RTEMS 6.1
m93cxx.h
1/*
2 * RTEMS generic MPC5200 BSP
3 *
4 * This file contains definitions for the M93Cxx EEPROM devices.
5 *
6 * M93C46 is a serial microwire EEPROM which contains
7 * 1Kbit (128 bytes/64 words) of non-volatile memory.
8 * The device can be configured for byte- or word-
9 * access. The driver provides a file-like interface
10 * to this memory.
11 *
12 * MPC5x00 PIN settings:
13 *
14 * PSC3_6 (output) -> MC93C46 serial data in (D)
15 * PSC3_7 (input) -> MC93C46 serial data out (Q)
16 * PSC3_8 (output) -> MC93C46 chip select input (S)
17 * PSC3_9 (output) -> MC93C46 serial clock (C)
18 */
19
20/*
21 * Copyright (c) 2005 embedded brains GmbH & Co. KG
22 * Copyright (c) 2003 IPR Engineering
23 *
24 * The license and distribution terms for this file may be
25 * found in the file LICENSE in this distribution or at
26 * http://www.rtems.org/license/LICENSE.
27 */
28
29#ifndef __M93CXX_H__
30#define __M93CXX_H__
31
32#ifdef __cplusplus
33extern "C" {
34#endif
35
36static void m93cxx_enable_write(void);
37static void m93cxx_disable_write(void);
38static void m93cxx_write_byte(uint32_t, uint8_t);
39static uint8_t m93cxx_read_byte(uint32_t);
40void wait_usec(unsigned long);
41
42#define M93CXX_MODE_WORD
43/*#define M93C46_MODE_BYTE*/
44#define M93C46
45#define M93C46_NVRAM_SIZE 128
46
47#define GPIO_PSC3_6 (1 << 12)
48#define GPIO_PSC3_7 (1 << 13)
49#define GPIO_PSC3_8 (1 << 26)
50#define GPIO_PSC3_9 (1 << 26)
51
52#define START_BIT 0x1
53#define EWDS_OPCODE 0x0
54#define WRAL_OPCODE 0x1
55#define ERAL_OPCODE 0x2
56#define EWEN_OPCODE 0x3
57#define WRITE_OPCODE 0x4
58#define READ_OPCODE 0x8
59#define ERASE_OPCODE 0xC
60
61#define WAIT(i) wait_usec(i)
62
63#define ENABLE_CHIP_SELECT mpc5200.gpiosido |= GPIO_PSC3_8
64#define DISABLE_CHIP_SELECT mpc5200.gpiosido &= ~GPIO_PSC3_8
65#define SET_DATA_BIT_HIGH mpc5200.gpiosdo |= GPIO_PSC3_6
66#define SET_DATA_BIT_LOW mpc5200.gpiosdo &= ~GPIO_PSC3_6
67
68#ifdef M93CXX_MODE_BYTE
69#define GET_DATA_BYTE_SHIFT(val) ((val) |= ((mpc5200.gpiosdi & GPIO_PSC3_7) >> 13)); \
70 ((val) <<= 1)
71#define SET_DATA_BYTE_SHIFT(val) (((val) & 0x80) ? (mpc5200.gpiosdo |= GPIO_PSC3_6) : (mpc5200.gpiosdo &= ~GPIO_PSC3_6)); \
72 ((val) <<= 1)
73#else
74#define GET_DATA_WORD_SHIFT(val) ((val) |= ((mpc5200.gpiosdi & GPIO_PSC3_7) >> 13)); \
75 ((val) <<= 1)
76#define SET_DATA_WORD_SHIFT(val) (((val) & 0x8000) ? (mpc5200.gpiosdo |= GPIO_PSC3_6) : (mpc5200.gpiosdo &= ~GPIO_PSC3_6)); \
77 ((val) <<= 1)
78#endif
79
80#define MASK_HEAD_SHIFT(head) ((((head) & 0x80000000) >> 31) ? (mpc5200.gpiosdo |= GPIO_PSC3_6) : (mpc5200.gpiosdo &= ~GPIO_PSC3_6)); \
81 ((head) <<= 1)
82#define DO_CLOCK_CYCLE mpc5200.gpiowdo |= GPIO_PSC3_9; \
83 WAIT(1000); \
84 mpc5200.gpiowdo &= ~GPIO_PSC3_9
85#define CHECK_WRITE_BUSY while(!(mpc5200.gpiosdi & GPIO_PSC3_7))
86
87
88#ifdef M93CXX_MODE_BYTE
89#ifdef M93C46
90#define M93C46_EWDS ((START_BIT << 31) | (EWDS_OPCODE << 27))
91#define M93C46_WRAL ((START_BIT << 31) | (WRAL_OPCODE << 27))
92#define M93C46_ERAL ((START_BIT << 31) | (ERAL_OPCODE << 27))
93#define M93C46_EWEN ((START_BIT << 31) | (EWEN_OPCODE << 27))
94#define M93C46_READ(addr) ((START_BIT << 31) | (READ_OPCODE << 27) | ((addr) << 22))
95#define M93C46_WRITE(addr) ((START_BIT << 31) | (WRITE_OPCODE << 27) | ((addr) << 22))
96#define M93C46_ERASE(addr) ((START_BIT << 31) | (ERASE_OPCODE << 27) | ((addr) << 22))
97#define M93C46_CLOCK_CYCLES 10
98#endif
99#else
100#ifdef M93C46
101#define M93C46_EWDS ((START_BIT << 31) | (EWDS_OPCODE << 27))
102#define M93C46_WRAL ((START_BIT << 31) | (WRAL_OPCODE << 27))
103#define M93C46_ERAL ((START_BIT << 31) | (ERAL_OPCODE << 27))
104#define M93C46_EWEN ((START_BIT << 31) | (EWEN_OPCODE << 27))
105#define M93C46_READ(addr) ((START_BIT << 31) | (READ_OPCODE << 27) | ((addr) << 23))
106#define M93C46_WRITE(addr) ((START_BIT << 31) | (WRITE_OPCODE << 27) | ((addr) << 23))
107#define M93C46_ERASE(addr) ((START_BIT << 31) | (ERASE_OPCODE << 27) | ((addr) << 23))
108#define M93C46_CLOCK_CYCLES 9
109#endif
110#endif
111
112#ifdef __cplusplus
113}
114#endif
115
116#endif /* __M93CXX_H__ */
