RTEMS 6.1
system-clocks.h
2
11/*
12 * Copyright (C) 2008, 2009 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_LPC24XX_SYSTEM_CLOCKS_H
37#define LIBBSP_ARM_LPC24XX_SYSTEM_CLOCKS_H
38
39#include <bsp/lpc24xx.h>
40
41#ifdef __cplusplus
42extern "C" {
43#endif /* __cplusplus */
44
61
67static inline unsigned lpc24xx_timer(void)
68{
69 return T1TC;
70}
71
81void lpc24xx_micro_seconds_delay(unsigned us);
82
88unsigned lpc24xx_pllclk(void);
89
95unsigned lpc24xx_cclk(void);
96
99#ifdef __cplusplus
100}
101#endif /* __cplusplus */
102
103#endif /* LIBBSP_ARM_LPC24XX_SYSTEM_CLOCKS_H */
Returns the CPU clock frequency in [Hz].
Definition: system-clocks.c:159
Returns the PLL output clock frequency in [Hz].
Definition: system-clocks.c:109
void lpc24xx_timer_initialize(void)
Initializes the standard timer.
Definition: system-clocks.c:55
Delay for us micro seconds.
Definition: system-clocks.c:89
Register definitions.
