RTEMS 6.1
tm27.h
1/*
2 * @file
3 * @ingroup m68k_mcf52235
4 * @brief Implementations for interrupt mechanisms for Time Test 27
5 */
6
7/*
8 * The license and distribution terms for this file may be
9 * found in the file LICENSE in this distribution or at
10 * http://www.rtems.org/license/LICENSE.
11 */
12
13#ifndef _RTEMS_TMTEST27
14#error "This is an RTEMS internal file you must not include directly."
15#endif
16
17#ifndef __tm27_h
18#define __tm27_h
19
20/*
21 * Stuff for Time Test 27
22 * Don't bother with hardware -- just use a software-interrupt
23 */
24
25#define MUST_WAIT_FOR_INTERRUPT 0
26
27#define TM27_USE_VECTOR_HANDLER
28
29#define Install_tm27_vector( handler ) set_vector( (handler), 35, 1 )
30
31#define Cause_tm27_intr() asm volatile ("trap #3");
32
33#define Clear_tm27_intr() /* empty */
34
35#define Lower_tm27_intr() /* empty */
36
37#endif
