RTEMS 6.1
malloc_p.h
2
12/*
13 * COPYRIGHT (c) 1989-2007.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38#include <rtems.h>
40#include <rtems/malloc.h>
41
42#ifdef __cplusplus
43extern "C" {
44#endif /* __cplusplus */
45
46typedef enum {
47 MALLOC_SYSTEM_STATE_NORMAL,
48 MALLOC_SYSTEM_STATE_NO_PROTECTION,
49 MALLOC_SYSTEM_STATE_NO_ALLOCATION
50} Malloc_System_state;
51
52Malloc_System_state _Malloc_System_state( void );
53
54void _Malloc_Process_deferred_frees( void );
55
56#ifdef __cplusplus
57}
58#endif /* __cplusplus */
This header file defines interfaces to support and use dynamic memory allocation.
This header file provides the interfaces of the Protected Heap Handler.
