RTEMS 6.1
atomic.h
2
12/*
13 * Copyright (C) 2015, 2024 embedded brains GmbH & Co. KG
14 * COPYRIGHT (c) 2012-2013 Deng Hengyi.
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38#ifndef _RTEMS_SCORE_ATOMIC_H
39#define _RTEMS_SCORE_ATOMIC_H
40
42
58#ifdef RTEMS_SMP
59 #if defined(__cplusplus) \
60 && (__GNUC__ > 4 || (__GNUC__ == 4 && __GNUC_MINOR__ >= 9))
61 /*
62 * The GCC 4.9 ships its own <stdatomic.h> which is not C++ compatible. The
63 * suggested solution was to include <atomic> in case C++ is used. This works
64 * at least with GCC 4.9. See also:
65 *
66 * http://gcc.gnu.org/bugzilla/show_bug.cgi?id=60932
67 * http://gcc.gnu.org/bugzilla/show_bug.cgi?id=60940
68 */
69 #include <atomic>
70 #define _RTEMS_SCORE_ATOMIC_USE_ATOMIC
71 #else
72 #include <stdatomic.h>
73 #define _RTEMS_SCORE_ATOMIC_USE_STDATOMIC
74 #endif
75#else
76 #include <rtems/score/isrlevel.h>
77#endif
78
79#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
80
81typedef unsigned int Atomic_Uint;
82
83typedef unsigned long Atomic_Ulong;
84
85typedef uintptr_t Atomic_Uintptr;
86
87typedef std::atomic_flag Atomic_Flag;
88
89typedef std::memory_order Atomic_Order;
90
91#define ATOMIC_ORDER_RELAXED std::memory_order_relaxed
92
93#define ATOMIC_ORDER_ACQUIRE std::memory_order_acquire
94
95#define ATOMIC_ORDER_RELEASE std::memory_order_release
96
97#define ATOMIC_ORDER_ACQ_REL std::memory_order_acq_rel
98
99#define ATOMIC_ORDER_SEQ_CST std::memory_order_seq_cst
100
101#define ATOMIC_INITIALIZER_UINT( value ) ATOMIC_VAR_INIT( value )
102
103#define ATOMIC_INITIALIZER_ULONG( value ) ATOMIC_VAR_INIT( value )
104
105#define ATOMIC_INITIALIZER_UINTPTR( value ) ATOMIC_VAR_INIT( value )
106
107#define ATOMIC_INITIALIZER_FLAG ATOMIC_FLAG_INIT
108
109#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
110
111typedef atomic_uint Atomic_Uint;
112
113typedef atomic_ulong Atomic_Ulong;
114
115typedef atomic_uintptr_t Atomic_Uintptr;
116
117typedef atomic_flag Atomic_Flag;
118
119typedef memory_order Atomic_Order;
120
121#define ATOMIC_ORDER_RELAXED memory_order_relaxed
122
123#define ATOMIC_ORDER_ACQUIRE memory_order_acquire
124
125#define ATOMIC_ORDER_RELEASE memory_order_release
126
127#define ATOMIC_ORDER_ACQ_REL memory_order_acq_rel
128
129#define ATOMIC_ORDER_SEQ_CST memory_order_seq_cst
130
131#define ATOMIC_INITIALIZER_UINT( value ) ATOMIC_VAR_INIT( value )
132
133#define ATOMIC_INITIALIZER_ULONG( value ) ATOMIC_VAR_INIT( value )
134
135#define ATOMIC_INITIALIZER_UINTPTR( value ) ATOMIC_VAR_INIT( value )
136
137#define ATOMIC_INITIALIZER_FLAG ATOMIC_FLAG_INIT
138
139#else
140
141typedef unsigned int Atomic_Uint;
142
143typedef unsigned long Atomic_Ulong;
144
145typedef uintptr_t Atomic_Uintptr;
146
147typedef bool Atomic_Flag;
148
149typedef int Atomic_Order;
150
151#define ATOMIC_ORDER_RELAXED 0
152
153#define ATOMIC_ORDER_ACQUIRE 2
154
155#define ATOMIC_ORDER_RELEASE 3
156
157#define ATOMIC_ORDER_ACQ_REL 4
158
159#define ATOMIC_ORDER_SEQ_CST 5
160
161#define ATOMIC_INITIALIZER_UINT( value ) ( value )
162
163#define ATOMIC_INITIALIZER_ULONG( value ) ( value )
164
165#define ATOMIC_INITIALIZER_UINTPTR( value ) ( value )
166
167#define ATOMIC_INITIALIZER_FLAG false
168
169#endif
170
176static inline void _Atomic_Fence( Atomic_Order order )
177{
178#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
179 std::atomic_thread_fence( order );
180#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
181 atomic_thread_fence( order );
182#else
183 (void) order;
185#endif
186}
187
194static inline void _Atomic_Init_uint( Atomic_Uint *obj, unsigned int desired )
195{
196#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
197 reinterpret_cast<std::atomic_uint *>( obj )->store( desired );
198#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
199 atomic_init( obj, desired );
200#else
201 *obj = desired;
202#endif
203}
204
211static inline void _Atomic_Init_ulong( Atomic_Ulong *obj, unsigned long desired )
212{
213#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
