RTEMS 6.1
mc9328mxl.h
1/*
2 * Motorola MC9328MXL Register definitions
3 *
4 * Copyright (c) 2003 by Cogent Computer Systems
5 * Written by Jay Monkman <jtm@lopingdog.com>
6 *
7 * The license and distribution terms for this file may be
8 * found in the file LICENSE in this distribution or at
9 * http://www.rtems.org/license/LICENSE.
10 */
11#ifndef __MC9328MXL_H__
12#define __MC9328MXL_H__
13
14#include <stdint.h>
15
16#define bit(_x_) (1 << (_x_))
17
18/* Define some constants relating to the CPU */
19#define MC9328MXL_NUM_INTS 64 /* CPU supports 64 interrupts */
20
21/* Define the base addresses of the internal registers */
22#define MC9328MXL_AIPI1_BASE 0x00200000
23#define MC9328MXL_AIPI2_BASE 0x00210000
24#define MC9328MXL_WDOG_BASE 0x00201000
25#define MC9328MXL_TMR1_BASE 0x00202000
26#define MC9328MXL_TMR2_BASE 0x00203000
27#define MC9328MXL_RTC_BASE 0x00204000
28#define MC9328MXL_LCDC_BASE 0x00205000
29#define MC9328MXL_UART1_BASE 0x00206000
30#define MC9328MXL_UART2_BASE 0x00207000
31#define MC9328MXL_PWM_BASE 0x00208000
32#define MC9328MXL_DMAC_BASE 0x00209000
33#define MC9328MXL_USBD_BASE 0x00212000
34#define MC9328MXL_SPI1_BASE 0x00213000
35#define MC9328MXL_SPI2_BASE 0x00219000
36#define MC9328MXL_MMC_BASE 0x00214000
37#define MC9328MXL_I2C_BASE 0x00217000
38#define MC9328MXL_SSI_BASE 0x00218000
39#define MC9328MXL_MSHC_BASE 0x0021a000
40#define MC9328MXL_PLL_BASE 0x0021b000
41#define MC9328MXL_RESET_BASE 0x0021b800
42#define MC9328MXL_SYSCTRL_BASE 0x0021b804
43#define MC9328MXL_GPIOA_BASE 0x0021c000
44#define MC9328MXL_GPIOB_BASE 0x0021c100
45#define MC9328MXL_GPIOC_BASE 0x0021c200
46#define MC9328MXL_GPIOD_BASE 0x0021c300
47#define MC9328MXL_EIM_BASE 0x00220000
48#define MC9328MXL_SDRAM_BASE 0x00221000
49#define MC9328MXL_MMA_BASE 0x00222000
50#define MC9328MXL_AITC_BASE 0x00223000
51#define MC9328MXL_CSI_BASE 0x00224000
52
53
54#define MC9328MXL_TMR1_TCTL (*((volatile uint32_t *)((MC9328MXL_TMR1_BASE) + 0x00)))
55#define MC9328MXL_TMR1_TPRER (*((volatile uint32_t *)((MC9328MXL_TMR1_BASE) + 0x04)))
56#define MC9328MXL_TMR1_TCMP (*((volatile uint32_t *)((MC9328MXL_TMR1_BASE) + 0x08)))
57#define MC9328MXL_TMR1_TCR (*((volatile uint32_t *)((MC9328MXL_TMR1_BASE) + 0x0c)))
58#define MC9328MXL_TMR1_TCN (*((volatile uint32_t *)((MC9328MXL_TMR1_BASE) + 0x10)))
59#define MC9328MXL_TMR1_TSTAT (*((volatile uint32_t *)((MC9328MXL_TMR1_BASE) + 0x14)))
60
61#define MC9328MXL_TMR2_TCTL (*((volatile uint32_t *)((MC9328MXL_TMR2_BASE) + 0x00)))
62#define MC9328MXL_TMR2_TPRER (*((volatile uint32_t *)((MC9328MXL_TMR2_BASE) + 0x04)))
63#define MC9328MXL_TMR2_TCMP (*((volatile uint32_t *)((MC9328MXL_TMR2_BASE) + 0x08)))
64#define MC9328MXL_TMR2_TCR (*((volatile uint32_t *)((MC9328MXL_TMR2_BASE) + 0x0c)))
65#define MC9328MXL_TMR2_TCN (*((volatile uint32_t *)((MC9328MXL_TMR2_BASE) + 0x10)))
66#define MC9328MXL_TMR2_TSTAT (*((volatile uint32_t *)((MC9328MXL_TMR2_BASE) + 0x14)))
67
68#define MC9328MXL_TMR_TCTL_SWR (bit(15))
69#define MC9328MXL_TMR_TCTL_FRR (bit(8))
70#define MC9328MXL_TMR_TCTL_CAP_DIS (0 << 6)
71#define MC9328MXL_TMR_TCTL_CAP_RISE (1 << 6)
72#define MC9328MXL_TMR_TCTL_CAP_FALL (2 << 6)
73#define MC9328MXL_TMR_TCTL_CAP_ANY (3 << 6)
74#define MC9328MXL_TMR_TCTL_OM (bit(5))
75#define MC9328MXL_TMR_TCTL_IRQEN (bit(4))
76#define MC9328MXL_TMR_TCTL_CLKSRC_STOP (0 << 1)
