RTEMS
6.1
bsps
arm
lpc176x
include
bsp
lpc-clock-config.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
* Copyright (c) 2009 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef LIBBSP_ARM_LPC176X_LPC_CLOCK_CONFIG_H
37
#define LIBBSP_ARM_LPC176X_LPC_CLOCK_CONFIG_H
38
39
#include <bsp.h>
40
#include <bsp/irq.h>
41
bsp/lpc176x.h
42
#include <bsp/io.h>
43
44
#ifdef __cplusplus
45
extern
"C"
46
#endif
/* __cplusplus */
47
48
#define LPC_CLOCK_INTERRUPT LPC176X_IRQ_TIMER_0
49
#define LPC_CLOCK_TIMER_BASE TMR0_BASE_ADDR
50
#define LPC_CLOCK_TIMECOUNTER_BASE TMR1_BASE_ADDR
51
#define LPC_CLOCK_REFERENCE LPC176X_PCLK
52
#define LPC_CLOCK_MODULE_ENABLE() \
53
lpc176x_module_enable( LPC176X_MODULE_TIMER_0, LPC176X_MODULE_PCLK_DEFAULT )
54
55
#ifdef __cplusplus
56
57
#endif
/* __cplusplus */
58
59
#endif
/* LIBBSP_ARM_LPC176X_LPC_CLOCK_CONFIG_H */
lpc176x.h
Specific register definitions according to lpc176x family boards.