214 reinterpret_cast<std::atomic_ulong *>( obj )->store( desired );
215#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
216 atomic_init( obj, desired );
217#else
218 *obj = desired;
219#endif
220}
221
228static inline void _Atomic_Init_uintptr( Atomic_Uintptr *obj, uintptr_t desired )
229{
230#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
231 reinterpret_cast<std::atomic_uintptr_t *>( obj )->store( desired );
232#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
233 atomic_init( obj, desired );
234#else
235 *obj = desired;
236#endif
237}
238
247static inline unsigned int _Atomic_Load_uint( const Atomic_Uint *obj, Atomic_Order order )
248{
249#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
250 return reinterpret_cast<const std::atomic_uint *>( obj )->load( order );
251#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
252 return atomic_load_explicit( obj, order );
253#else
254 unsigned int val;
255
256 (void) order;
257 val = *obj;
259
260 return val;
261#endif
262}
263
272static inline unsigned long _Atomic_Load_ulong( const Atomic_Ulong *obj, Atomic_Order order )
273{
274#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
275 return reinterpret_cast<const std::atomic_ulong *>( obj )->load( order );
276#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
277 return atomic_load_explicit( obj, order );
278#else
279 unsigned long val;
280
281 (void) order;
282 val = *obj;
284
285 return val;
286#endif
287}
288
297static inline uintptr_t _Atomic_Load_uintptr( const Atomic_Uintptr *obj, Atomic_Order order )
298{
299#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
300 return reinterpret_cast<const std::atomic_uintptr_t *>( obj )->load( order );
301#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
302 return atomic_load_explicit( obj, order );
303#else
304 uintptr_t val;
305
306 (void) order;
307 val = *obj;
309
310 return val;
311#endif
312}
313
321static inline void _Atomic_Store_uint( Atomic_Uint *obj, unsigned int desired, Atomic_Order order )
322{
323#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
324 reinterpret_cast<std::atomic_uint *>( obj )->store( desired, order );
325#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
326 atomic_store_explicit( obj, desired, order );
327#else
328 (void) order;
330 *obj = desired;
331#endif
332}
333
341static inline void _Atomic_Store_ulong( Atomic_Ulong *obj, unsigned long desired, Atomic_Order order )
342{
343#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
344 reinterpret_cast<std::atomic_ulong *>( obj )->store( desired, order );
345#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
346 atomic_store_explicit( obj, desired, order );
347#else
348 (void) order;
350 *obj = desired;
351#endif
352}
353
361static inline void _Atomic_Store_uintptr( Atomic_Uintptr *obj, uintptr_t desired, Atomic_Order order )
362{
363#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
364 reinterpret_cast<std::atomic_uintptr_t *>( obj )->store( desired, order );
365#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
366 atomic_store_explicit( obj, desired, order );
367#else
368 (void) order;
370 *obj = desired;
371#endif
372}
373
383static inline unsigned int _Atomic_Fetch_add_uint( Atomic_Uint *obj, unsigned int arg, Atomic_Order order )
384{
385#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
386 return reinterpret_cast<std::atomic_uint *>( obj )->fetch_add( arg, order );
387#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
388 return atomic_fetch_add_explicit( obj, arg, order );
389#else
390 unsigned int val;
391 ISR_Level level;
392
393 (void) order;
394 _ISR_Local_disable( level );
395 val = *obj;
396 *obj = val + arg;
397 _ISR_Local_enable( level );
398
399 return val;
400#endif
401}
402
412static inline unsigned long _Atomic_Fetch_add_ulong( Atomic_Ulong *obj, unsigned long arg, Atomic_Order order )
413{
414#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
415 return reinterpret_cast<std::atomic_ulong *>( obj )->fetch_add( arg, order );
