RTEMS 6.1
dma.h
2
11/*
12 * Copyright (C) 2008, 2009 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_LPC24XX_DMA_H
37#define LIBBSP_ARM_LPC24XX_DMA_H
38
39#include <rtems.h>
40
41#ifdef __cplusplus
42extern "C" {
43#endif /* __cplusplus */
44
58void lpc24xx_dma_initialize(void);
59
68
77void lpc24xx_dma_channel_release(unsigned channel);
78
87void lpc24xx_dma_channel_disable(unsigned channel, bool force);
88
89rtems_status_code lpc24xx_dma_copy_initialize(void);
90
91rtems_status_code lpc24xx_dma_copy_release(void);
92
93rtems_status_code lpc24xx_dma_copy(
94 unsigned channel,
95 void *dest,
96 const void *src,
97 size_t n,
98 size_t width
99);
100
101rtems_status_code lpc24xx_dma_copy_wait(unsigned channel);
102
105#ifdef __cplusplus
106}
107#endif /* __cplusplus */
108
109#endif /* LIBBSP_ARM_LPC24XX_DMA_H */
rtems_status_code
Definition: status.h:85
rtems_status_code lpc24xx_dma_channel_obtain(unsigned channel)
Tries to obtain the DMA channel channel.
Definition: dma.c:72
Initializes the general purpose DMA.
Definition: dma.c:47
Disables the DMA channel channel.
Definition: dma.c:96
Releases the DMA channel channel.
Definition: dma.c:89
