcdma API.
7 */
8
9/*
10 * Copyright (C) 2004, 2009 embedded brains GmbH & Co. KG
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34#ifndef _MCDMA_GLUE_H
35#define _MCDMA_GLUE_H
36
37#include <rtems.h>
38#include <rtems/irq.h>
39#include <mcf548x/mcf548x.h>
40
41#define MCDMA_CLR_PENDING(chan) (MCF548X_DMA_DIPR = (1 << (chan)))
42#define MCDMA_GET_PENDING(chan) (MCF548X_DMA_DIPR & (1 << (chan)))
43
44/*=========================================================================*\
45| Function: |
46\*-------------------------------------------------------------------------*/
47void mcdma_glue_irq_enable
48(
49/*-------------------------------------------------------------------------*\
50| Purpose: |
51| enable interrupt for given task number |
52+---------------------------------------------------------------------------+
53| Input Parameters: |
54\*-------------------------------------------------------------------------*/
55 int mcdma_taskno /* task number to enable */
56 );
57/*-------------------------------------------------------------------------*\
58| Return Value: |
59| none |
60\*=========================================================================*/
61
62/*=========================================================================*\
63| Function: |
64\*-------------------------------------------------------------------------*/
65void mcdma_glue_irq_disable
66(
67/*-------------------------------------------------------------------------*\
68| Purpose: |
69| disable interrupt for given task number |
70+---------------------------------------------------------------------------+
71| Input Parameters: |
72\*-------------------------------------------------------------------------*/
73 int mcdma_taskno /* task number to disable */
74 );
75/*-------------------------------------------------------------------------*\
76| Return Value: |
77| none |
78\*=========================================================================*/
79
80/*=========================================================================*\
81| Function: |
82\*-------------------------------------------------------------------------*/
83void mcdma_glue_irq_install
84(
85/*-------------------------------------------------------------------------*\
86| Purpose: |
87| install given function as mcdma interrupt handler |
88+---------------------------------------------------------------------------+
89| Input Parameters: |
90\*-------------------------------------------------------------------------*/
91 int mcdma_taskno, /* task number for handler */
92 void (*the_handler)(rtems_irq_hdl_param), /* function to call */
93 void *the_param
94 );
95/*-------------------------------------------------------------------------*\
96| Return Value: |
97| none |
98\*=========================================================================*/
99
100/*=========================================================================*\
101| Function: |
102\*-------------------------------------------------------------------------*/
103void mcdma_glue_init
104(
105/*-------------------------------------------------------------------------*\
106| Purpose: |
107| initialize the mcdma module (if not yet done): |
108| - load code |
109| - initialize registers |
110| - initialize bus arbiter |
111| - initialize interrupt control |
112+---------------------------------------------------------------------------+
113| Input Parameters: |
114\*-------------------------------------------------------------------------*/
115 void *sram_base /* base address for SRAM, to be used for DMA task */
116 );
117/*-------------------------------------------------------------------------*\
118| Return Value: |
119| none |
120\*=========================================================================*/
121
122#endif /* _MCDMA_GLUE_H */
