RTEMS 6.1
tm27.h
1
9/*
10 * The license and distribution terms for this file may be
11 * found in the file LICENSE in this distribution or at
12 * http://www.rtems.org/license/LICENSE.
13 */
14
15#ifndef _RTEMS_TMTEST27
16#error "This is an RTEMS internal file you must not include directly."
17#endif
18
19#ifndef __tm27_h
20#define __tm27_h
21
22/*
23 * Stuff for Time Test 27
24 * Don't bother with hardware -- just use a software-interrupt
25 */
26
27#define MUST_WAIT_FOR_INTERRUPT 0
28
29#define TM27_USE_VECTOR_HANDLER
30
31#define Install_tm27_vector( handler ) set_vector( (handler), 35, 1 )
32
33#define Cause_tm27_intr() asm volatile ("trap #3");
34
35#define Clear_tm27_intr() /* empty */
36
37#define Lower_tm27_intr() /* empty */
38
39#endif
