RTEMS 6.1
imxrt1050-pinfunc.h
2
11/*
12 * Copyright (C) 2020 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_IMXRT_IMXRT1050_PINFUNC_H
37#define LIBBSP_ARM_IMXRT_IMXRT1050_PINFUNC_H
38
39#ifdef __cplusplus
40extern "C" {
41#endif /* __cplusplus */
42
43/* GPIO_AD_B0_00 */
44#define IMXRT_PAD_GPIO_AD_B0_00__PWM2_A3 0x00bc 0x02ac 0x0474 0 2
45#define IMXRT_PAD_GPIO_AD_B0_00__XBARA1_OUT14 0x00bc 0x02ac 0x0644 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_14 to 0x1 */
46#define IMXRT_PAD_GPIO_AD_B0_00__XBARA1_IN14 0x00bc 0x02ac 0x0644 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_14 to 0 */
47#define IMXRT_PAD_GPIO_AD_B0_00__XTALOSC24M_REF_CLK_32K 0x00bc 0x02ac 0x0000 2 0
48#define IMXRT_PAD_GPIO_AD_B0_00__USB2_usb_otg2_id 0x00bc 0x02ac 0x03f8 3 0
49#define IMXRT_PAD_GPIO_AD_B0_00__LPI2C1_SCLS 0x00bc 0x02ac 0x0000 4 0
50#define IMXRT_PAD_GPIO_AD_B0_00__GPIO1_gpio_io00 0x00bc 0x02ac 0x0000 5 0
51#define IMXRT_PAD_GPIO_AD_B0_00__USDHC1_usdhc_reset_b 0x00bc 0x02ac 0x0000 6 0
52#define IMXRT_PAD_GPIO_AD_B0_00__LPSPI3_SCK 0x00bc 0x02ac 0x0510 7 0
53#define IMXRT_PAD_GPIO_AD_B0_00__CMP1_IN4 0x00bc 0x02ac 0x0000 5 0
54
55/* GPIO_AD_B0_01 */
56#define IMXRT_PAD_GPIO_AD_B0_01__PWM2_B3 0x00c0 0x02b0 0x0484 0 2
57#define IMXRT_PAD_GPIO_AD_B0_01__XBARA1_OUT15 0x00c0 0x02b0 0x0648 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_15 to 0x1 */
58#define IMXRT_PAD_GPIO_AD_B0_01__XBARA1_IN15 0x00c0 0x02b0 0x0648 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_15 to 0 */
59#define IMXRT_PAD_GPIO_AD_B0_01__XTALOSC24M_REF_CLK_24M 0x00c0 0x02b0 0x0000 2 0
60#define IMXRT_PAD_GPIO_AD_B0_01__USB1_usb_otg1_id 0x00c0 0x02b0 0x03f4 3 0
61#define IMXRT_PAD_GPIO_AD_B0_01__LPI2C1_SDAS 0x00c0 0x02b0 0x0000 4 0
62#define IMXRT_PAD_GPIO_AD_B0_01__GPIO1_gpio_io01 0x00c0 0x02b0 0x0000 5 0
63#define IMXRT_PAD_GPIO_AD_B0_01__EWM_EWM_OUT_B 0x00c0 0x02b0 0x0000 6 0
64#define IMXRT_PAD_GPIO_AD_B0_01__LPSPI3_SDO 0x00c0 0x02b0 0x0518 7 0
65#define IMXRT_PAD_GPIO_AD_B0_01__CMP2_IN4 0x00c0 0x02b0 0x0000 5 0
66
67/* GPIO_AD_B0_02 */
68#define IMXRT_PAD_GPIO_AD_B0_02__CAN2_TX 0x00c4 0x02b4 0x0000 0 0
69#define IMXRT_PAD_GPIO_AD_B0_02__XBARA1_OUT16 0x00c4 0x02b4 0x064c 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_16 to 0x1 */
70#define IMXRT_PAD_GPIO_AD_B0_02__XBARA1_IN16 0x00c4 0x02b4 0x064c 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_16 to 0 */
