RTEMS 6.1
gdb_if.h
1
7/*
8 * gdb_if.h - definition of the interface between the stub and gdb
9 *
10 * THIS SOFTWARE IS NOT COPYRIGHTED
11 *
12 * The following software is offered for use in the public domain.
13 * There is no warranty with regard to this software or its performance
14 * and the user must accept the software "AS IS" with all faults.
15 *
16 * THE CONTRIBUTORS DISCLAIM ANY WARRANTIES, EXPRESS OR IMPLIED, WITH
17 * REGARD TO THIS SOFTWARE INCLUDING BUT NOT LIMITED TO THE WARRANTIES
18 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
19 */
20
28#ifndef _GDB_IF_H
29#define _GDB_IF_H
30
32#define QM_MAX_THREADS (20)
33
35 char display[256];
36 char name[256];
37 char more_display[256];
38};
39
40/*
41 * Prototypes
42 */
43
44int parse_zbreak(const char *in, int *type, unsigned char **addr, int *len);
45
46char* mem2hstr(char *buf, const unsigned char *mem, int count);
47int hstr2mem(unsigned char *mem, const char *buf, int count);
48void set_mem_err(void);
49unsigned char get_byte(const unsigned char *ptr);
50void set_byte(unsigned char *ptr, int val);
51char* thread2vhstr(char *buf, int thread);
52char* thread2fhstr(char *buf, int thread);
53const char* fhstr2thread(const char *buf, int *thread);
54const char* vhstr2thread(const char *buf, int *thread);
55char* int2fhstr(char *buf, int val);
56char* int2vhstr(char *buf, int vali);
57const char* fhstr2int(const char *buf, int *ival);
58const char* vhstr2int(const char *buf, int *ival);
59int hstr2byte(const char *buf, int *bval);
60int hstr2nibble(const char *buf, int *nibble);
61
62Thread_Control *rtems_gdb_index_to_stub_id(int);
63int rtems_gdb_stub_thread_support_ok(void);
64int rtems_gdb_stub_get_current_thread(void);
65int rtems_gdb_stub_get_next_thread(int);
66int rtems_gdb_stub_get_offsets(
67 unsigned char **text_addr,
68 unsigned char **data_addr,
69 unsigned char **bss_addr
70);
71int rtems_gdb_stub_get_thread_regs(
72 int thread,
73 unsigned int *registers
74);
75int rtems_gdb_stub_set_thread_regs(
76 int thread,
77 unsigned int *registers
78);
79void rtems_gdb_process_query(
80 char *inbuffer,
81 char *outbuffer,
82 int do_threads,
83 int thread
84);
85
87#define LM32_EXCEPTION_RESET 0x0
88#define LM32_EXCEPTION_INST_BREAKPOINT 0x1
89#define LM32_EXCEPTION_INST_BUS_ERROR 0x2
90#define LM32_EXCEPTION_DATA_BREAKPOINT 0x3
91#define LM32_EXCEPTION_DATA_BUS_ERROR 0x4
92#define LM32_EXCEPTION_DIVIDE_BY_ZERO 0x5
93#define LM32_EXCEPTION_INTERRUPT 0x6
94#define LM32_EXCEPTION_SYSTEM_CALL 0x7
95
97#define LM32_BREAK 0xac000002UL
98
101 LM32_REG_R0, LM32_REG_R1, LM32_REG_R2, LM32_REG_R3, LM32_REG_R4, LM32_REG_R5,
102 LM32_REG_R6, LM32_REG_R7, LM32_REG_R8, LM32_REG_R9, LM32_REG_R10,
103 LM32_REG_R11, LM32_REG_R12, LM32_REG_R13, LM32_REG_R14, LM32_REG_R15,
104 LM32_REG_R16, LM32_REG_R17, LM32_REG_R18, LM32_REG_R19, LM32_REG_R20,
105 LM32_REG_R21, LM32_REG_R22, LM32_REG_R23, LM32_REG_R24, LM32_REG_R25,
106 LM32_REG_GP, LM32_REG_FP, LM32_REG_SP, LM32_REG_RA, LM32_REG_EA, LM32_REG_BA,
107 LM32_REG_PC, LM32_REG_EID, LM32_REG_EBA, LM32_REG_DEBA, LM32_REG_IE, NUM_REGS
108};
109
110/* keep this in sync with the debug isr handler in lm32-debug.S */
111enum lm32_int_regnames {
112 LM32_INT_REG_R1, LM32_INT_REG_R2, LM32_INT_REG_R3, LM32_INT_REG_R4,
113 LM32_INT_REG_R5, LM32_INT_REG_R6, LM32_INT_REG_R7, LM32_INT_REG_R8,
114 LM32_INT_REG_R9, LM32_INT_REG_R10, LM32_INT_REG_RA, LM32_INT_REG_EA,
115 LM32_INT_REG_BA, LM32_INT_REG_R11, LM32_INT_REG_R12, LM32_INT_REG_R13,
116 LM32_INT_REG_R14, LM32_INT_REG_R15, LM32_INT_REG_R16, LM32_INT_REG_R17,
117 LM32_INT_REG_R18, LM32_INT_REG_R19, LM32_INT_REG_R20, LM32_INT_REG_R21,
118 LM32_INT_REG_R22, LM32_INT_REG_R23, LM32_INT_REG_R24, LM32_INT_REG_R25,
119 LM32_INT_REG_GP, LM32_INT_REG_FP, LM32_INT_REG_SP, LM32_INT_REG_PC,
120 LM32_INT_REG_EID, LM32_INT_REG_EBA, LM32_INT_REG_DEBA, LM32_INT_REG_IE,
121};
122
123#endif /* _GDB_IF_H */
124
lm32_regnames
This numbering must be consistant with GDBs numbering in gdb/lm32-tdep.c.
Definition: gdb_if.h:100
Definition: thread.h:837
Definition: gdb_if.h:34