77#define MC9328MXL_TMR_TCTL_CLKSRC_PCLK1 (1 << 1)
78#define MC9328MXL_TMR_TCTL_CLKSRC_PCLK_DIV16 (2 << 1)
79#define MC9328MXL_TMR_TCTL_CLKSRC_TIN (3 << 1)
80#define MC9328MXL_TMR_TCTL_CLKSRC_32KHX (4 << 1)
81#define MC9328MXL_TMR_TCTL_TEN (bit(0))
82
83#define MC9328MXL_UART1_RXD (*((volatile uint32_t *)((MC9328MXL_UART1_BASE) + 0x00)))
84#define MC9328MXL_UART1_TXD (*((volatile uint32_t *)((MC9328MXL_UART1_BASE) + 0x40)))
85#define MC9328MXL_UART1_CR1 (*((volatile uint32_t *)((MC9328MXL_UART1_BASE) + 0x80)))
86#define MC9328MXL_UART1_CR2 (*((volatile uint32_t *)((MC9328MXL_UART1_BASE) + 0x84)))
87#define MC9328MXL_UART1_CR3 (*((volatile uint32_t *)((MC9328MXL_UART1_BASE) + 0x88)))
88#define MC9328MXL_UART1_CR4 (*((volatile uint32_t *)((MC9328MXL_UART1_BASE) + 0x8c)))
89#define MC9328MXL_UART1_FCR (*((volatile uint32_t *)((MC9328MXL_UART1_BASE) + 0x90)))
90#define MC9328MXL_UART1_SR1 (*((volatile uint32_t *)((MC9328MXL_UART1_BASE) + 0x94)))
91#define MC9328MXL_UART1_SR2 (*((volatile uint32_t *)((MC9328MXL_UART1_BASE) + 0x98)))
92#define MC9328MXL_UART1_ESC (*((volatile uint32_t *)((MC9328MXL_UART1_BASE) + 0x9c)))
93#define MC9328MXL_UART1_TIM (*((volatile uint32_t *)((MC9328MXL_UART1_BASE) + 0xa0)))
94#define MC9328MXL_UART1_BIR (*((volatile uint32_t *)((MC9328MXL_UART1_BASE) + 0xa4)))
95#define MC9328MXL_UART1_BMR (*((volatile uint32_t *)((MC9328MXL_UART1_BASE) + 0xa8)))
96#define MC9328MXL_UART1_BRC (*((volatile uint32_t *)((MC9328MXL_UART1_BASE) + 0xac)))
97#define MC9328MXL_UART1_IPR1 (*((volatile uint32_t *)((MC9328MXL_UART1_BASE) + 0xb0)))
98#define MC9328MXL_UART1_IPR2 (*((volatile uint32_t *)((MC9328MXL_UART1_BASE) + 0xb4)))
99#define MC9328MXL_UART1_IPR3 (*((volatile uint32_t *)((MC9328MXL_UART1_BASE) + 0xb8)))
100#define MC9328MXL_UART1_IPR4 (*((volatile uint32_t *)((MC9328MXL_UART1_BASE) + 0xbc)))
101#define MC9328MXL_UART1_MPR1 (*((volatile uint32_t *)((MC9328MXL_UART1_BASE) + 0xc0)))
102#define MC9328MXL_UART1_MPR2 (*((volatile uint32_t *)((MC9328MXL_UART1_BASE) + 0xc4)))
103#define MC9328MXL_UART1_MPR3 (*((volatile uint32_t *)((MC9328MXL_UART1_BASE) + 0xc8)))
104#define MC9328MXL_UART1_MPR4 (*((volatile uint32_t *)((MC9328MXL_UART1_BASE) + 0xcc)))
105#define MC9328MXL_UART1_TS (*((volatile uint32_t *)((MC9328MXL_UART1_BASE) + 0xd0)))
106
107#define MC9328MXL_UART2_RXD (*((volatile uint32_t *)((MC9328MXL_UART2_BASE) + 0x00)))
108#define MC9328MXL_UART2_TXD (*((volatile uint32_t *)((MC9328MXL_UART2_BASE) + 0x40)))
109#define MC9328MXL_UART2_CR1 (*((volatile uint32_t *)((MC9328MXL_UART2_BASE) + 0x80)))
110#define MC9328MXL_UART2_CR2 (*((volatile uint32_t *)((MC9328MXL_UART2_BASE) + 0x84)))
111#define MC9328MXL_UART2_CR3 (*((volatile uint32_t *)((MC9328MXL_UART2_BASE) + 0x88)))
112#define MC9328MXL_UART2_CR4 (*((volatile uint32_t *)((MC9328MXL_UART2_BASE) + 0x8c)))
113#define MC9328MXL_UART2_FCR (*((volatile uint32_t *)((MC9328MXL_UART2_BASE) + 0x90)))
114#define MC9328MXL_UART2_SR1 (*((volatile uint32_t *)((MC9328MXL_UART2_BASE) + 0x94)))
115#define MC9328MXL_UART2_SR2 (*((volatile uint32_t *)((MC9328MXL_UART2_BASE) + 0x98)))
116#define MC9328MXL_UART2_ESC (*((volatile uint32_t *)((MC9328MXL_UART2_BASE) + 0x9c)))
117#define MC9328MXL_UART2_TIM (*((volatile uint32_t *)((MC9328MXL_UART2_BASE) + 0xa0)))
118#define MC9328MXL_UART2_BIR (*((volatile uint32_t *)((MC9328MXL_UART2_BASE) + 0xa4)))