71#define IMXRT_PAD_GPIO_AD_B0_02__LPUART6_TX 0x00c4 0x02b4 0x0554 2 1
72#define IMXRT_PAD_GPIO_AD_B0_02__USB1_usb_otg1_pwr 0x00c4 0x02b4 0x0000 3 0
73#define IMXRT_PAD_GPIO_AD_B0_02__PWM1_X0 0x00c4 0x02b4 0x0000 4 0
74#define IMXRT_PAD_GPIO_AD_B0_02__GPIO1_gpio_io02 0x00c4 0x02b4 0x0000 5 0
75#define IMXRT_PAD_GPIO_AD_B0_02__LPI2C1_HREQ 0x00c4 0x02b4 0x0000 6 0
76#define IMXRT_PAD_GPIO_AD_B0_02__LPSPI3_SDI 0x00c4 0x02b4 0x0514 7 0
77#define IMXRT_PAD_GPIO_AD_B0_02__CMP3_IN4 0x00c4 0x02b4 0x0000 5 0
78
79/* GPIO_AD_B0_03 */
80#define IMXRT_PAD_GPIO_AD_B0_03__CAN2_RX 0x00c8 0x02b8 0x0450 0 1
81#define IMXRT_PAD_GPIO_AD_B0_03__XBARA1_OUT17 0x00c8 0x02b8 0x062c 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0x1 */
82#define IMXRT_PAD_GPIO_AD_B0_03__XBARA1_IN17 0x00c8 0x02b8 0x062c 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0 */
83#define IMXRT_PAD_GPIO_AD_B0_03__LPUART6_RX 0x00c8 0x02b8 0x0550 2 1
84#define IMXRT_PAD_GPIO_AD_B0_03__USB1_usb_otg1_oc 0x00c8 0x02b8 0x05d0 3 0
85#define IMXRT_PAD_GPIO_AD_B0_03__PWM1_X1 0x00c8 0x02b8 0x0000 4 0
86#define IMXRT_PAD_GPIO_AD_B0_03__GPIO1_gpio_io03 0x00c8 0x02b8 0x0000 5 0
87#define IMXRT_PAD_GPIO_AD_B0_03__XTALOSC24M_REF_CLK_24M 0x00c8 0x02b8 0x0000 6 0
88#define IMXRT_PAD_GPIO_AD_B0_03__LPSPI3_PCS0 0x00c8 0x02b8 0x050c 7 0
89#define IMXRT_PAD_GPIO_AD_B0_03__CMP4_IN4 0x00c8 0x02b8 0x0000 5 0
90
91/* GPIO_AD_B0_04 */
92#define IMXRT_PAD_GPIO_AD_B0_04__SRC_BOOT_MODE0 0x00cc 0x02bc 0x0000 0 0
93#define IMXRT_PAD_GPIO_AD_B0_04__MQS_RIGHT 0x00cc 0x02bc 0x0000 1 0
94#define IMXRT_PAD_GPIO_AD_B0_04__ENET_enet_tx_data3 0x00cc 0x02bc 0x0000 2 0
95#define IMXRT_PAD_GPIO_AD_B0_04__SAI2_sai_tx_sync 0x00cc 0x02bc 0x05c4 3 1
96#define IMXRT_PAD_GPIO_AD_B0_04__CSI_csi_data09 0x00cc 0x02bc 0x041c 4 1
97#define IMXRT_PAD_GPIO_AD_B0_04__GPIO1_gpio_io04 0x00cc 0x02bc 0x0000 5 0
98#define IMXRT_PAD_GPIO_AD_B0_04__PIT_TRIGGER0 0x00cc 0x02bc 0x0000 6 0
99#define IMXRT_PAD_GPIO_AD_B0_04__LPSPI3_PCS1 0x00cc 0x02bc 0x0000 7 0
100
101/* GPIO_AD_B0_05 */
102#define IMXRT_PAD_GPIO_AD_B0_05__SRC_BOOT_MODE1 0x00d0 0x02c0 0x0000 0 0
103#define IMXRT_PAD_GPIO_AD_B0_05__MQS_LEFT 0x00d0 0x02c0 0x0000 1 0
104#define IMXRT_PAD_GPIO_AD_B0_05__ENET_enet_tx_data2 0x00d0 0x02c0 0x0000 2 0
105#define IMXRT_PAD_GPIO_AD_B0_05__SAI2_sai_tx_bclk 0x00d0 0x02c0 0x05c0 3 1
