RTEMS 6.1
Standard C Library Support. More...
#include <sys/types.h>#include <stdint.h>#include <rtems/score/heap.h>#include <rtems/rtems/tasks.h>Go to the source code of this file.
| struct | rtems_resource_rtems_api |
| struct | rtems_resource_posix_api |
| struct | rtems_resource_snapshot |
| #define | _NEWLIB_CREATE_HOOK newlib_create_hook |
| #define | RTEMS_NEWLIB_EXTENSION |
| void | malloc_dump (void) |
| bool | malloc_walk (int source, bool printf_enabled) |
| Malloc walk. | |
| void | malloc_set_heap_pointer (Heap_Control *new_heap) |
| Set malloc heap pointer. | |
| Heap_Control * | malloc_get_heap_pointer (void) |
| Get malloc heap pointer. | |
| size_t | malloc_free_space (void) |
| Get free malloc information. | |
| int | malloc_info (Heap_Information_block *the_info) |
| Get malloc status information. | |
| bool | newlib_create_hook (rtems_tcb *current_task, rtems_tcb *creating_task) |
| void | newlib_terminate_hook (rtems_tcb *current_task) |
| void | rtems_resource_snapshot_take (rtems_resource_snapshot *snapshot) |
| Tasks a snapshot of the resource usage of the system. | |
| bool | rtems_resource_snapshot_equal (const rtems_resource_snapshot *a, const rtems_resource_snapshot *b) |
| Compares two resource snapshots for equality. | |
| bool | rtems_resource_snapshot_check (const rtems_resource_snapshot *snapshot) |
| Takes a new resource snapshot and checks that it is equal to the given resource snapshot. | |
This include file contains the information regarding the RTEMS specific support for the standard C library.
