RTEMS 6.1
Data Structures | Macros | Typedefs
irqamp-regs.h File Reference
This header file defines the IRQAMP register block interface. More...
#include <stdint.h>
struct  irqamp_timestamp
 This structure defines the IRQ(A)MP Timestamp register block memory map. More...
struct  irqamp
 This structure defines the IRQ(A)MP register block memory map. More...
#define IRQAMP_ITCNT_TCNT_SHIFT   0
#define IRQAMP_ITCNT_TCNT_MASK   0xffffffffU
#define IRQAMP_ITCNT_TCNT_GET(_reg)
#define IRQAMP_ITCNT_TCNT_SET(_reg, _val)
#define IRQAMP_ITCNT_TCNT(_val)
#define IRQAMP_ITSTMPC_TSTAMP_SHIFT   27
#define IRQAMP_ITSTMPC_TSTAMP_MASK   0xf8000000U
#define IRQAMP_ITSTMPC_TSTAMP_GET(_reg)
#define IRQAMP_ITSTMPC_TSTAMP_SET(_reg, _val)
#define IRQAMP_ITSTMPC_TSTAMP(_val)
#define IRQAMP_ITSTMPC_S1   0x4000000U
#define IRQAMP_ITSTMPC_S2   0x2000000U
#define IRQAMP_ITSTMPC_KS   0x20U
#define IRQAMP_ITSTMPC_TSISEL_SHIFT   0
#define IRQAMP_ITSTMPC_TSISEL_MASK   0x1fU
#define IRQAMP_ITSTMPC_TSISEL_GET(_reg)
#define IRQAMP_ITSTMPC_TSISEL_SET(_reg, _val)
#define IRQAMP_ITSTMPC_TSISEL(_val)
#define IRQAMP_ITSTMPAS_TASSERTION_SHIFT   0
#define IRQAMP_ITSTMPAS_TASSERTION_MASK   0xffffffffU
#define IRQAMP_ITSTMPAS_TASSERTION_GET(_reg)
#define IRQAMP_ITSTMPAS_TASSERTION_SET(_reg, _val)
#define IRQAMP_ITSTMPAS_TASSERTION(_val)
#define IRQAMP_ITSTMPAC_TACKNOWLEDGE_SHIFT   0
#define IRQAMP_ITSTMPAC_TACKNOWLEDGE_MASK   0xffffffffU
#define IRQAMP_ITSTMPAC_TACKNOWLEDGE_GET(_reg)
#define IRQAMP_ITSTMPAC_TACKNOWLEDGE_SET(_reg, _val)
#define IRQAMP_ITSTMPAC_TACKNOWLEDGE(_val)
#define IRQAMP_ILEVEL_IL_15_1_SHIFT   1
#define IRQAMP_ILEVEL_IL_15_1_MASK   0xfffeU
#define IRQAMP_ILEVEL_IL_15_1_GET(_reg)
#define IRQAMP_ILEVEL_IL_15_1_SET(_reg, _val)
#define IRQAMP_ILEVEL_IL_15_1(_val)
#define IRQAMP_IPEND_EIP_31_16_SHIFT   16
#define IRQAMP_IPEND_EIP_31_16_MASK   0xffff0000U
#define IRQAMP_IPEND_EIP_31_16_GET(_reg)
#define IRQAMP_IPEND_EIP_31_16_SET(_reg, _val)
#define IRQAMP_IPEND_EIP_31_16(_val)
#define IRQAMP_IPEND_IP_15_1_SHIFT   1
#define IRQAMP_IPEND_IP_15_1_MASK   0xfffeU
#define IRQAMP_IPEND_IP_15_1_GET(_reg)
#define IRQAMP_IPEND_IP_15_1_SET(_reg, _val)
#define IRQAMP_IPEND_IP_15_1(_val)
#define IRQAMP_IFORCE0_IF_15_1_SHIFT   1
#define IRQAMP_IFORCE0_IF_15_1_MASK   0xfffeU
#define IRQAMP_IFORCE0_IF_15_1_GET(_reg)
#define IRQAMP_IFORCE0_IF_15_1_SET(_reg, _val)
#define IRQAMP_IFORCE0_IF_15_1(_val)
#define IRQAMP_ICLEAR_EIC_31_16_SHIFT   16
#define IRQAMP_ICLEAR_EIC_31_16_MASK   0xffff0000U
#define IRQAMP_ICLEAR_EIC_31_16_GET(_reg)
#define IRQAMP_ICLEAR_EIC_31_16_SET(_reg, _val)
#define IRQAMP_ICLEAR_EIC_31_16(_val)
#define IRQAMP_ICLEAR_IC_15_1_SHIFT   1