106#define IMXRT_PAD_GPIO_AD_B0_05__CSI_csi_data08 0x00d0 0x02c0 0x0418 4 1
107#define IMXRT_PAD_GPIO_AD_B0_05__GPIO1_gpio_io05 0x00d0 0x02c0 0x0000 5 0
108#define IMXRT_PAD_GPIO_AD_B0_05__XBARA1_OUT17 0x00d0 0x02c0 0x062c 6 2 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0x1 */
109#define IMXRT_PAD_GPIO_AD_B0_05__XBARA1_IN17 0x00d0 0x02c0 0x062c 6 2 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0 */
110#define IMXRT_PAD_GPIO_AD_B0_05__LPSPI3_PCS2 0x00d0 0x02c0 0x0000 7 0
111
112/* GPIO_AD_B0_06 */
113#define IMXRT_PAD_GPIO_AD_B0_06__JTAG_TMS 0x00d4 0x02c4 0x0000 0 0
114#define IMXRT_PAD_GPIO_AD_B0_06__GPT2_gpt_compare1 0x00d4 0x02c4 0x0000 1 0
115#define IMXRT_PAD_GPIO_AD_B0_06__ENET_enet_rx_clk 0x00d4 0x02c4 0x0000 2 0
116#define IMXRT_PAD_GPIO_AD_B0_06__SAI2_sai_rx_bclk 0x00d4 0x02c4 0x05b4 3 1
117#define IMXRT_PAD_GPIO_AD_B0_06__CSI_csi_data07 0x00d4 0x02c4 0x0414 4 1
118#define IMXRT_PAD_GPIO_AD_B0_06__GPIO1_gpio_io06 0x00d4 0x02c4 0x0000 5 0
119#define IMXRT_PAD_GPIO_AD_B0_06__XBARA1_OUT18 0x00d4 0x02c4 0x0630 6 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_18 to 0x1 */
120#define IMXRT_PAD_GPIO_AD_B0_06__XBARA1_IN18 0x00d4 0x02c4 0x0630 6 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_18 to 0 */
121#define IMXRT_PAD_GPIO_AD_B0_06__LPSPI3_PCS3 0x00d4 0x02c4 0x0000 7 0
122
123/* GPIO_AD_B0_07 */
124#define IMXRT_PAD_GPIO_AD_B0_07__JTAG_TCK 0x00d8 0x02c8 0x0000 0 0
125#define IMXRT_PAD_GPIO_AD_B0_07__GPT2_gpt_compare2 0x00d8 0x02c8 0x0000 1 0
126#define IMXRT_PAD_GPIO_AD_B0_07__ENET_enet_tx_er 0x00d8 0x02c8 0x0000 2 0
127#define IMXRT_PAD_GPIO_AD_B0_07__SAI2_sai_rx_sync 0x00d8 0x02c8 0x05bc 3 1
128#define IMXRT_PAD_GPIO_AD_B0_07__CSI_csi_data06 0x00d8 0x02c8 0x0410 4 1
129#define IMXRT_PAD_GPIO_AD_B0_07__GPIO1_gpio_io07 0x00d8 0x02c8 0x0000 5 0
130#define IMXRT_PAD_GPIO_AD_B0_07__XBARA1_OUT19 0x00d8 0x02c8 0x0654 6 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_19 to 0x1 */
131#define IMXRT_PAD_GPIO_AD_B0_07__XBARA1_IN19 0x00d8 0x02c8 0x0654 6 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_19 to 0 */
132#define IMXRT_PAD_GPIO_AD_B0_07__ENET_1588_EVENT3_OUT 0x00d8 0x02c8 0x0000 7 0
133
134/* GPIO_AD_B0_08 */
135#define IMXRT_PAD_GPIO_AD_B0_08__JTAG_MOD 0x00dc 0x02cc 0x0000 0 0
136#define IMXRT_PAD_GPIO_AD_B0_08__GPT2_gpt_compare3 0x00dc 0x02cc 0x0000 1 0
137#define IMXRT_PAD_GPIO_AD_B0_08__ENET_enet_rx_data3 0x00dc 0x02cc 0x0000 2 0
