RTEMS 6.1
system_conf.h File Reference
System configuration. More...
#define FPGA_DEVICE_FAMILY   "ECP2M"
#define PLATFORM_NAME   "platform1"
#define USE_PLL   (0)
#define CPU_FREQUENCY   (75000000)
#define CPU_NAME   "LM32"
#define CPU_EBA   (0x04000000)
#define CPU_DIVIDE_ENABLED   (1)
#define CPU_SIGN_EXTEND_ENABLED   (1)
#define CPU_MULTIPLIER_ENABLED   (1)
#define CPU_SHIFT_ENABLED   (1)
#define CPU_DEBUG_ENABLED   (1)
#define CPU_HW_BREAKPOINTS_ENABLED   (0)
#define CPU_NUM_HW_BREAKPOINTS   (0)
#define CPU_NUM_WATCHPOINTS   (0)
#define CPU_ICACHE_ENABLED   (1)
#define CPU_ICACHE_SETS   (512)
#define CPU_ICACHE_ASSOC   (1)
#define CPU_ICACHE_BYTES_PER_LINE   (16)
#define CPU_DCACHE_ENABLED   (1)
#define CPU_DCACHE_SETS   (512)
#define CPU_DCACHE_ASSOC   (1)
#define CPU_DCACHE_BYTES_PER_LINE   (16)
#define CPU_DEBA   (0x0C000000)
#define CPU_CHARIO_IN   (1)
#define CPU_CHARIO_OUT   (1)
#define CPU_CHARIO_TYPE   "JTAG UART"
#define GPIO_NAME   "gpio"
#define GPIO_BASE_ADDRESS   (0x80004000)
#define GPIO_SIZE   (128)
#define GPIO_CHARIO_IN   (0)
#define GPIO_CHARIO_OUT   (0)
#define GPIO_ADDRESS_LOCK   (1)
#define GPIO_DISABLE   (0)
#define GPIO_OUTPUT_PORTS_ONLY   (1)
#define GPIO_INPUT_PORTS_ONLY   (0)
#define GPIO_TRISTATE_PORTS   (0)
#define GPIO_BOTH_INPUT_AND_OUTPUT   (0)
#define GPIO_DATA_WIDTH   (4)
#define GPIO_INPUT_WIDTH   (1)
#define GPIO_OUTPUT_WIDTH   (1)
#define GPIO_IRQ_MODE   (0)
#define GPIO_LEVEL   (0)
#define GPIO_EDGE   (0)
#define GPIO_EITHER_EDGE_IRQ   (0)
#define GPIO_POSE_EDGE_IRQ   (0)
#define GPIO_NEGE_EDGE_IRQ   (0)
#define UART_NAME   "uart"
#define UART_BASE_ADDRESS   (0x80006000)
#define UART_SIZE   (128)
#define UART_IRQ   (0)
#define UART_CHARIO_IN   (1)
#define UART_CHARIO_OUT   (1)
#define UART_CHARIO_TYPE   "RS-232"
#define UART_ADDRESS_LOCK   (1)
#define UART_DISABLE   (0)
#define UART_MODEM   (0)
#define UART_ADDRWIDTH   (5)
#define UART_DATAWIDTH   (8)
#define UART_BAUD_RATE   (115200)
#define UART_IB_SIZE   (4)
#define UART_OB_SIZE   (4)
#define UART_BLOCK_WRITE   (1)
#define UART_BLOCK_READ   (1)
#define UART_DATA_BITS   (8)
#define UART_STOP_BITS   (1)
#define UART_FIFO   (0)
#define UART_INTERRUPT_DRIVEN   (1)
#define EBR_NAME   "ebr"
#define EBR_BASE_ADDRESS   (0x04000000)
#define EBR_SIZE   (32768)
#define EBR_IS_READABLE   (1)
#define EBR_IS_WRITABLE   (1)
#define EBR_ADDRESS_LOCK   (1)
