RTEMS 6.1
irq-enable-disable.c File Reference
This source file contains the implementation of rtems_interrupt_get_attributes(), rtems_interrupt_vector_is_enabled(), rtems_interrupt_vector_enable() and rtems_interrupt_vector_disable(). More...
#include <bsp/irq-generic.h>
rtems_status_code rtems_interrupt_get_attributes (rtems_vector_number vector, rtems_interrupt_attributes *attributes)
 Gets the attributes of the interrupt vector.
rtems_status_code rtems_interrupt_vector_is_enabled (rtems_vector_number vector, bool *enabled)
 Checks if the interrupt vector is enabled.
rtems_status_code rtems_interrupt_vector_enable (rtems_vector_number vector)
 Enables the interrupt vector.
rtems_status_code rtems_interrupt_vector_disable (rtems_vector_number vector)
 Disables the interrupt vector.