#define IRQAMP_ICLEAR_IC_15_1_MASK   0xfffeU
#define IRQAMP_ICLEAR_IC_15_1_GET(_reg)
#define IRQAMP_ICLEAR_IC_15_1_SET(_reg, _val)
#define IRQAMP_ICLEAR_IC_15_1(_val)
#define IRQAMP_MPSTAT_NCPU_SHIFT   28
#define IRQAMP_MPSTAT_NCPU_MASK   0xf0000000U
#define IRQAMP_MPSTAT_NCPU_GET(_reg)
#define IRQAMP_MPSTAT_NCPU_SET(_reg, _val)
#define IRQAMP_MPSTAT_NCPU(_val)
#define IRQAMP_MPSTAT_BA   0x8000000U
#define IRQAMP_MPSTAT_ER   0x4000000U
#define IRQAMP_MPSTAT_EIRQ_SHIFT   16
#define IRQAMP_MPSTAT_EIRQ_MASK   0xf0000U
#define IRQAMP_MPSTAT_EIRQ_GET(_reg)
#define IRQAMP_MPSTAT_EIRQ_SET(_reg, _val)
#define IRQAMP_MPSTAT_EIRQ(_val)
#define IRQAMP_MPSTAT_STATUS_SHIFT   0
#define IRQAMP_MPSTAT_STATUS_MASK   0xfU
#define IRQAMP_MPSTAT_STATUS_GET(_reg)
#define IRQAMP_MPSTAT_STATUS_SET(_reg, _val)
#define IRQAMP_MPSTAT_STATUS(_val)
#define IRQAMP_BRDCST_BM15_1_SHIFT   1
#define IRQAMP_BRDCST_BM15_1_MASK   0xfffeU
#define IRQAMP_BRDCST_BM15_1_GET(_reg)
#define IRQAMP_BRDCST_BM15_1_SET(_reg, _val)
#define IRQAMP_BRDCST_BM15_1(_val)
#define IRQAMP_ERRSTAT_ERRMODE_3_0_SHIFT   0
#define IRQAMP_ERRSTAT_ERRMODE_3_0_MASK   0xfU
#define IRQAMP_ERRSTAT_ERRMODE_3_0_GET(_reg)
#define IRQAMP_ERRSTAT_ERRMODE_3_0_SET(_reg, _val)
#define IRQAMP_ERRSTAT_ERRMODE_3_0(_val)
#define IRQAMP_WDOGCTRL_NWDOG_SHIFT   27
#define IRQAMP_WDOGCTRL_NWDOG_MASK   0xf8000000U
#define IRQAMP_WDOGCTRL_NWDOG_GET(_reg)
#define IRQAMP_WDOGCTRL_NWDOG_SET(_reg, _val)
#define IRQAMP_WDOGCTRL_NWDOG(_val)
#define IRQAMP_WDOGCTRL_WDOGIRQ_SHIFT   16
#define IRQAMP_WDOGCTRL_WDOGIRQ_MASK   0xf0000U
#define IRQAMP_WDOGCTRL_WDOGIRQ_GET(_reg)
#define IRQAMP_WDOGCTRL_WDOGIRQ_SET(_reg, _val)
#define IRQAMP_WDOGCTRL_WDOGIRQ(_val)
#define IRQAMP_WDOGCTRL_WDOGMSK_SHIFT   0
#define IRQAMP_WDOGCTRL_WDOGMSK_MASK   0xfU
#define IRQAMP_WDOGCTRL_WDOGMSK_GET(_reg)
#define IRQAMP_WDOGCTRL_WDOGMSK_SET(_reg, _val)
#define IRQAMP_WDOGCTRL_WDOGMSK(_val)
#define IRQAMP_ASMPCTRL_NCTRL_SHIFT   28
#define IRQAMP_ASMPCTRL_NCTRL_MASK   0xf0000000U
#define IRQAMP_ASMPCTRL_NCTRL_GET(_reg)
#define IRQAMP_ASMPCTRL_NCTRL_SET(_reg, _val)
#define IRQAMP_ASMPCTRL_NCTRL(_val)
#define IRQAMP_ASMPCTRL_ICF   0x2U
#define IRQAMP_ASMPCTRL_L   0x1U
#define IRQAMP_ICSELR_ICSEL0_SHIFT   28
#define IRQAMP_ICSELR_ICSEL0_MASK   0xf0000000U
#define IRQAMP_ICSELR_ICSEL0_GET(_reg)
#define IRQAMP_ICSELR_ICSEL0_SET(_reg, _val)
#define IRQAMP_ICSELR_ICSEL0(_val)
#define IRQAMP_ICSELR_ICSEL1_SHIFT   24
#define IRQAMP_ICSELR_ICSEL1_MASK   0xf000000U
#define IRQAMP_ICSELR_ICSEL1_GET(_reg)
#define IRQAMP_ICSELR_ICSEL1_SET(_reg, _val)
#define IRQAMP_ICSELR_ICSEL1(_val)
#define IRQAMP_ICSELR_ICSEL2_SHIFT   20
#define IRQAMP_ICSELR_ICSEL2_MASK   0xf00000U