416#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
417 return atomic_fetch_add_explicit( obj, arg, order );
418#else
419 unsigned long val;
420 ISR_Level level;
421
422 (void) order;
423 _ISR_Local_disable( level );
424 val = *obj;
425 *obj = val + arg;
426 _ISR_Local_enable( level );
427
428 return val;
429#endif
430}
431
441static inline uintptr_t _Atomic_Fetch_add_uintptr( Atomic_Uintptr *obj, uintptr_t arg, Atomic_Order order )
442{
443#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
444 return reinterpret_cast<std::atomic_uintptr_t *>( obj )->fetch_add( arg, order );
445#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
446 return atomic_fetch_add_explicit( obj, arg, order );
447#else
448 uintptr_t val;
449 ISR_Level level;
450
451 (void) order;
452 _ISR_Local_disable( level );
453 val = *obj;
454 *obj = val + arg;
455 _ISR_Local_enable( level );
456
457 return val;
458#endif
459}
460
470static inline unsigned int _Atomic_Fetch_sub_uint( Atomic_Uint *obj, unsigned int arg, Atomic_Order order )
471{
472#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
473 return reinterpret_cast<std::atomic_uint *>( obj )->fetch_sub( arg, order );
474#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
475 return atomic_fetch_sub_explicit( obj, arg, order );
476#else
477 unsigned int val;
478 ISR_Level level;
479
480 (void) order;
481 _ISR_Local_disable( level );
482 val = *obj;
483 *obj = val - arg;
484 _ISR_Local_enable( level );
485
486 return val;
487#endif
488}
489
499static inline unsigned long _Atomic_Fetch_sub_ulong( Atomic_Ulong *obj, unsigned long arg, Atomic_Order order )
500{
501#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
502 return reinterpret_cast<std::atomic_ulong *>( obj )->fetch_sub( arg, order );
503#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
504 return atomic_fetch_sub_explicit( obj, arg, order );
505#else
506 unsigned long val;
507 ISR_Level level;
508
509 (void) order;
510 _ISR_Local_disable( level );
511 val = *obj;
512 *obj = val - arg;
513 _ISR_Local_enable( level );
514
515 return val;
516#endif
517}
518
528static inline uintptr_t _Atomic_Fetch_sub_uintptr( Atomic_Uintptr *obj, uintptr_t arg, Atomic_Order order )
529{
530#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
531 return reinterpret_cast<std::atomic_uintptr_t *>( obj )->fetch_sub( arg, order );
532#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
533 return atomic_fetch_sub_explicit( obj, arg, order );
534#else
535 uintptr_t val;
536 ISR_Level level;
537
538 (void) order;
539 _ISR_Local_disable( level );
540 val = *obj;
541 *obj = val - arg;
542 _ISR_Local_enable( level );
543
544 return val;
545#endif
546}
547
557static inline unsigned int _Atomic_Fetch_or_uint( Atomic_Uint *obj, unsigned int arg, Atomic_Order order )
558{
559#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
560 return reinterpret_cast<std::atomic_uint *>( obj )->fetch_or( arg, order );
561#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
562 return atomic_fetch_or_explicit( obj, arg, order );
563#else
564 unsigned int val;
565 ISR_Level level;
566
567 (void) order;
568 _ISR_Local_disable( level );
569 val = *obj;
570 *obj = val | arg;
571 _ISR_Local_enable( level );
572
573 return val;
574#endif
575}
576
586static inline unsigned long _Atomic_Fetch_or_ulong( Atomic_Ulong *obj, unsigned long arg, Atomic_Order order )
587{
588#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
589 return reinterpret_cast<std::atomic_ulong *>( obj )->fetch_or( arg, order );
590#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
591 return atomic_fetch_or_explicit( obj, arg, order );
592#else
593 unsigned long val;
594 ISR_Level level;
595
596 (void) order;
597 _ISR_Local_disable( level );
598 val = *obj;
599 *obj = val | arg;
600 _ISR_Local_enable( level );
601
602 return val;
603#endif
604}
605
615static inline uintptr_t _Atomic_Fetch_or_uintptr( Atomic_Uintptr *obj, uintptr_t arg, Atomic_Order order )
