RTEMS 6.1
mpu-config.h
2
11/*
12 * Copyright (C) 2020 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_IMXRT_IMXRT_MPU_CONFIG_H
37#define LIBBSP_ARM_IMXRT_IMXRT_MPU_CONFIG_H
38
39#include <bsp/start.h>
40#include <rtems/score/armv7m.h>
41
42#ifdef __cplusplus
43extern "C" {
44#endif /* __cplusplus */
45
46extern BSP_START_DATA_SECTION const ARMV7M_MPU_Region_config
47 imxrt_config_mpu_region[];
48extern BSP_START_DATA_SECTION const size_t imxrt_config_mpu_region_count;
49
50#ifdef __cplusplus
51}
52#endif /* __cplusplus */
53
54#endif /* LIBBSP_ARM_IMXRT_IMXRT_MPU_CONFIG_H */
This header file provides interfaces of the ARMv7-M architecture support.