138#define IMXRT_PAD_GPIO_AD_B0_08__SAI2_sai_rx_data 0x00dc 0x02cc 0x05b8 3 1
139#define IMXRT_PAD_GPIO_AD_B0_08__CSI_csi_data05 0x00dc 0x02cc 0x040c 4 1
140#define IMXRT_PAD_GPIO_AD_B0_08__GPIO1_gpio_io08 0x00dc 0x02cc 0x0000 5 0
141#define IMXRT_PAD_GPIO_AD_B0_08__XBARA1_IN20 0x00dc 0x02cc 0x0634 6 1
142#define IMXRT_PAD_GPIO_AD_B0_08__ENET_1588_EVENT3_IN 0x00dc 0x02cc 0x0000 7 0
143
144/* GPIO_AD_B0_09 */
145#define IMXRT_PAD_GPIO_AD_B0_09__JTAG_TDI 0x00e0 0x02d0 0x0000 0 0
146#define IMXRT_PAD_GPIO_AD_B0_09__PWM2_A3 0x00e0 0x02d0 0x0474 1 3
147#define IMXRT_PAD_GPIO_AD_B0_09__ENET_enet_rx_data2 0x00e0 0x02d0 0x0000 2 0
148#define IMXRT_PAD_GPIO_AD_B0_09__SAI2_sai_tx_data 0x00e0 0x02d0 0x0000 3 0
149#define IMXRT_PAD_GPIO_AD_B0_09__CSI_csi_data04 0x00e0 0x02d0 0x0408 4 1
150#define IMXRT_PAD_GPIO_AD_B0_09__GPIO1_gpio_io09 0x00e0 0x02d0 0x0000 5 0
151#define IMXRT_PAD_GPIO_AD_B0_09__XBARA1_IN21 0x00e0 0x02d0 0x0658 6 1
152#define IMXRT_PAD_GPIO_AD_B0_09__GPT2_gpt_clk 0x00e0 0x02d0 0x0000 7 0
153
154/* GPIO_AD_B0_10 */
155#define IMXRT_PAD_GPIO_AD_B0_10__JTAG_TDO 0x00e4 0x02d4 0x0000 0 0
156#define IMXRT_PAD_GPIO_AD_B0_10__PWM1_A3 0x00e4 0x02d4 0x0454 1 3
157#define IMXRT_PAD_GPIO_AD_B0_10__ENET_enet_crs 0x00e4 0x02d4 0x0000 2 0
158#define IMXRT_PAD_GPIO_AD_B0_10__SAI2_sai_mclk 0x00e4 0x02d4 0x05b0 3 1
159#define IMXRT_PAD_GPIO_AD_B0_10__CSI_csi_data03 0x00e4 0x02d4 0x0404 4 1
160#define IMXRT_PAD_GPIO_AD_B0_10__GPIO1_gpio_io10 0x00e4 0x02d4 0x0000 5 0
161#define IMXRT_PAD_GPIO_AD_B0_10__XBARA1_IN22 0x00e4 0x02d4 0x0638 6 1
162#define IMXRT_PAD_GPIO_AD_B0_10__ENET_1588_EVENT0_OUT 0x00e4 0x02d4 0x0000 7 0
163
164/* GPIO_AD_B0_11 */
165#define IMXRT_PAD_GPIO_AD_B0_11__JTAG_TRSTB 0x00e8 0x02d8 0x0000 0 0
166#define IMXRT_PAD_GPIO_AD_B0_11__PWM1_B3 0x00e8 0x02d8 0x0464 1 3
167#define IMXRT_PAD_GPIO_AD_B0_11__ENET_enet_col 0x00e8 0x02d8 0x0000 2 0
168#define IMXRT_PAD_GPIO_AD_B0_11__WDOG1_wdog_b 0x00e8 0x02d8 0x0000 3 0
169#define IMXRT_PAD_GPIO_AD_B0_11__CSI_csi_data02 0x00e8 0x02d8 0x0400 4 1
170#define IMXRT_PAD_GPIO_AD_B0_11__GPIO1_gpio_io11 0x00e8 0x02d8 0x0000 5 0
171#define IMXRT_PAD_GPIO_AD_B0_11__XBARA1_IN23 0x00e8 0x02d8 0x063c 6 1
172#define IMXRT_PAD_GPIO_AD_B0_11__ENET_1588_EVENT0_IN 0x00e8 0x02d8 0x0444 7 1
173
174/* GPIO_AD_B0_12 */
175#define IMXRT_PAD_GPIO_AD_B0_12__LPI2C4_SCL 0x00ec 0x02dc 0x04e4 0 1
