RTEMS
6.1
bsps
m68k
mcf5206elite
include
nvram.h
1
2
* nvram.h -- DS1307-based non-volatile memory device driver.
3
4
* This driver support file-like operations to 56-bytes long non-volatile
5
* memory of DS1307 I2C real-time clock chip.
6
7
* Copyright (C) 2000 OKTET Ltd., St.-Petersburg, Russia
8
* Author: Victor V. Vengerov <vvv@oktet.ru>
9
10
* The license and distribution terms for this file may be
11
* found in the file LICENSE in this distribution or at
12
13
* http://www.rtems.org/license/LICENSE.
14
15
16
#ifndef __DRIVER__NVRAM_H__
17
#define __DRIVER__NVRAM_H__
18
19
#ifdef __cplusplus
20
extern
"C"
21
#endif
22
23
#define NVRAM_DRIVER_TABLE_ENTRY \
24
{ nvram_driver_initialize, nvram_driver_open, nvram_driver_close, \
25
nvram_driver_read, nvram_driver_write, NULL }
26
27
/* nvram_driver_initialize --
28
* Non-volatile memory device driver initialization.
29
30
rtems_device_driver
31
nvram_driver_initialize(
rtems_device_major_number
major,
32
rtems_device_minor_number
minor,
33
void
*arg);
34
35
/* nvram_driver_open --
36
* Non-volatile memory device driver open primitive.
37
38
rtems_device_driver
39
nvram_driver_open(
major,
40
minor,
41
void
*arg);
42
43
/* nvram_driver_close --
44
* Non-volatile memory device driver close primitive.
45
46
rtems_device_driver
47
nvram_driver_close(
major,
48
minor,
49
void
*arg);
50
51
/* nvram_driver_read --
52
* Non-volatile memory device driver read primitive.
53
54
rtems_device_driver
55
nvram_driver_read(
major,
56
minor,
57
void
*arg);
58
59
/* nvram_driver_write --
60
* Non-volatile memory device driver write primitive.
61
62
rtems_device_driver
63
nvram_driver_write(
major,
64
minor,
65
void
*arg);
66
67
#ifdef __cplusplus
68
69
#endif
70
71
#endif
/* __VFDDRV_H__ */
uint32_t rtems_device_major_number
This integer type represents the major number of devices.
Definition:
io.h:103
uint32_t rtems_device_minor_number
This integer type represents the minor number of devices.
Definition:
io.h:115
rtems_status_code
rtems_status_code
Definition:
status.h:85