119#define MC9328MXL_UART2_BMR (*((volatile uint32_t *)((MC9328MXL_UART2_BASE) + 0xa8)))
120#define MC9328MXL_UART2_BRC (*((volatile uint32_t *)((MC9328MXL_UART2_BASE) + 0xac)))
121#define MC9328MXL_UART2_IPR1 (*((volatile uint32_t *)((MC9328MXL_UART2_BASE) + 0xb0)))
122#define MC9328MXL_UART2_IPR2 (*((volatile uint32_t *)((MC9328MXL_UART2_BASE) + 0xb4)))
123#define MC9328MXL_UART2_IPR3 (*((volatile uint32_t *)((MC9328MXL_UART2_BASE) + 0xb8)))
124#define MC9328MXL_UART2_IPR4 (*((volatile uint32_t *)((MC9328MXL_UART2_BASE) + 0xbc)))
125#define MC9328MXL_UART2_MPR1 (*((volatile uint32_t *)((MC9328MXL_UART2_BASE) + 0xc0)))
126#define MC9328MXL_UART2_MPR2 (*((volatile uint32_t *)((MC9328MXL_UART2_BASE) + 0xc4)))
127#define MC9328MXL_UART2_MPR3 (*((volatile uint32_t *)((MC9328MXL_UART2_BASE) + 0xc8)))
128#define MC9328MXL_UART2_MPR4 (*((volatile uint32_t *)((MC9328MXL_UART2_BASE) + 0xcc)))
129#define MC9328MXL_UART2_TS (*((volatile uint32_t *)((MC9328MXL_UART2_BASE) + 0xd0)))
130
131typedef struct {
132 volatile uint32_t rxd;
133 volatile uint32_t _res0[15];
134 volatile uint32_t txd;
135 volatile uint32_t _res1[15];
136 volatile uint32_t cr1;
137 volatile uint32_t cr2;
138 volatile uint32_t cr3;
139 volatile uint32_t cr4;
140 volatile uint32_t fcr;
141 volatile uint32_t sr1;
142 volatile uint32_t sr2;
143 volatile uint32_t esc;
144 volatile uint32_t tim;
145 volatile uint32_t bir;
146 volatile uint32_t bmr;
147 volatile uint32_t brc;
148 volatile uint32_t ipr1;
149 volatile uint32_t ipr2;
150 volatile uint32_t ipr3;
151 volatile uint32_t ipr4;
152 volatile uint32_t mpr1;
153 volatile uint32_t mpr2;
154 volatile uint32_t mpr3;
155 volatile uint32_t mpr4;
156 volatile uint32_t ts;
158
159#define MC9328MXL_UART_RXD_CHARRDY (bit(15))
160#define MC9328MXL_UART_RXD_ERR (bit(14))
161#define MC9328MXL_UART_RXD_OVRRUN (bit(13))
162#define MC9328MXL_UART_RXD_FRMERR (bit(12))
163#define MC9328MXL_UART_RXD_BRK (bit(11))
164#define MC9328MXL_UART_RXD_PRERR (bit(10))
165#define MC9328MXL_UART_RXD_CHARMASK (0xff)
166
167#define MC9328MXL_UART_CR1_ADEN (bit(15))
168#define MC9328MXL_UART_CR1_ADBR (bit(14))
169#define MC9328MXL_UART_CR1_TRDYEN (bit(13))
170#define MC9328MXL_UART_CR1_IDEN (bit(12))
171#define MC9328MXL_UART_CR1_ICD4 (0x0 << 10)
172#define MC9328MXL_UART_CR1_ICD8 (0x1 << 10)
173#define MC9328MXL_UART_CR1_ICD16 (0x2 << 10)
174#define MC9328MXL_UART_CR1_ICD32 (0x3 << 10)
175#define MC9328MXL_UART_CR1_RRDYEN (bit(9))
176#define MC9328MXL_UART_CR1_RDMAEN (bit(8))
177#define MC9328MXL_UART_CR1_IREN (bit(7))
178#define MC9328MXL_UART_CR1_TXMPTYEN (bit(6))
179#define MC9328MXL_UART_CR1_RTSDEN (bit(5))
180#define MC9328MXL_UART_CR1_SNDBRK (bit(4))
181#define MC9328MXL_UART_CR1_TDMAEN (bit(3))
182#define MC9328MXL_UART_CR1_UARTCLKEN (bit(2))
183#define MC9328MXL_UART_CR1_DOZE (bit(1))
184#define MC9328MXL_UART_CR1_UARTEN (bit(0))
185
186
187#define MC9328MXL_UART_CR2_ESCI (bit(15))
188#define MC9328MXL_UART_CR2_IRTS (bit(14))
189#define MC9328MXL_UART_CR2_CTSC (bit(13))
190#define MC9328MXL_UART_CR2_CTS (bit(12))
191#define MC9328MXL_UART_CR2_ESCEN (bit(11))
192#define MC9328MXL_UART_CR2_RTEC_RE (0 << 9)
193#define MC9328MXL_UART_CR2_RTEC_FE (1 << 9)
194#define MC9328MXL_UART_CR2_RTEC_ANY (2 << 9)
195#define MC9328MXL_UART_CR2_PREN (bit(8))
196#define MC9328MXL_UART_CR2_PROE (bit(7))