176#define IMXRT_PAD_GPIO_AD_B0_12__CCM_PMIC_RDY 0x00ec 0x02dc 0x03fc 1 1
177#define IMXRT_PAD_GPIO_AD_B0_12__LPUART1_TX 0x00ec 0x02dc 0x0000 2 0
178#define IMXRT_PAD_GPIO_AD_B0_12__WDOG2_wdog_b 0x00ec 0x02dc 0x0000 3 0
179#define IMXRT_PAD_GPIO_AD_B0_12__PWM1_X2 0x00ec 0x02dc 0x0000 4 0
180#define IMXRT_PAD_GPIO_AD_B0_12__GPIO1_gpio_io12 0x00ec 0x02dc 0x0000 5 0
181#define IMXRT_PAD_GPIO_AD_B0_12__ENET_1588_EVENT1_OUT 0x00ec 0x02dc 0x0000 6 0
182#define IMXRT_PAD_GPIO_AD_B0_12__ARM_arm_nmi 0x00ec 0x02dc 0x0568 7 0
183#define IMXRT_PAD_GPIO_AD_B0_12__ADC1_IN1 0x00ec 0x02dc 0x0000 5 0
184
185/* GPIO_AD_B0_13 */
186#define IMXRT_PAD_GPIO_AD_B0_13__LPI2C4_SDA 0x00f0 0x02e0 0x04e8 0 1
187#define IMXRT_PAD_GPIO_AD_B0_13__GPT1_gpt_clk 0x00f0 0x02e0 0x0000 1 0
188#define IMXRT_PAD_GPIO_AD_B0_13__LPUART1_RX 0x00f0 0x02e0 0x0000 2 0
189#define IMXRT_PAD_GPIO_AD_B0_13__EWM_EWM_OUT_B 0x00f0 0x02e0 0x0000 3 0
190#define IMXRT_PAD_GPIO_AD_B0_13__PWM1_X3 0x00f0 0x02e0 0x0000 4 0
191#define IMXRT_PAD_GPIO_AD_B0_13__GPIO1_gpio_io13 0x00f0 0x02e0 0x0000 5 0
192#define IMXRT_PAD_GPIO_AD_B0_13__ENET_1588_EVENT1_IN 0x00f0 0x02e0 0x0000 6 0
193#define IMXRT_PAD_GPIO_AD_B0_13__XTALOSC24M_REF_CLK_24M 0x00f0 0x02e0 0x0000 7 0
194#define IMXRT_PAD_GPIO_AD_B0_13__ADC1_IN2 0x00f0 0x02e0 0x0000 5 0
195#define IMXRT_PAD_GPIO_AD_B0_13__CMP1_IN2 0x00f0 0x02e0 0x0000 5 0
196
197/* GPIO_AD_B0_14 */
198#define IMXRT_PAD_GPIO_AD_B0_14__USB2_usb_otg2_oc 0x00f4 0x02e4 0x05cc 0 0
199#define IMXRT_PAD_GPIO_AD_B0_14__XBARA1_IN24 0x00f4 0x02e4 0x0640 1 1
200#define IMXRT_PAD_GPIO_AD_B0_14__LPUART1_CTS_B 0x00f4 0x02e4 0x0000 2 0
201#define IMXRT_PAD_GPIO_AD_B0_14__ENET_1588_EVENT0_OUT 0x00f4 0x02e4 0x0000 3 0
202#define IMXRT_PAD_GPIO_AD_B0_14__CSI_csi_vsync 0x00f4 0x02e4 0x0428 4 0
203#define IMXRT_PAD_GPIO_AD_B0_14__GPIO1_gpio_io14 0x00f4 0x02e4 0x0000 5 0
204#define IMXRT_PAD_GPIO_AD_B0_14__CAN2_TX 0x00f4 0x02e4 0x0000 6 0
205#define IMXRT_PAD_GPIO_AD_B0_14__ADC1_IN3 0x00f4 0x02e4 0x0000 5 0
206#define IMXRT_PAD_GPIO_AD_B0_14__CMP2_IN2 0x00f4 0x02e4 0x0000 5 0
207
208/* GPIO_AD_B0_15 */
209#define IMXRT_PAD_GPIO_AD_B0_15__USB2_usb_otg2_pwr 0x00f8 0x02e8 0x0000 0 0
210#define IMXRT_PAD_GPIO_AD_B0_15__XBARA1_IN25 0x00f8 0x02e8 0x0650 1 0
211#define IMXRT_PAD_GPIO_AD_B0_15__LPUART1_RTS_B 0x00f8 0x02e8 0x0000 2 0