616{
617#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
618 return reinterpret_cast<std::atomic_uintptr_t *>( obj )->fetch_or( arg, order );
619#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
620 return atomic_fetch_or_explicit( obj, arg, order );
621#else
622 uintptr_t val;
623 ISR_Level level;
624
625 (void) order;
626 _ISR_Local_disable( level );
627 val = *obj;
628 *obj = val | arg;
629 _ISR_Local_enable( level );
630
631 return val;
632#endif
633}
634
644static inline unsigned int _Atomic_Fetch_and_uint( Atomic_Uint *obj, unsigned int arg, Atomic_Order order )
645{
646#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
647 return reinterpret_cast<std::atomic_uint *>( obj )->fetch_and( arg, order );
648#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
649 return atomic_fetch_and_explicit( obj, arg, order );
650#else
651 unsigned int val;
652 ISR_Level level;
653
654 (void) order;
655 _ISR_Local_disable( level );
656 val = *obj;
657 *obj = val & arg;
658 _ISR_Local_enable( level );
659
660 return val;
661#endif
662}
663
673static inline unsigned long _Atomic_Fetch_and_ulong( Atomic_Ulong *obj, unsigned long arg, Atomic_Order order )
674{
675#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
676 return reinterpret_cast<std::atomic_ulong *>( obj )->fetch_and( arg, order );
677#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
678 return atomic_fetch_and_explicit( obj, arg, order );
679#else
680 unsigned long val;
681 ISR_Level level;
682
683 (void) order;
684 _ISR_Local_disable( level );
685 val = *obj;
686 *obj = val & arg;
687 _ISR_Local_enable( level );
688
689 return val;
690#endif
691}
692
702static inline uintptr_t _Atomic_Fetch_and_uintptr( Atomic_Uintptr *obj, uintptr_t arg, Atomic_Order order )
703{
704#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
705 return reinterpret_cast<std::atomic_uintptr_t *>( obj )->fetch_and( arg, order );
706#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
707 return atomic_fetch_and_explicit( obj, arg, order );
708#else
709 uintptr_t val;
710 ISR_Level level;
711
712 (void) order;
713 _ISR_Local_disable( level );
714 val = *obj;
715 *obj = val & arg;
716 _ISR_Local_enable( level );
717
718 return val;
719#endif
720}
721
731static inline unsigned int _Atomic_Exchange_uint( Atomic_Uint *obj, unsigned int desired, Atomic_Order order )
732{
733#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
734 return reinterpret_cast<std::atomic_uint *>( obj )->exchange( desired, order );
735#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
736 return atomic_exchange_explicit( obj, desired, order );
737#else
738 unsigned int val;
739 ISR_Level level;
740
741 (void) order;
742 _ISR_Local_disable( level );
743 val = *obj;
744 *obj = desired;
745 _ISR_Local_enable( level );
746
747 return val;
748#endif
749}
750
760static inline unsigned long _Atomic_Exchange_ulong( Atomic_Ulong *obj, unsigned long desired, Atomic_Order order )
761{
762#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
763 return reinterpret_cast<std::atomic_ulong *>( obj )->exchange( desired, order );
764#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
765 return atomic_exchange_explicit( obj, desired, order );
766#else
767 unsigned long val;
768 ISR_Level level;
769
770 (void) order;
771 _ISR_Local_disable( level );
772 val = *obj;
773 *obj = desired;
774 _ISR_Local_enable( level );
775
776 return val;
777#endif
778}
779
789static inline uintptr_t _Atomic_Exchange_uintptr( Atomic_Uintptr *obj, uintptr_t desired, Atomic_Order order )
790{
791#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
792 return reinterpret_cast<std::atomic_uintptr_t *>( obj )->exchange( desired, order );
793#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
794 return atomic_exchange_explicit( obj, desired, order );
795#else
796 uintptr_t val;
797 ISR_Level level;
798
799 (void) order;
800 _ISR_Local_disable( level );
801 val = *obj;
802 *obj = desired;
803 _ISR_Local_enable( level );
804