197#define MC9328MXL_UART_CR2_STPB (bit(6))
198#define MC9328MXL_UART_CR2_WS (bit(5))
199#define MC9328MXL_UART_CR2_RTSEN (bit(4))
200#define MC9328MXL_UART_CR2_TXEN (bit(2))
201#define MC9328MXL_UART_CR2_RXEN (bit(1))
202#define MC9328MXL_UART_CR2_SRST (bit(0))
203
204#define MC9328MXL_UART_CR3_DPEC_RE (0 << 14) /* UART2 only */
205#define MC9328MXL_UART_CR3_DPEC_FE (1 << 14) /* UART2 only */
206#define MC9328MXL_UART_CR3_DPEC_ANY (2 << 14) /* UART2 only */
207#define MC9328MXL_UART_CR3_DTREN (bit(13)) /* UART2 only */
208#define MC9328MXL_UART_CR3_PARERREN (bit(12))
209#define MC9328MXL_UART_CR3_FRAERREN (bit(11))
210#define MC9328MXL_UART_CR3_DSR (bit(10)) /* UART2 only */
211#define MC9328MXL_UART_CR3_DCD (bit(9)) /* UART2 only */
212#define MC9328MXL_UART_CR3_RI (bit(8)) /* UART2 only */
213#define MC9328MXL_UART_CR3_RXDSEN (bit(6))
214#define MC9328MXL_UART_CR3_AIRINTEN (bit(5))
215#define MC9328MXL_UART_CR3_AWAKEN (bit(4))
216#define MC9328MXL_UART_CR3_REF25 (bit(3))
217#define MC9328MXL_UART_CR3_REF30 (bit(2))
218#define MC9328MXL_UART_CR3_INVT (bit(1))
219#define MC9328MXL_UART_CR3_BPEN (bit(0))
220
221#define MC9328MXL_UART_CR4_CTSTL(_x_) (((_x_) & 0x3f) << 10)
222#define MC9328MXL_UART_CR4_INVR (bit(9))
223#define MC9328MXL_UART_CR4_ENIRI (bit(8))
224#define MC9328MXL_UART_CR4_WKEN (bit(7))
225#define MC9328MXL_UART_CR4_REF16 (bit(6))
226#define MC9328MXL_UART_CR4_IRSC (bit(5))
227#define MC9328MXL_UART_CR4_TCEN (bit(3))
228#define MC9328MXL_UART_CR4_BKEN (bit(2))
229#define MC9328MXL_UART_CR4_OREN (bit(1))
230#define MC9328MXL_UART_CR4_DREN (bit(0))
231
232#define MC9328MXL_UART_FCR_TXTL(x) (((x) & 0x3f) << 10)
233#define MC9328MXL_UART_FCR_RFDIV_1 (5 << 7)
234#define MC9328MXL_UART_FCR_RFDIV_2 (4 << 7)
235#define MC9328MXL_UART_FCR_RFDIV_3 (3 << 7)
236#define MC9328MXL_UART_FCR_RFDIV_4 (2 << 7)
237#define MC9328MXL_UART_FCR_RFDIV_5 (1 << 7)
238#define MC9328MXL_UART_FCR_RFDIV_6 (0 << 7)
239#define MC9328MXL_UART_FCR_RFDIV_7 (6 << 7)
240#define MC9328MXL_UART_FCR_RFDIV_MASK (7 << 7)
241#define MC9328MXL_UART_FCR_RXTL(x) (((x) & 0x3f) << 0)
242
243#define MC9328MXL_UART_SR1_PARERR (bit(15))
244#define MC9328MXL_UART_SR1_RTSS (bit(14))
245#define MC9328MXL_UART_SR1_TRDY (bit(13))
246#define MC9328MXL_UART_SR1_RTSD (bit(12))
247#define MC9328MXL_UART_SR1_ESCF (bit(11))
248#define MC9328MXL_UART_SR1_FRMERR (bit(10))
249#define MC9328MXL_UART_SR1_RRDY (bit(9))
250#define MC9328MXL_UART_SR1_RXDS (bit(6))
251#define MC9328MXL_UART_SR1_AIRINT (bit(5))
252#define MC9328MXL_UART_SR1_AWAKE (bit(4))
253
254#define MC9328MXL_UART_SR2_ADET (bit(15))
255#define MC9328MXL_UART_SR2_TXFE (bit(14))
256#define MC9328MXL_UART_SR2_DTRF (bit(13))
257#define MC9328MXL_UART_SR2_IDLE (bit(12))
258#define MC9328MXL_UART_SR2_IRINT (bit(8))
259#define MC9328MXL_UART_SR2_WAKE (bit(7))
260#define MC9328MXL_UART_SR2_RTSF (bit(4))
261#define MC9328MXL_UART_SR2_TXDC (bit(3))
262#define MC9328MXL_UART_SR2_BRCD (bit(2))
263#define MC9328MXL_UART_SR2_ORE (bit(1))
264#define MC9328MXL_UART_SR2_RDR (bit(0))
265
266
267#define MC9328MXL_PLL_CSCR (*((volatile uint32_t *)((MC9328MXL_PLL_BASE) + 0x00)))
268#define MC9328MXL_PLL_MPCTL0 (*((volatile uint32_t *)((MC9328MXL_PLL_BASE) + 0x04)))
269#define MC9328MXL_PLL_MPCTL1 (*((volatile uint32_t *)((MC9328MXL_PLL_BASE) + 0x08)))