212#define IMXRT_PAD_GPIO_AD_B0_15__ENET_1588_EVENT0_IN 0x00f8 0x02e8 0x0444 3 0
213#define IMXRT_PAD_GPIO_AD_B0_15__CSI_csi_hsync 0x00f8 0x02e8 0x0420 4 0
214#define IMXRT_PAD_GPIO_AD_B0_15__GPIO1_gpio_io15 0x00f8 0x02e8 0x0000 5 0
215#define IMXRT_PAD_GPIO_AD_B0_15__CAN2_RX 0x00f8 0x02e8 0x0450 6 2
216#define IMXRT_PAD_GPIO_AD_B0_15__WDOG1_wdog_rst_b_deb 0x00f8 0x02e8 0x0000 7 0
217#define IMXRT_PAD_GPIO_AD_B0_15__ADC1_IN4 0x00f8 0x02e8 0x0000 5 0
218#define IMXRT_PAD_GPIO_AD_B0_15__CMP3_IN2 0x00f8 0x02e8 0x0000 5 0
219
220/* GPIO_AD_B1_00 */
221#define IMXRT_PAD_GPIO_AD_B1_00__USB2_usb_otg2_id 0x00fc 0x02ec 0x03f8 0 1
222#define IMXRT_PAD_GPIO_AD_B1_00__TMR3_TIMER0 0x00fc 0x02ec 0x057c 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM0_INPUT_SEL to 0 */
223#define IMXRT_PAD_GPIO_AD_B1_00__LPUART2_CTS_B 0x00fc 0x02ec 0x0000 2 0
224#define IMXRT_PAD_GPIO_AD_B1_00__LPI2C1_SCL 0x00fc 0x02ec 0x04cc 3 1
225#define IMXRT_PAD_GPIO_AD_B1_00__WDOG1_wdog_b 0x00fc 0x02ec 0x0000 4 0
226#define IMXRT_PAD_GPIO_AD_B1_00__GPIO1_gpio_io16 0x00fc 0x02ec 0x0000 5 0
227#define IMXRT_PAD_GPIO_AD_B1_00__USDHC1_usdhc_wp 0x00fc 0x02ec 0x05d8 6 2
228#define IMXRT_PAD_GPIO_AD_B1_00__KPP_kpp_row7 0x00fc 0x02ec 0x0000 7 0
229#define IMXRT_PAD_GPIO_AD_B1_00__ADC1_IN5 0x00fc 0x02ec 0x0000 5 0
230#define IMXRT_PAD_GPIO_AD_B1_00__ADC2_IN5 0x00fc 0x02ec 0x0000 5 0
231#define IMXRT_PAD_GPIO_AD_B1_00__CMP4_IN2 0x00fc 0x02ec 0x0000 5 0
232
233/* GPIO_AD_B1_01 */
234#define IMXRT_PAD_GPIO_AD_B1_01__USB1_usb_otg1_pwr 0x0100 0x02f0 0x0000 0 0
235#define IMXRT_PAD_GPIO_AD_B1_01__TMR3_TIMER1 0x0100 0x02f0 0x0580 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM1_INPUT_SEL to 0 */
236#define IMXRT_PAD_GPIO_AD_B1_01__LPUART2_RTS_B 0x0100 0x02f0 0x0000 2 0
237#define IMXRT_PAD_GPIO_AD_B1_01__LPI2C1_SDA 0x0100 0x02f0 0x04d0 3 1
238#define IMXRT_PAD_GPIO_AD_B1_01__CCM_PMIC_RDY 0x0100 0x02f0 0x03fc 4 2
239#define IMXRT_PAD_GPIO_AD_B1_01__GPIO1_gpio_io17 0x0100 0x02f0 0x0000 5 0
240#define IMXRT_PAD_GPIO_AD_B1_01__USDHC1_usdhc_vselect 0x0100 0x02f0 0x0000 6 0
241#define IMXRT_PAD_GPIO_AD_B1_01__KPP_kpp_col7 0x0100 0x02f0 0x0000 7 0
242#define IMXRT_PAD_GPIO_AD_B1_01__ADC1_IN6 0x0100 0x02f0 0x0000 5 0
243#define IMXRT_PAD_GPIO_AD_B1_01__ADC2_IN6 0x0100 0x02f0 0x0000 5 0
244#define IMXRT_PAD_GPIO_AD_B1_01__CMP1_IN0 0x0100 0x02f0 0x0000 5 0
245#define IMXRT_PAD_GPIO_AD_B1_01__CMP2_IN0 0x0100 0x02f0 0x0000 5 0
