RTEMS 6.1
version.h
2
11/*
12 * Copyright (C) 2017.
13 * Chris Johns <chrisj@rtems.org>
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _RTEMS_VERSION_H
38#define _RTEMS_VERSION_H
39
40#include <stdbool.h>
41
42#ifdef __cplusplus
43extern "C" {
44#endif
45
83const char *rtems_version( void );
84
90int rtems_version_major( void );
91
97int rtems_version_minor( void );
98
104int rtems_version_revision( void );
105
120const char *rtems_version_control_key( void );
121
130static inline bool rtems_version_control_key_is_valid( const char *key )
131{
132 return key[ 0 ] != '\0';
133}
134
147const char *rtems_version_release_label( void );
148
156
162const char *rtems_board_support_package( void );
163
166#ifdef __cplusplus
167}
168#endif
169
170#endif
171/* end of include file */
int rtems_version_major(void)
Returns the version's major number.
Definition: version.c:65
const char * rtems_version(void)
Returns the version string.
Definition: version.c:56
bool rtems_version_release_label_is_valid(void)
Returns true, if the release label is valid, otherwise false.
Definition: version.c:102
int rtems_version_revision(void)
Returns the version's revision number.
Definition: version.c:75
const char * rtems_version_control_key(void)
Returns the version control key for the current version of code that has been built.
Definition: version.c:80
const char * rtems_board_support_package(void)
Returns the board support package name.
Definition: rtems-version.c:42
int rtems_version_minor(void)
Returns the version's minor number.
Definition: version.c:70
const char * rtems_version_release_label(void)
Returns the revision label for the current version of code that has been built.
Definition: version.c:89