270#define MC9328MXL_PLL_SPCTL0 (*((volatile uint32_t *)((MC9328MXL_PLL_BASE) + 0x0c)))
271#define MC9328MXL_PLL_SPCTL1 (*((volatile uint32_t *)((MC9328MXL_PLL_BASE) + 0x10)))
272#define MC9328MXL_PLL_PCDR (*((volatile uint32_t *)((MC9328MXL_PLL_BASE) + 0x20)))
273
274#define MC9328MXL_PLL_CSCR_CLKOSEL_PERCLK1 (0 << 29)
275#define MC9328MXL_PLL_CSCR_CLKOSEL_HCLK (1 << 29)
276#define MC9328MXL_PLL_CSCR_CLKOSEL_CLK48M (2 << 29)
277#define MC9328MXL_PLL_CSCR_CLKOSEL_CLK16M (3 << 29)
278#define MC9328MXL_PLL_CSCR_CLKOSEL_PREMCLK (4 << 29)
279#define MC9328MXL_PLL_CSCR_CLKOSEL_FCLK (5 << 29)
280
281#define MC9328MXL_PLL_CSCR_USBDIV(_x_) (((_x_) & 0x7) << 26)
282#define MC9328MXL_PLL_CSCR_SDCNT_1 (0 << 24)
283#define MC9328MXL_PLL_CSCR_SDCNT_2 (1 << 24)
284#define MC9328MXL_PLL_CSCR_SDCNT_3 (2 << 24)
285#define MC9328MXL_PLL_CSCR_SDCNT_4 (3 << 24)
286
287#define MC9328MXL_PLL_CSCR_SPLLRSTRT (bit(22))
288#define MC9328MXL_PLL_CSCR_MPLLRSTRT (bit(21))
289#define MC9328MXL_PLL_CSCR_CLK16SEL (bit(18))
290#define MC9328MXL_PLL_CSCR_OSCEN (bit(17))
291#define MC9328MXL_PLL_CSCR_SYSSEL (bit(16))
292#define MC9328MXL_PLL_CSCR_PRESC (bit(15))
293#define MC9328MXL_PLL_CSCR_BLKDIV(_x_) (((_x_) & 0xf) << 10)
294#define MC9328MXL_PLL_CSCR_SPEN (bit(1))
295#define MC9328MXL_PLL_CSCR_MPEN (bit(0))
296
297#define MC9328MXL_PLL_PCDR_PCLK1_MASK (0x0000000f)
298#define MC9328MXL_PLL_PCDR_PCLK1_SHIFT (0)
299#define MC9328MXL_PLL_PCDR_PCLK2_MASK (0x000000f0)
300#define MC9328MXL_PLL_PCDR_PCLK2_SHIFT (4)
301#define MC9328MXL_PLL_PCDR_PCLK3_MASK (0x007f0000)
302#define MC9328MXL_PLL_PCDR_PCLK3_SHIFT (16)
303
304
305#define MC9328MXL_PLL_SPCTL_PD_MASK (0x3c000000)
306#define MC9328MXL_PLL_SPCTL_PD_SHIFT (26)
307#define MC9328MXL_PLL_SPCTL_MFD_MASK (0x03ff0000)
308#define MC9328MXL_PLL_SPCTL_MFD_SHIFT (16)
309#define MC9328MXL_PLL_SPCTL_MFI_MASK (0x00003c00)
310#define MC9328MXL_PLL_SPCTL_MFI_SHIFT (10)
311#define MC9328MXL_PLL_SPCTL_MFN_MASK (0x000003ff)
312#define MC9328MXL_PLL_SPCTL_MFN_SHIFT (0)
313
314
315#define MC9328MXL_GPIOA_DDIR (*((volatile uint32_t *)((MC9328MXL_GPIOA_BASE) + 0x00)))
316#define MC9328MXL_GPIOA_OCR1 (*((volatile uint32_t *)((MC9328MXL_GPIOA_BASE) + 0x04)))
317#define MC9328MXL_GPIOA_OCR2 (*((volatile uint32_t *)((MC9328MXL_GPIOA_BASE) + 0x08)))
318#define MC9328MXL_GPIOA_ICONFA1 (*((volatile uint32_t *)((MC9328MXL_GPIOA_BASE) + 0x0c)))
319#define MC9328MXL_GPIOA_ICONFA2 (*((volatile uint32_t *)((MC9328MXL_GPIOA_BASE) + 0x10)))
320#define MC9328MXL_GPIOA_ICONFB1 (*((volatile uint32_t *)((MC9328MXL_GPIOA_BASE) + 0x14)))
321#define MC9328MXL_GPIOA_ICONFB2 (*((volatile uint32_t *)((MC9328MXL_GPIOA_BASE) + 0x18)))
322#define MC9328MXL_GPIOA_DR (*((volatile uint32_t *)((MC9328MXL_GPIOA_BASE) + 0x1c)))
323#define MC9328MXL_GPIOA_GIUS (*((volatile uint32_t *)((MC9328MXL_GPIOA_BASE) + 0x20)))
324#define MC9328MXL_GPIOA_SSR (*((volatile uint32_t *)((MC9328MXL_GPIOA_BASE) + 0x24)))
325#define MC9328MXL_GPIOA_ICR1 (*((volatile uint32_t *)((MC9328MXL_GPIOA_BASE) + 0x28)))
326#define MC9328MXL_GPIOA_ICR2 (*((volatile uint32_t *)((MC9328MXL_GPIOA_BASE) + 0x2c)))
327#define MC9328MXL_GPIOA_IMR (*((volatile uint32_t *)((MC9328MXL_GPIOA_BASE) + 0x30)))
328#define MC9328MXL_GPIOA_ISR (*((volatile uint32_t *)((MC9328MXL_GPIOA_BASE) + 0x34)))
329#define MC9328MXL_GPIOA_GPR (*((volatile uint32_t *)((MC9328MXL_GPIOA_BASE) + 0x38)))