246#define IMXRT_PAD_GPIO_AD_B1_01__CMP3_IN0 0x0100 0x02f0 0x0000 5 0
247#define IMXRT_PAD_GPIO_AD_B1_01__CMP4_IN0 0x0100 0x02f0 0x0000 5 0
248
249/* GPIO_AD_B1_02 */
250#define IMXRT_PAD_GPIO_AD_B1_02__USB1_usb_otg1_id 0x0104 0x02f4 0x03f4 0 1
251#define IMXRT_PAD_GPIO_AD_B1_02__TMR3_TIMER2 0x0104 0x02f4 0x0584 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM2_INPUT_SEL to 0 */
252#define IMXRT_PAD_GPIO_AD_B1_02__LPUART2_TX 0x0104 0x02f4 0x0530 2 1
253#define IMXRT_PAD_GPIO_AD_B1_02__SPDIF_spdif_out 0x0104 0x02f4 0x0000 3 0
254#define IMXRT_PAD_GPIO_AD_B1_02__ENET_1588_EVENT2_OUT 0x0104 0x02f4 0x0000 4 0
255#define IMXRT_PAD_GPIO_AD_B1_02__GPIO1_gpio_io18 0x0104 0x02f4 0x0000 5 0
256#define IMXRT_PAD_GPIO_AD_B1_02__USDHC1_usdhc_cd_b 0x0104 0x02f4 0x05d4 6 1
257#define IMXRT_PAD_GPIO_AD_B1_02__KPP_kpp_row6 0x0104 0x02f4 0x0000 7 0
258#define IMXRT_PAD_GPIO_AD_B1_02__ADC1_IN7 0x0104 0x02f4 0x0000 5 0
259#define IMXRT_PAD_GPIO_AD_B1_02__ADC2_IN7 0x0104 0x02f4 0x0000 5 0
260#define IMXRT_PAD_GPIO_AD_B1_02__CMP1_IN3 0x0104 0x02f4 0x0000 5 0
261
262/* GPIO_AD_B1_03 */
263#define IMXRT_PAD_GPIO_AD_B1_03__USB1_usb_otg1_oc 0x0108 0x02f8 0x05d0 0 1
264#define IMXRT_PAD_GPIO_AD_B1_03__TMR3_TIMER3 0x0108 0x02f8 0x0588 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM3_INPUT_SEL to 0 */
265#define IMXRT_PAD_GPIO_AD_B1_03__LPUART2_RX 0x0108 0x02f8 0x052c 2 1
266#define IMXRT_PAD_GPIO_AD_B1_03__SPDIF_spdif_in 0x0108 0x02f8 0x05c8 3 0
267#define IMXRT_PAD_GPIO_AD_B1_03__ENET_1588_EVENT2_IN 0x0108 0x02f8 0x0000 4 0
268#define IMXRT_PAD_GPIO_AD_B1_03__GPIO1_gpio_io19 0x0108 0x02f8 0x0000 5 0
269#define IMXRT_PAD_GPIO_AD_B1_03__USDHC2_usdhc_cd_b 0x0108 0x02f8 0x05e0 6 0
270#define IMXRT_PAD_GPIO_AD_B1_03__KPP_kpp_col6 0x0108 0x02f8 0x0000 7 0
271#define IMXRT_PAD_GPIO_AD_B1_03__ADC1_IN8 0x0108 0x02f8 0x0000 5 0
272#define IMXRT_PAD_GPIO_AD_B1_03__ADC2_IN8 0x0108 0x02f8 0x0000 5 0
273#define IMXRT_PAD_GPIO_AD_B1_03__CMP2_IN3 0x0108 0x02f8 0x0000 5 0
274
275/* GPIO_AD_B1_04 */
276#define IMXRT_PAD_GPIO_AD_B1_04__FLEXSPI_FLEXSPI_B_DATA3 0x010c 0x02fc 0x04c4 0 1
277#define IMXRT_PAD_GPIO_AD_B1_04__ENET_enet_mdc 0x010c 0x02fc 0x0000 1 0
278#define IMXRT_PAD_GPIO_AD_B1_04__LPUART3_CTS_B 0x010c 0x02fc 0x0534 2 1
279#define IMXRT_PAD_GPIO_AD_B1_04__SPDIF_spdif_sr_clk 0x010c 0x02fc 0x0000 3 0
