RTEMS
6.1
bsps
arm
include
bsp
lpc-timer.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
* Copyright (c) 2009 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef LIBBSP_ARM_SHARED_LPC_TIMER_H
37
#define LIBBSP_ARM_SHARED_LPC_TIMER_H
38
39
#include <stdint.h>
40
41
#ifdef __cplusplus
42
extern
"C"
43
#endif
44
62
#define LPC_TIMER_IR_MR0 0x1U
63
#define LPC_TIMER_IR_MR1 0x2U
64
#define LPC_TIMER_IR_MR2 0x4U
65
#define LPC_TIMER_IR_MR3 0x8U
66
#define LPC_TIMER_IR_CR0 0x10U
67
#define LPC_TIMER_IR_CR1 0x20U
68
#define LPC_TIMER_IR_CR2 0x40U
69
#define LPC_TIMER_IR_CR3 0x80U
70
#define LPC_TIMER_IR_ALL 0xffU
71
80
#define LPC_TIMER_TCR_EN 0x1U
81
#define LPC_TIMER_TCR_RST 0x2U
82
91
#define LPC_TIMER_MCR_MR0_INTR 0x1U
92
#define LPC_TIMER_MCR_MR0_RST 0x2U
93
#define LPC_TIMER_MCR_MR0_STOP 0x4U
94
#define LPC_TIMER_MCR_MR1_INTR 0x8U
95
#define LPC_TIMER_MCR_MR1_RST 0x10U
96
#define LPC_TIMER_MCR_MR1_STOP 0x20U
97
#define LPC_TIMER_MCR_MR2_INTR 0x40U
98
#define LPC_TIMER_MCR_MR2_RST 0x80U
99
#define LPC_TIMER_MCR_MR2_STOP 0x100U
100
#define LPC_TIMER_MCR_MR3_INTR 0x200U
101
#define LPC_TIMER_MCR_MR3_RST 0x400U
102
#define LPC_TIMER_MCR_MR3_STOP 0x800U
103
112
#define LPC_TIMER_CCR_CAP0_RE 0x1U
113
#define LPC_TIMER_CCR_CAP0_FE 0x2U
114
#define LPC_TIMER_CCR_CAP0_INTR 0x4U
115
#define LPC_TIMER_CCR_CAP1_RE 0x8U
116
#define LPC_TIMER_CCR_CAP1_FE 0x10U
117
#define LPC_TIMER_CCR_CAP1_INTR 0x20U
118
#define LPC_TIMER_CCR_CAP2_RE 0x40U
119
#define LPC_TIMER_CCR_CAP2_FE 0x80U
120
#define LPC_TIMER_CCR_CAP2_INTR 0x100U
121
#define LPC_TIMER_CCR_CAP3_RE 0x200U
122
#define LPC_TIMER_CCR_CAP3_FE 0x400U
123
#define LPC_TIMER_CCR_CAP3_INTR 0x800U
124
133
#define LPC_TIMER_EMR_EM0_RE 0x1U
134
#define LPC_TIMER_EMR_EM1_FE 0x2U
135
#define LPC_TIMER_EMR_EM2_INTR 0x4U
136
#define LPC_TIMER_EMR_EM3_RE 0x8U
137
#define LPC_TIMER_EMR_EMC0_FE 0x10U
138
#define LPC_TIMER_EMR_EMC1_INTR 0x20U
139
#define LPC_TIMER_EMR_EMC2_RE 0x40U
140
#define LPC_TIMER_EMR_EMC3_FE 0x80U
141
147
typedef
struct
148
uint32_t ir;
149
uint32_t tcr;
150
uint32_t tc;
151
uint32_t pr;
152
uint32_t
pc
153
uint32_t mcr;
154
uint32_t mr0;
155
uint32_t mr1;
156
uint32_t mr2;
157
uint32_t mr3;
158
uint32_t ccr;
159
uint32_t cr0;
160
uint32_t cr1;
161
uint32_t cr2;
162
uint32_t cr3;
163
uint32_t emr;
164
uint32_t ctcr;
165
lpc_timer
166
169
#ifdef __cplusplus
170
171
#endif
/* __cplusplus */
172
173
#endif
/* LIBBSP_ARM_SHARED_LPC_TIMER_H */
pc
#define pc
pc, used on mips16 */
Definition:
regs.h:67
lpc_timer
Timer control block.
Definition:
lpc-timer.h:147
