RTEMS 6.1
jffs2_qspi.h
2
11/*
12 * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_MICROBLAZE_FPGA_JFFS2_QSPI_H
37#define LIBBSP_MICROBLAZE_FPGA_JFFS2_QSPI_H
38
39#ifdef __cplusplus
40extern "C" {
41#endif /* __cplusplus */
42
50int microblaze_jffs2_initialize( const char* mount_dir );
51
52#ifdef __cplusplus
53}
54#endif /* __cplusplus */
55
56#endif /* LIBBSP_MICROBLAZE_FPGA_JFFS2_QSPI_H */
int microblaze_jffs2_initialize(const char *mount_dir)
Mount jffs2 filesystem.
Definition: jffs2_qspi.c:285