330#define MC9328MXL_GPIOA_SWR (*((volatile uint32_t *)((MC9328MXL_GPIOA_BASE) + 0x3c)))
331#define MC9328MXL_GPIOA_PUEN (*((volatile uint32_t *)((MC9328MXL_GPIOA_BASE) + 0x40)))
332
333#define MC9328MXL_GPIOB_DDIR (*((volatile uint32_t *)((MC9328MXL_GPIOB_BASE) + 0x00)))
334#define MC9328MXL_GPIOB_OCR1 (*((volatile uint32_t *)((MC9328MXL_GPIOB_BASE) + 0x04)))
335#define MC9328MXL_GPIOB_OCR2 (*((volatile uint32_t *)((MC9328MXL_GPIOB_BASE) + 0x08)))
336#define MC9328MXL_GPIOB_ICONFA1 (*((volatile uint32_t *)((MC9328MXL_GPIOB_BASE) + 0x0c)))
337#define MC9328MXL_GPIOB_ICONFA2 (*((volatile uint32_t *)((MC9328MXL_GPIOB_BASE) + 0x10)))
338#define MC9328MXL_GPIOB_ICONFB1 (*((volatile uint32_t *)((MC9328MXL_GPIOB_BASE) + 0x14)))
339#define MC9328MXL_GPIOB_ICONFB2 (*((volatile uint32_t *)((MC9328MXL_GPIOB_BASE) + 0x18)))
340#define MC9328MXL_GPIOB_DR (*((volatile uint32_t *)((MC9328MXL_GPIOB_BASE) + 0x1c)))
341#define MC9328MXL_GPIOB_GIUS (*((volatile uint32_t *)((MC9328MXL_GPIOB_BASE) + 0x20)))
342#define MC9328MXL_GPIOB_SSR (*((volatile uint32_t *)((MC9328MXL_GPIOB_BASE) + 0x24)))
343#define MC9328MXL_GPIOB_ICR1 (*((volatile uint32_t *)((MC9328MXL_GPIOB_BASE) + 0x28)))
344#define MC9328MXL_GPIOB_ICR2 (*((volatile uint32_t *)((MC9328MXL_GPIOB_BASE) + 0x2c)))
345#define MC9328MXL_GPIOB_IMR (*((volatile uint32_t *)((MC9328MXL_GPIOB_BASE) + 0x30)))
346#define MC9328MXL_GPIOB_ISR (*((volatile uint32_t *)((MC9328MXL_GPIOB_BASE) + 0x34)))
347#define MC9328MXL_GPIOB_GPR (*((volatile uint32_t *)((MC9328MXL_GPIOB_BASE) + 0x38)))
348#define MC9328MXL_GPIOB_SWR (*((volatile uint32_t *)((MC9328MXL_GPIOB_BASE) + 0x3c)))
349#define MC9328MXL_GPIOB_PUEN (*((volatile uint32_t *)((MC9328MXL_GPIOB_BASE) + 0x40)))
350
351#define MC9328MXL_GPIOC_DDIR (*((volatile uint32_t *)((MC9328MXL_GPIOC_BASE) + 0x00)))
352#define MC9328MXL_GPIOC_OCR1 (*((volatile uint32_t *)((MC9328MXL_GPIOC_BASE) + 0x04)))
353#define MC9328MXL_GPIOC_OCR2 (*((volatile uint32_t *)((MC9328MXL_GPIOC_BASE) + 0x08)))
354#define MC9328MXL_GPIOC_ICONFA1 (*((volatile uint32_t *)((MC9328MXL_GPIOC_BASE) + 0x0c)))
355#define MC9328MXL_GPIOC_ICONFA2 (*((volatile uint32_t *)((MC9328MXL_GPIOC_BASE) + 0x10)))
356#define MC9328MXL_GPIOC_ICONFB1 (*((volatile uint32_t *)((MC9328MXL_GPIOC_BASE) + 0x14)))
357#define MC9328MXL_GPIOC_ICONFB2 (*((volatile uint32_t *)((MC9328MXL_GPIOC_BASE) + 0x18)))
358#define MC9328MXL_GPIOC_DR (*((volatile uint32_t *)((MC9328MXL_GPIOC_BASE) + 0x1c)))
359#define MC9328MXL_GPIOC_GIUS (*((volatile uint32_t *)((MC9328MXL_GPIOC_BASE) + 0x20)))
360#define MC9328MXL_GPIOC_SSR (*((volatile uint32_t *)((MC9328MXL_GPIOC_BASE) + 0x24)))
361#define MC9328MXL_GPIOC_ICR1 (*((volatile uint32_t *)((MC9328MXL_GPIOC_BASE) + 0x28)))
362#define MC9328MXL_GPIOC_ICR2 (*((volatile uint32_t *)((MC9328MXL_GPIOC_BASE) + 0x2c)))
363#define MC9328MXL_GPIOC_IMR (*((volatile uint32_t *)((MC9328MXL_GPIOC_BASE) + 0x30)))
364#define MC9328MXL_GPIOC_ISR (*((volatile uint32_t *)((MC9328MXL_GPIOC_BASE) + 0x34)))
365#define MC9328MXL_GPIOC_GPR (*((volatile uint32_t *)((MC9328MXL_GPIOC_BASE) + 0x38)))
366#define MC9328MXL_GPIOC_SWR (*((volatile uint32_t *)((MC9328MXL_GPIOC_BASE) + 0x3c)))
367#define MC9328MXL_GPIOC_PUEN (*((volatile uint32_t *)((MC9328MXL_GPIOC_BASE) + 0x40)))
368
369#define MC9328MXL_GPIOD_DDIR (*((volatile uint32_t *)((MC9328MXL_GPIOD_BASE) + 0x00)))
