RTEMS 6.1
m360_spi.h
2
11/*
12 * Copyright (c) 2008 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
44#ifndef _M360_SPIDRV_H
45#define _M360_SPIDRV_H
46
47#include <rtems/m68k/m68360.h>
48#include <rtems/libi2c.h>
49#include <rtems/irq.h>
50
51#ifdef __cplusplus
52extern "C" {
53#endif
54
55typedef struct m360_spi_softc {
56 int initialized;
57 rtems_id irq_sema_id;
58 rtems_isr_entry old_handler;
62
63typedef struct {
64 rtems_libi2c_bus_t bus_desc;
65 m360_spi_softc_t softc;
67
68/*=========================================================================*\
69| Function: |
70\*-------------------------------------------------------------------------*/
71rtems_status_code m360_spi_init
72(
73/*-------------------------------------------------------------------------*\
74| Purpose: |
75| initialize the driver |
76+---------------------------------------------------------------------------+
77| Input Parameters: |
78\*-------------------------------------------------------------------------*/
79 rtems_libi2c_bus_t *bh /* bus specifier structure */
80 );
81/*-------------------------------------------------------------------------*\
82| Return Value: |
83| o = ok or error code |
84\*=========================================================================*/
85
86/*=========================================================================*\
87| Function: |
88\*-------------------------------------------------------------------------*/
89int m360_spi_read_bytes
90(
91/*-------------------------------------------------------------------------*\
92| Purpose: |
93| receive some bytes from SPI device |
94+---------------------------------------------------------------------------+
95| Input Parameters: |
96\*-------------------------------------------------------------------------*/
97 rtems_libi2c_bus_t *bh, /* bus specifier structure */
98 unsigned char *buf, /* buffer to store bytes */
99 int len /* number of bytes to receive */
100 );
101/*-------------------------------------------------------------------------*\
102| Return Value: |
103| number of bytes received or (negative) error code |
104\*=========================================================================*/
105
106/*=========================================================================*\
107| Function: |
108\*-------------------------------------------------------------------------*/
109int m360_spi_write_bytes
110(
111/*-------------------------------------------------------------------------*\
112| Purpose: |
113| send some bytes to SPI device |
114+---------------------------------------------------------------------------+
115| Input Parameters: |
116\*-------------------------------------------------------------------------*/
117 rtems_libi2c_bus_t *bh, /* bus specifier structure */
118 unsigned char *buf, /* buffer to send */
119 int len /* number of bytes to send */
120
121 );
122/*-------------------------------------------------------------------------*\
123| Return Value: |
124| number of bytes sent or (negative) error code |
125\*=========================================================================*/
126
127/*=========================================================================*\
128| Function: |
129\*-------------------------------------------------------------------------*/
130rtems_status_code m360_spi_set_tfr_mode
131(
132/*-------------------------------------------------------------------------*\
133| Purpose: |
134| set SPI to desired baudrate/clock mode/character mode |
135+---------------------------------------------------------------------------+
136| Input Parameters: |
137\*-------------------------------------------------------------------------*/
138 rtems_libi2c_bus_t *bh, /* bus specifier structure */
139 const rtems_libi2c_tfr_mode_t *tfr_mode /* transfer mode info */
140 );
141/*-------------------------------------------------------------------------*\
142| Return Value: |
143| rtems_status_code |
144\*=========================================================================*/
145
146/*=========================================================================*\
147| Function: |
148\*-------------------------------------------------------------------------*/
149int m360_spi_ioctl
150(
151/*-------------------------------------------------------------------------*\
152| Purpose: |
153| perform selected ioctl function for SPI |
154+---------------------------------------------------------------------------+
155| Input Parameters: |
156\*-------------------------------------------------------------------------*/
157 rtems_libi2c_bus_t *bh, /* bus specifier structure */
158 int cmd, /* ioctl command code */
159 void *arg /* additional argument array */
160 );
161/*-------------------------------------------------------------------------*\
162| Return Value: |
163| rtems_status_code |
164\*=========================================================================*/
165
166#ifdef __cplusplus
167}
168#endif
169
170
171#endif /* _M360_SPIDRV_H */
ISR_Handler_entry rtems_isr_entry
Interrupt service routines installed by rtems_interrupt_catch() shall have this type.
Definition: intr.h:134
rtems_status_code
Definition: status.h:85
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
Legacy I2C Library.
Definitions for Motorola MC68360 Processor.
Definition: m68360.h:407
Definition: m360_spi.h:63
Definition: m360_spi.h:55
Definition: libi2c.h:163
Definition: libi2c.h:462