805 return val;
806#endif
807}
808
826static inline bool _Atomic_Compare_exchange_uint( Atomic_Uint *obj, unsigned int *expected, unsigned int desired, Atomic_Order succ, Atomic_Order fail )
827{
828#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
829 return reinterpret_cast<std::atomic_uint *>( obj )->compare_exchange_strong( *expected, desired, succ, fail );
830#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
831 return atomic_compare_exchange_strong_explicit( obj, expected, desired, succ, fail );
832#else
833 bool success;
834 ISR_Level level;
835 unsigned int actual;
836
837 (void) succ;
838 (void) fail;
839 _ISR_Local_disable( level );
840 actual = *obj;
841 success = ( actual == *expected );
842 if ( success ) {
843 *obj = desired;
844 } else {
845 *expected = actual;
846 }
847 _ISR_Local_enable( level );
848
849 return success;
850#endif
851}
852
870static inline bool _Atomic_Compare_exchange_ulong( Atomic_Ulong *obj, unsigned long *expected, unsigned long desired, Atomic_Order succ, Atomic_Order fail )
871{
872#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
873 return reinterpret_cast<std::atomic_ulong *>( obj )->compare_exchange_strong( *expected, desired, succ, fail );
874#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
875 return atomic_compare_exchange_strong_explicit( obj, expected, desired, succ, fail );
876#else
877 bool success;
878 ISR_Level level;
879 unsigned long actual;
880
881 (void) succ;
882 (void) fail;
883 _ISR_Local_disable( level );
884 actual = *obj;
885 success = ( actual == *expected );
886 if ( success ) {
887 *obj = desired;
888 } else {
889 *expected = actual;
890 }
891 _ISR_Local_enable( level );
892
893 return success;
894#endif
895}
896
914static inline bool _Atomic_Compare_exchange_uintptr( Atomic_Uintptr *obj, uintptr_t *expected, uintptr_t desired, Atomic_Order succ, Atomic_Order fail )
915{
916#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
917 return reinterpret_cast<std::atomic_uintptr_t *>( obj )->compare_exchange_strong( *expected, desired, succ, fail );
918#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
919 return atomic_compare_exchange_strong_explicit( obj, expected, desired, succ, fail );
920#else
921 bool success;
922 ISR_Level level;
923 uintptr_t actual;
924
925 (void) succ;
926 (void) fail;
927 _ISR_Local_disable( level );
928 actual = *obj;
929 success = ( actual == *expected );
930 if ( success ) {
931 *obj = desired;
932 } else {
933 *expected = actual;
934 }
935 _ISR_Local_enable( level );
936
937 return success;
938#endif
939}
940
947static inline void _Atomic_Flag_clear( Atomic_Flag *obj, Atomic_Order order )
948{
949#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
950 obj->clear( order );
951#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
952 atomic_flag_clear_explicit( obj, order );
953#else
954 (void) order;
955 *obj = false;
956#endif
957}
958
968static inline bool _Atomic_Flag_test_and_set( Atomic_Flag *obj, Atomic_Order order )
969{
970#if defined(_RTEMS_SCORE_ATOMIC_USE_ATOMIC)
971 return obj->test_and_set( order );
972#elif defined(_RTEMS_SCORE_ATOMIC_USE_STDATOMIC)
973 return atomic_flag_test_and_set_explicit( obj, order );
974#else
975 bool flag;
976 ISR_Level level;
977
978 (void) order;
979 _ISR_Local_disable( level );
980 flag = *obj;
981 *obj = true;
982 _ISR_Local_enable( level );
983
984 return flag;
985#endif
986}
987
990#endif /* _RTEMS_SCORE_ATOMIC_H */
This header file provides basic definitions used by the API and the implementation.
#define RTEMS_COMPILER_MEMORY_BARRIER()
This macro forbids the compiler to reorder read and write commands around it.
Definition: basedefs.h:258
#define _ISR_Local_disable(_level)
Disables interrupts on this processor.
Definition: isrlevel.h:76
#define _ISR_Local_enable(_level)
Enables interrupts on this processor.
Definition: isrlevel.h:93
uint32_t ISR_Level
Definition: isrlevel.h:60
This header file provides the ISR_Level related interfaces of the ISR Handler.
