RTEMS 6.1
dma.h
2
11/*
12 * Copyright (C) 2008, 2009 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_LPC176X_DMA_H
37#define LIBBSP_ARM_LPC176X_DMA_H
38
39#include <rtems.h>
40
41#ifdef __cplusplus
42extern "C" {
43#endif /* __cplusplus */
44
58void lpc176x_dma_initialize( void );
59
68
77void lpc176x_dma_channel_release( unsigned channel );
78
88 unsigned channel,
89 bool force
90);
91
92rtems_status_code lpc176x_dma_copy_initialize( void );
93
94rtems_status_code lpc176x_dma_copy_release( void );
95
96rtems_status_code lpc176x_dma_copy(
97 unsigned channel,
98 const void *dest,
99 const void *src,
100 size_t n,
101 size_t width
102);
103
104rtems_status_code lpc176x_dma_copy_wait( unsigned channel );
105
108#ifdef __cplusplus
109}
110#endif /* __cplusplus */
111
112#endif /* LIBBSP_ARM_LPC176X_DMA_H */
rtems_status_code
Definition: status.h:85
rtems_status_code lpc176x_dma_channel_obtain(unsigned channel)
Tries to obtain the DMA channel channel.
Definition: dma.c:70
void lpc176x_dma_channel_release(unsigned channel)
Releases the DMA channel channel.
Definition: dma.c:92
void lpc176x_dma_channel_disable(unsigned channel, bool force)
Disables the DMA channel channel.
Definition: dma.c:102
void lpc176x_dma_initialize(void)
Initializes the general purpose DMA.
Definition: dma.c:45
