RTEMS 6.1
io_types.h
1/************************************************************************
2 *
3 * Data types and constants for Hitachi SH704X on-chip peripherals
4 *
5 * Author: John M.Mills (jmills@tga.com)
6 *
7 * COPYRIGHT (c) 1999, TGA Technologies, Norcross, GA, USA
8 *
9 * This program is distributed in the hope that it will be useful,
10 * but WITHOUT ANY WARRANTY; without even the implied warranty of
11 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
12 *
13 * This file may be distributed as part of the RTEMS software item.
14 *
15 * The license and distribution terms for this file may be
16 * found in the file LICENSE in this distribution or at
17 * http://www.rtems.org/license/LICENSE.
18 *
19 * John M. Mills (jmills@tga.com)
20 * TGA Technologies, Inc.
21 * 100 Pinnacle Way, Suite 140
22 * Norcross, GA 30071 U.S.A.
23 *
24 * This modified file may be copied and distributed in accordance
25 * the above-referenced license. It is provided for critique and
26 * developmental purposes without any warranty nor representation
27 * by the authors or by TGA Technologies.
28 *
29 *
30 ************************************************************************/
31
32#ifndef _sh_io_types_h
33#define _sh_io_types_h
34
35#include <rtems/score/iosh7045.h>
36#include <termios.h>
37
38typedef enum {SCI0, SCI1} portNo;
39typedef enum {eight, seven} dataBits;
40typedef enum {one, two} stopBits;
41typedef enum {even, odd} parity;
42
43typedef struct {
44 portNo line;
45 int speed_ix;
46 dataBits dBits;
47 int parEn;
48 parity par;
49 int mulPro;
50 stopBits sBits;
52
53typedef union{
54 unsigned char Reg; /* By Register */
55 struct { /* By Field */
56 unsigned char Sync :1; /* Async/Sync */
57 unsigned char DBts :1; /* Char.Length */
58 unsigned char ParEn :1; /* Parity En.*/
59 unsigned char Odd :1; /* Even/Odd */
60 unsigned char SBts :1; /* No.Stop Bits */
61 unsigned char MulP :1; /* Multi-Proc. */
62 unsigned char Dvsr :2; /* Clock Sel. */
63 } Fld;
64} sci_smr_t;
65
66typedef union {
67 unsigned char Reg; /* By Register */
68 struct { /* By Field */
69 unsigned char TIE :1; /* Tx.Int.En. */
70 unsigned char RIE :1; /* Rx.Int.En. */
71 unsigned char TE :1; /* Tx.En. */
72 unsigned char RE :1; /* Rx.En. */
73 unsigned char MPIE:1; /* Mult.Pro.Int.En. */
74 unsigned char TEIE:1; /* Tx.End Int.En. */
75 unsigned char CkSrc :2; /* Clock Src. */
76 } Fld;
77} sci_scr_t;
78
79typedef struct {
80 unsigned char n ;
81 unsigned char N ;
83
84#endif /* _sh_io_types_h */
Definition: io_types.h:79
Definition: io_types.h:43
Definition: io_types.h:66
Definition: io_types.h:53