#define IRQAMP_ICSELR_ICSEL2_GET(_reg)
#define IRQAMP_ICSELR_ICSEL2_SET(_reg, _val)
#define IRQAMP_ICSELR_ICSEL2(_val)
#define IRQAMP_ICSELR_ICSEL3_SHIFT   16
#define IRQAMP_ICSELR_ICSEL3_MASK   0xf0000U
#define IRQAMP_ICSELR_ICSEL3_GET(_reg)
#define IRQAMP_ICSELR_ICSEL3_SET(_reg, _val)
#define IRQAMP_ICSELR_ICSEL3(_val)
#define IRQAMP_PIMASK_EIM_31_16_SHIFT   16
#define IRQAMP_PIMASK_EIM_31_16_MASK   0xffff0000U
#define IRQAMP_PIMASK_EIM_31_16_GET(_reg)
#define IRQAMP_PIMASK_EIM_31_16_SET(_reg, _val)
#define IRQAMP_PIMASK_EIM_31_16(_val)
#define IRQAMP_PIMASK_IM15_1_SHIFT   1
#define IRQAMP_PIMASK_IM15_1_MASK   0xfffeU
#define IRQAMP_PIMASK_IM15_1_GET(_reg)
#define IRQAMP_PIMASK_IM15_1_SET(_reg, _val)
#define IRQAMP_PIMASK_IM15_1(_val)
#define IRQAMP_PIFORCE_FC_15_1_SHIFT   17
#define IRQAMP_PIFORCE_FC_15_1_MASK   0xfffe0000U
#define IRQAMP_PIFORCE_FC_15_1_GET(_reg)
#define IRQAMP_PIFORCE_FC_15_1_SET(_reg, _val)
#define IRQAMP_PIFORCE_FC_15_1(_val)
#define IRQAMP_PIFORCE_IF15_1_SHIFT   1
#define IRQAMP_PIFORCE_IF15_1_MASK   0xfffeU
#define IRQAMP_PIFORCE_IF15_1_GET(_reg)
#define IRQAMP_PIFORCE_IF15_1_SET(_reg, _val)
#define IRQAMP_PIFORCE_IF15_1(_val)
#define IRQAMP_PEXTACK_EID_4_0_SHIFT   0
#define IRQAMP_PEXTACK_EID_4_0_MASK   0x1fU
#define IRQAMP_PEXTACK_EID_4_0_GET(_reg)
#define IRQAMP_PEXTACK_EID_4_0_SET(_reg, _val)
#define IRQAMP_PEXTACK_EID_4_0(_val)
#define IRQAMP_BADDR_BOOTADDR_31_3_SHIFT   3
#define IRQAMP_BADDR_BOOTADDR_31_3_MASK   0xfffffff8U
#define IRQAMP_BADDR_BOOTADDR_31_3_GET(_reg)
#define IRQAMP_BADDR_BOOTADDR_31_3_SET(_reg, _val)
#define IRQAMP_BADDR_BOOTADDR_31_3(_val)
#define IRQAMP_BADDR_AS   0x1U
#define IRQAMP_IRQMAP_IRQMAP_4_N_0_SHIFT   24
#define IRQAMP_IRQMAP_IRQMAP_4_N_0_MASK   0xff000000U
#define IRQAMP_IRQMAP_IRQMAP_4_N_0_GET(_reg)
#define IRQAMP_IRQMAP_IRQMAP_4_N_0_SET(_reg, _val)
#define IRQAMP_IRQMAP_IRQMAP_4_N_0(_val)
#define IRQAMP_IRQMAP_IRQMAP_4_N_1_SHIFT   16
#define IRQAMP_IRQMAP_IRQMAP_4_N_1_MASK   0xff0000U
#define IRQAMP_IRQMAP_IRQMAP_4_N_1_GET(_reg)
#define IRQAMP_IRQMAP_IRQMAP_4_N_1_SET(_reg, _val)
#define IRQAMP_IRQMAP_IRQMAP_4_N_1(_val)
#define IRQAMP_IRQMAP_IRQMAP_4_N_2_SHIFT   8
#define IRQAMP_IRQMAP_IRQMAP_4_N_2_MASK   0xff00U
#define IRQAMP_IRQMAP_IRQMAP_4_N_2_GET(_reg)
#define IRQAMP_IRQMAP_IRQMAP_4_N_2_SET(_reg, _val)
#define IRQAMP_IRQMAP_IRQMAP_4_N_2(_val)
#define IRQAMP_IRQMAP_IRQMAP_4_N_3_SHIFT   0
#define IRQAMP_IRQMAP_IRQMAP_4_N_3_MASK   0xffU
#define IRQAMP_IRQMAP_IRQMAP_4_N_3_GET(_reg)
#define IRQAMP_IRQMAP_IRQMAP_4_N_3_SET(_reg, _val)
#define IRQAMP_IRQMAP_IRQMAP_4_N_3(_val)
typedef struct irqamp_timestamp irqamp_timestamp
typedef struct irqamp irqamp