#define EBR_DISABLE   (0)
#define EBR_EBR_DATA_WIDTH   (32)
#define EBR_INIT_FILE_NAME   "none"
#define EBR_INIT_FILE_FORMAT   "hex"
#define TS_MAC_CORE_NAME   "ts_mac_core"
#define TS_MAC_CORE_BASE_ADDRESS   (0x80008000)
#define TS_MAC_CORE_SIZE   (8192)
#define TS_MAC_CORE_IRQ   (2)
#define TS_MAC_CORE_CHARIO_IN   (0)
#define TS_MAC_CORE_CHARIO_OUT   (0)
#define TS_MAC_CORE_ADDRESS_LOCK   (1)
#define TS_MAC_CORE_DISABLE   (0)
#define TS_MAC_CORE_STAT_REGS   (1)
#define TS_MAC_CORE_TXRX_FIFO_DEPTH   (512)
#define TS_MAC_CORE_MIIM_MODULE   (1)
#define TS_MAC_CORE_NGO   "l:/mrf/lattice/crio-lm32/platform1/components/ts_mac_top_v27/ipexpress/ts_mac_core/ts_mac_core.ngo"
#define TS_MAC_CORE_ISPLEVER_PRJ   "l:/mrf/lattice/crio-lm32/criomico.syn"
#define TIMER0_NAME   "timer0"
#define TIMER0_BASE_ADDRESS   (0x80002000)
#define TIMER0_SIZE   (128)
#define TIMER0_IRQ   (1)
#define TIMER0_CHARIO_IN   (0)
#define TIMER0_CHARIO_OUT   (0)
#define TIMER0_ADDRESS_LOCK   (1)
#define TIMER0_DISABLE   (0)
#define TIMER0_PERIOD_NUM   (20)
#define TIMER0_PERIOD_WIDTH   (32)
#define TIMER0_WRITEABLE_PERIOD   (1)
#define TIMER0_READABLE_SNAPSHOT   (1)
#define TIMER0_START_STOP_CONTROL   (1)
#define TIMER0_WATCHDOG   (0)
#define TIMER1_NAME   "timer1"
#define TIMER1_BASE_ADDRESS   (0x8000A000)
#define TIMER1_SIZE   (128)
#define TIMER1_IRQ   (3)
#define TIMER1_CHARIO_IN   (0)
#define TIMER1_CHARIO_OUT   (0)
#define TIMER1_ADDRESS_LOCK   (1)
#define TIMER1_DISABLE   (0)
#define TIMER1_PERIOD_NUM   (20)
#define TIMER1_PERIOD_WIDTH   (32)
#define TIMER1_WRITEABLE_PERIOD   (1)
#define TIMER1_READABLE_SNAPSHOT   (1)
#define TIMER1_START_STOP_CONTROL   (1)
#define TIMER1_WATCHDOG   (0)
#define DDR2_SDRAM_NAME   "ddr2_sdram"
#define DDR2_SDRAM_BASE_ADDRESS   (0x08000000)
#define DDR2_SDRAM_SIZE   (33554432)
#define DDR2_SDRAM_IS_READABLE   (1)
#define DDR2_SDRAM_IS_WRITABLE   (1)
#define DDR2_SDRAM_BST_CNT_READ   (1)
#define DDR2_SDRAM_ADDRESS_LOCK   (1)
#define DDR2_SDRAM_DISABLE   (0)
#define DDR2_SDRAM_NGO   "L:/mrf/lattice/cRIO-LM32/platform1/components/wb_ddr2_ctl_v65/ipexpress/ddr2_sdram/ddr2_sdram.ngo"
#define DDR2_SDRAM_ISPLEVER_PRJ   "l:/mrf/lattice/crio-lm32/criomico.syn"
#define DDR2_SDRAM_PARAM_FILE   "ddr_p_eval/$/src/params/ddr_sdram_mem_params.v"
#define DDR2_SDRAM_MEM_TOP   "ddr_p_eval/$/src/rtl/top/@/ddr_sdram_mem_top.v"
