RTEMS 6.1
lpc-lcd.h
2
11/*
12 * Copyright (c) 2011 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_SHARED_LPC_LCD_H
37#define LIBBSP_ARM_SHARED_LPC_LCD_H
38
39#include <bsp/utility.h>
40
41#ifdef __cplusplus
42extern "C" {
43#endif
44
56typedef struct {
57 uint8_t img [1024];
58 uint32_t ctrl;
59 uint32_t cfg;
60 uint32_t pal0;
61 uint32_t pal1;
62 uint32_t xy;
63 uint32_t clip;
64 uint32_t intmsk;
65 uint32_t intclr;
66 uint32_t intraw;
67 uint32_t intstat;
69
70typedef struct {
71 uint32_t timh;
72 uint32_t timv;
73 uint32_t pol;
74 uint32_t le;
75 uint32_t upbase;
76 uint32_t lpbase;
77 uint32_t ctrl;
78 uint32_t intmsk;
79 uint32_t intraw;
80 uint32_t intstat;
81 uint32_t intclr;
82 uint32_t upcurr;
83 uint32_t lpcurr;
84 uint8_t reserved_0 [0x200 - 0x034];
85 uint16_t pal [256];
86 uint8_t reserved_1 [0x800 - 0x400];
87 lpc_cursor crsr;
88} lpc_lcd;
89
96#define LCD_CFG_CLKDIV(val) BSP_FLD32(val, 0, 4)
97#define LCD_CFG_HCLK_ENABLE BSP_BIT32(5)
98#define LCD_CFG_MODE_SELECT(val) BSP_FLD32(val, 6, 7)
99#define LCD_CFG_DISPLAY_TYPE BSP_BIT32(8)
100
109#define LCD_TIMH_PPL(val) BSP_FLD32(val, 2, 7)
110#define LCD_TIMH_PPL_GET(reg) BSP_FLD32GET(reg, 2, 7)
111#define LCD_TIMH_HSW(val) BSP_FLD32(val, 8, 15)
112#define LCD_TIMH_HSW_GET(reg) BSP_FLD32GET(reg, 8, 15)
113#define LCD_TIMH_HFP(val) BSP_FLD32(val, 16, 23)
114#define LCD_TIMH_HFP_GET(reg) BSP_FLD32GET(reg, 16, 23)
115#define LCD_TIMH_HBP(val) BSP_FLD32(val, 24, 31)
116#define LCD_TIMH_HBP_GET(reg) BSP_FLD32GET(reg, 24, 31)
117
126#define LCD_TIMV_LPP(val) BSP_FLD32(val, 0, 9)
127#define LCD_TIMV_LPP_GET(reg) BSP_FLD32GET(reg, 0, 9)
128#define LCD_TIMV_VSW(val) BSP_FLD32(val, 10, 15)
129#define LCD_TIMV_VSW_GET(reg) BSP_FLD32GET(reg, 10, 15)
130#define LCD_TIMV_VFP(val) BSP_FLD32(val, 16, 23)
131#define LCD_TIMV_VFP_GET(reg) BSP_FLD32GET(reg, 16, 23)
132#define LCD_TIMV_VBP(val) BSP_FLD32(val, 24, 31)
133#define LCD_TIMV_VBP_GET(reg) BSP_FLD32GET(reg, 24, 31)
134
143#define LCD_POL_PCD_LO(val) BSP_FLD32(val, 0, 4)
144#define LCD_POL_PCD_LO_GET(reg) BSP_FLD32GET(reg, 0, 4)
145#define LCD_POL_CLKSEL BSP_BIT32(5)
146#define LCD_POL_ACB(val) BSP_FLD32(val, 6, 10)
147#define LCD_POL_ACB_GET(reg) BSP_FLD32GET(reg, 6, 10)
148#define LCD_POL_IVS BSP_BIT32(11)
149#define LCD_POL_IHS BSP_BIT32(12)
150#define LCD_POL_IPC BSP_BIT32(13)
151#define LCD_POL_IOE BSP_BIT32(14)
152#define LCD_POL_CPL(val) BSP_FLD32(val, 16, 25)
153#define LCD_POL_CPL_GET(reg) BSP_FLD32GET(reg, 16, 25)
154#define LCD_POL_BCD BSP_BIT32(26)
155#define LCD_POL_PCD_HI(val) BSP_FLD32(val, 27, 31)
156#define LCD_POL_PCD_HI_GET(reg) BSP_FLD32GET(reg, 27, 31)
157
166#define LCD_LE_LED(val) BSP_FLD32(val, 0, 6)
167#define LCD_LE_LEE BSP_BIT32(16)
168
177#define LCD_CTRL_LCDEN BSP_BIT32(0)
178#define LCD_CTRL_LCDBPP(val) BSP_FLD32(val, 1, 3)
179#define LCD_CTRL_LCDBPP_GET(reg) BSP_FLD32GET(reg, 1, 3)
180#define LCD_CTRL_LCDBW BSP_BIT32(4)
181#define LCD_CTRL_LCDTFT BSP_BIT32(5)
182#define LCD_CTRL_LCDMONO8 BSP_BIT32(6)
183#define LCD_CTRL_LCDDUAL BSP_BIT32(7)
184#define LCD_CTRL_BGR BSP_BIT32(8)
185#define LCD_CTRL_BEBO BSP_BIT32(9)
186#define LCD_CTRL_BEPO BSP_BIT32(10)
187#define LCD_CTRL_LCDPWR BSP_BIT32(11)
188#define LCD_CTRL_LCDVCOMP(val) BSP_FLD32(val, 12, 13)
189#define LCD_CTRL_LCDVCOMP_GET(reg) BSP_FLD32GET(reg, 12, 13)
190#define LCD_CTRL_WATERMARK BSP_BIT32(16)
191
200#define LCD_INT_FUF BSP_BIT32(1)
201#define LCD_INT_LNBU BSP_BIT32(2)
202#define LCD_INT_VCOMP BSP_BIT32(3)
203#define LCD_INT_BER BSP_BIT32(4)
204
213#define LCD_PAL_R(val) BSP_FLD16(val, 0, 4)
214#define LCD_PAL_G(val) BSP_FLD16(val, 5, 9)
215#define LCD_PAL_B(val) BSP_FLD16(val, 10, 14)
216#define LCD_PAL_I BSP_BIT16(15)
217
222#ifdef __cplusplus
223}
224#endif /* __cplusplus */
225
226#endif /* LIBBSP_ARM_SHARED_LPC_LCD_H */
This header file provides utility macros for BSPs.
Definition: lpc-lcd.h:56
Definition: lpc-lcd.h:70
