RTEMS 6.1
legacy-console.h
2
11/*
12 * COPYRIGHT (c) 1989-2011, 2016.
13 * On-Line Applications Research Corporation (OAR).
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _PC386_CONSOLE_PRIVATE_h
38#define _PC386_CONSOLE_PRIVATE_h
39
40#include <rtems.h>
41
42#include <libchip/serial.h>
43
44#ifdef __cplusplus
45extern "C" {
46#endif
47
48extern rtems_device_minor_number BSPPrintkPort;
49
57int vt_ioctl(
58 unsigned int cmd,
59 unsigned long arg
60);
61
70 const char *match,
71 size_t length,
72 rtems_device_minor_number *match_minor
73);
74
84
97 console_tbl *new_ports,
98 size_t number_of_ports
99);
100
101#ifdef __cplusplus
102}
103#endif
104
107#endif
108/* end of include file */
uint32_t rtems_device_minor_number
This integer type represents the minor number of devices.
Definition: io.h:115
int vt_ioctl(unsigned int cmd, unsigned long arg)
This function is the ioctl() support for a VGA buffer driver.
Definition: vt.c:181
void console_initialize_data(void)
Definition: legacy-console.c:101
void console_register_devices(console_tbl *new_ports, size_t number_of_ports)
Definition: legacy-console.c:138
console_tbl * console_find_console_entry(const char *match, size_t length, rtems_device_minor_number *match_minor)
Definition: legacy-console.c:62
The generic libchip serial driver interface.
Definition: serial.h:136