370#define MC9328MXL_GPIOD_OCR1 (*((volatile uint32_t *)((MC9328MXL_GPIOD_BASE) + 0x04)))
371#define MC9328MXL_GPIOD_OCR2 (*((volatile uint32_t *)((MC9328MXL_GPIOD_BASE) + 0x08)))
372#define MC9328MXL_GPIOD_ICONFA1 (*((volatile uint32_t *)((MC9328MXL_GPIOD_BASE) + 0x0c)))
373#define MC9328MXL_GPIOD_ICONFA2 (*((volatile uint32_t *)((MC9328MXL_GPIOD_BASE) + 0x10)))
374#define MC9328MXL_GPIOD_ICONFB1 (*((volatile uint32_t *)((MC9328MXL_GPIOD_BASE) + 0x14)))
375#define MC9328MXL_GPIOD_ICONFB2 (*((volatile uint32_t *)((MC9328MXL_GPIOD_BASE) + 0x18)))
376#define MC9328MXL_GPIOD_DR (*((volatile uint32_t *)((MC9328MXL_GPIOD_BASE) + 0x1c)))
377#define MC9328MXL_GPIOD_GIUS (*((volatile uint32_t *)((MC9328MXL_GPIOD_BASE) + 0x20)))
378#define MC9328MXL_GPIOD_SSR (*((volatile uint32_t *)((MC9328MXL_GPIOD_BASE) + 0x24)))
379#define MC9328MXL_GPIOD_ICR1 (*((volatile uint32_t *)((MC9328MXL_GPIOD_BASE) + 0x28)))
380#define MC9328MXL_GPIOD_ICR2 (*((volatile uint32_t *)((MC9328MXL_GPIOD_BASE) + 0x2c)))
381#define MC9328MXL_GPIOD_IMR (*((volatile uint32_t *)((MC9328MXL_GPIOD_BASE) + 0x30)))
382#define MC9328MXL_GPIOD_ISR (*((volatile uint32_t *)((MC9328MXL_GPIOD_BASE) + 0x34)))
383#define MC9328MXL_GPIOD_GPR (*((volatile uint32_t *)((MC9328MXL_GPIOD_BASE) + 0x38)))
384#define MC9328MXL_GPIOD_SWR (*((volatile uint32_t *)((MC9328MXL_GPIOD_BASE) + 0x3c)))
385#define MC9328MXL_GPIOD_PUEN (*((volatile uint32_t *)((MC9328MXL_GPIOD_BASE) + 0x40)))
386
387#define MC9328MXL_AITC_INTCNTL (*((volatile uint32_t *)((MC9328MXL_AITC_BASE) + 0x00)))
388#define MC9328MXL_AITC_NIMASK (*((volatile uint32_t *)((MC9328MXL_AITC_BASE) + 0x04)))
389#define MC9328MXL_AITC_INTENNUM (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x08)))
390#define MC9328MXL_AITC_INTDISNUM (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x0c)))
391#define MC9328MXL_AITC_INTENABLEH (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x10)))
392#define MC9328MXL_AITC_INTENABLEL (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x14)))
393#define MC9328MXL_AITC_INTTYPEH (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x18)))
394#define MC9328MXL_AITC_INTTYPEL (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x1c)))
395#define MC9328MXL_AITC_NIPIR7 (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x20)))
396#define MC9328MXL_AITC_NIPRI6 (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x24)))
397#define MC9328MXL_AITC_NIPRI5 (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x28)))
398#define MC9328MXL_AITC_NIPRI4 (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x2c)))
399#define MC9328MXL_AITC_NIPRI3 (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x30)))
400#define MC9328MXL_AITC_NIPRI2 (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x34)))
401#define MC9328MXL_AITC_NIPRI1 (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x38)))
402#define MC9328MXL_AITC_NIPRI0 (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x3c)))
403#define MC9328MXL_AITC_NIVECSR (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x40)))
404#define MC9328MXL_AITC_FIVECSR (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x44)))
405#define MC9328MXL_AITC_INTSRCH (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x48)))
406#define MC9328MXL_AITC_INTSRCL (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x4c)))
