RTEMS 6.1
system-clocks.h
2
11/*
12 * Copyright (C) 2008, 2009 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_LPC176X_SYSTEM_CLOCKS_H
37#define LIBBSP_ARM_LPC176X_SYSTEM_CLOCKS_H
38
39#include <bsp/lpc176x.h>
40#include <bsp/timer-defs.h>
41
42#ifdef __cplusplus
43extern "C" {
44#endif /* __cplusplus */
45
61void lpc176x_timer_initialize( void );
62
68static inline unsigned lpc176x_get_timer1( void )
69{
70 return LPC176X_T1TC;
71}
72
83void lpc176x_micro_seconds_delay( unsigned us );
84
90unsigned lpc176x_pllclk( void );
91
97unsigned lpc176x_cclk( void );
98
101#ifdef __cplusplus
102}
103#endif /* __cplusplus */
104
105#endif /* LIBBSP_ARM_LPC176X_SYSTEM_CLOCKS_H */
unsigned lpc176x_pllclk(void)
Returns the PLL output clock frequency in [Hz].
Definition: system-clocks.c:89
void lpc176x_timer_initialize(void)
Initializes the standard timer.
Definition: system-clocks.c:54
unsigned lpc176x_cclk(void)
Returns the CPU clock frequency in [Hz].
Definition: system-clocks.c:108
void lpc176x_micro_seconds_delay(unsigned us)
Delay for us micro seconds.
Definition: system-clocks.c:72
Specific register definitions according to lpc176x family boards.
API definitions of the for the timer of the lpc176x bsp.