407#define MC9328MXL_AITC_INTFRCH (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x50)))
408#define MC9328MXL_AITC_INTFRCL (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x54)))
409#define MC9328MXL_AITC_NIPNDH (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x58)))
410#define MC9328MXL_AITC_NIPNDL (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x5c)))
411#define MC9328MXL_AITC_FIPNDH (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x60)))
412#define MC9328MXL_AITC_FIPNDL (*((volatile uint32_t *)((MC9328MXL_AITC_BASE)+ 0x64)))
413
414#define MC9328MXL_INT_UART3_PFERR (0)
415#define MC9328MXL_INT_UART3_RTS (1)
416#define MC9328MXL_INT_UART3_DTR (2)
417#define MC9328MXL_INT_UART3_UARTC (3)
418#define MC9328MXL_INT_UART3_TX (4)
419#define MC9328MXL_INT_PEN_UP (5)
420#define MC9328MXL_INT_CSI (6)
421#define MC9328MXL_INT_MMA_MAC (7)
422#define MC9328MXL_INT_MMA (8)
423#define MC9328MXL_INT_COMP (9)
424#define MC9328MXL_INT_MSIRQ (10)
425#define MC9328MXL_INT_GPIO_PORTA (11)
426#define MC9328MXL_INT_GPIO_PORTB (12)
427#define MC9328MXL_INT_GPIO_PORTC (13)
428#define MC9328MXL_INT_LCDC (14)
429#define MC9328MXL_INT_SIM_IRQ (15)
430#define MC9328MXL_INT_SIM_DATA (16)
431#define MC9328MXL_INT_RTC (17)
432#define MC9328MXL_INT_RTC_SAM (18)
433#define MC9328MXL_INT_UART2_PFERR (19)
434#define MC9328MXL_INT_UART2_RTS (20)
435#define MC9328MXL_INT_UART2_DTR (21)
436#define MC9328MXL_INT_UART2_UARTC (22)
437#define MC9328MXL_INT_UART2_TX (23)
438#define MC9328MXL_INT_UART2_RX (24)
439#define MC9328MXL_INT_UART1_PFERR (25)
440#define MC9328MXL_INT_UART1_RTS (26)
441#define MC9328MXL_INT_UART1_DTR (27)
442#define MC9328MXL_INT_UART1_UARTC (28)
443#define MC9328MXL_INT_UART1_TX (29)
444#define MC9328MXL_INT_UART1_RX (30)
445#define MC9328MXL_INT_PEN_DATA (33)
446#define MC9328MXL_INT_PWM (34)
447#define MC9328MXL_INT_MMC_IRQ (35)
448#define MC9328MXL_INT_SSI2_TX (36)
449#define MC9328MXL_INT_SSI2_RX (37)
450#define MC9328MXL_INT_SSI2_ERR (38)
451#define MC9328MXL_INT_I2C (39)
452#define MC9328MXL_INT_SPI2 (40)
453#define MC9328MXL_INT_SPI1 (41)
454#define MC9328MXL_INT_SSI_TX (42)
455#define MC9328MXL_INT_SSI_TX_ERR (43)
456#define MC9328MXL_INT_SSI_RX (44)
457#define MC9328MXL_INT_SSI_RX_ERR (45)
458#define MC9328MXL_INT_TOUCH (46)
459#define MC9328MXL_INT_USBD0 (47)
460#define MC9328MXL_INT_USBD1 (48)
461#define MC9328MXL_INT_USBD2 (49)
462#define MC9328MXL_INT_USBD3 (50)
463#define MC9328MXL_INT_USBD4 (51)
464#define MC9328MXL_INT_USBD5 (52)
465#define MC9328MXL_INT_USBD6 (53)
466#define MC9328MXL_INT_UART3_RX (54)
467#define MC9328MXL_INT_BTSYS (55)
468#define MC9328MXL_INT_BTTIM (56)
469#define MC9328MXL_INT_BTWUI (57)
470#define MC9328MXL_INT_TIMER2 (58)
471#define MC9328MXL_INT_TIMER1 (59)
472#define MC9328MXL_INT_DMA_ERR (60)
473#define MC9328MXL_INT_DMA (61)
474#define MC9328MXL_INT_GPIO_PORTD (62)
475#define MC9328MXL_INT_WDT (63)
476
477#define MC9328MXL_AITC_INTCTL_NIAD BIT(20)
478#define MC9328MXL_AITC_INTCTL_FIAD BIT(19)
479#define MC9328MXL_AITC_NIMASK_MASK (0X1F)
480#define MC9328MXL_AITC_INTENNUM_MASK (0X3F)
481#define MC9328MXL_AITC_INTDISNUM_MASK (0X3F)
482#define MC9328MXL_AITC_NIPRIORITY(_int_, _pri_) \
483 (((_pri_) & 0xf) << ((_int_) & 0x7) * 4)
484
485
486#endif /* __MC9328MXL_H__ */
Definition: mc9328mxl.h:131