280#define IMXRT_PAD_GPIO_AD_B1_04__CSI_csi_pixclk 0x010c 0x02fc 0x0424 4 0
281#define IMXRT_PAD_GPIO_AD_B1_04__GPIO1_gpio_io20 0x010c 0x02fc 0x0000 5 0
282#define IMXRT_PAD_GPIO_AD_B1_04__USDHC2_usdhc_data0 0x010c 0x02fc 0x05e8 6 1
283#define IMXRT_PAD_GPIO_AD_B1_04__KPP_kpp_row5 0x010c 0x02fc 0x0000 7 0
284#define IMXRT_PAD_GPIO_AD_B1_04__ADC1_IN9 0x010c 0x02fc 0x0000 5 0
285#define IMXRT_PAD_GPIO_AD_B1_04__ADC2_IN9 0x010c 0x02fc 0x0000 5 0
286#define IMXRT_PAD_GPIO_AD_B1_04__CMP3_IN3 0x010c 0x02fc 0x0000 5 0
287
288/* GPIO_AD_B1_05 */
289#define IMXRT_PAD_GPIO_AD_B1_05__FLEXSPI_FLEXSPI_B_DATA2 0x0110 0x0300 0x04c0 0 1
290#define IMXRT_PAD_GPIO_AD_B1_05__ENET_enet_mdio 0x0110 0x0300 0x0430 1 0
291#define IMXRT_PAD_GPIO_AD_B1_05__LPUART3_RTS_B 0x0110 0x0300 0x0000 2 0
292#define IMXRT_PAD_GPIO_AD_B1_05__SPDIF_spdif_out 0x0110 0x0300 0x0000 3 0
293#define IMXRT_PAD_GPIO_AD_B1_05__CSI_csi_mclk 0x0110 0x0300 0x0000 4 0
294#define IMXRT_PAD_GPIO_AD_B1_05__GPIO1_gpio_io21 0x0110 0x0300 0x0000 5 0
295#define IMXRT_PAD_GPIO_AD_B1_05__USDHC2_usdhc_data1 0x0110 0x0300 0x05ec 6 1
296#define IMXRT_PAD_GPIO_AD_B1_05__KPP_kpp_col5 0x0110 0x0300 0x0000 7 0
297#define IMXRT_PAD_GPIO_AD_B1_05__ADC1_IN10 0x0110 0x0300 0x0000 5 0
298#define IMXRT_PAD_GPIO_AD_B1_05__ADC2_IN10 0x0110 0x0300 0x0000 5 0
299#define IMXRT_PAD_GPIO_AD_B1_05__CMP4_IN3 0x0110 0x0300 0x0000 5 0
300
301/* GPIO_AD_B1_06 */
302#define IMXRT_PAD_GPIO_AD_B1_06__FLEXSPI_FLEXSPI_B_DATA1 0x0114 0x0304 0x04bc 0 1
303#define IMXRT_PAD_GPIO_AD_B1_06__LPI2C3_SDA 0x0114 0x0304 0x04e0 1 2
304#define IMXRT_PAD_GPIO_AD_B1_06__LPUART3_TX 0x0114 0x0304 0x053c 2 0
305#define IMXRT_PAD_GPIO_AD_B1_06__SPDIF_spdif_lock 0x0114 0x0304 0x0000 3 0
306#define IMXRT_PAD_GPIO_AD_B1_06__CSI_csi_vsync 0x0114 0x0304 0x0428 4 1
307#define IMXRT_PAD_GPIO_AD_B1_06__GPIO1_gpio_io22 0x0114 0x0304 0x0000 5 0
308#define IMXRT_PAD_GPIO_AD_B1_06__USDHC2_usdhc_data2 0x0114 0x0304 0x05f0 6 1
309#define IMXRT_PAD_GPIO_AD_B1_06__KPP_kpp_row4 0x0114 0x0304 0x0000 7 0
310#define IMXRT_PAD_GPIO_AD_B1_06__ADC1_IN11 0x0114 0x0304 0x0000 5 0
311#define IMXRT_PAD_GPIO_AD_B1_06__ADC2_IN11 0x0114 0x0304 0x0000 5 0
312#define IMXRT_PAD_GPIO_AD_B1_06__CMP1_IN1 0x0114 0x0304 0x0000 5 0
313#define IMXRT_PAD_GPIO_AD_B1_06__CMP2_IN1 0x0114 0x0304 0x0000 5 0
314#define IMXRT_PAD_GPIO_AD_B1_06__CMP3_IN1 0x0114 0x0304 0x0000 5 0
315#define IMXRT_PAD_GPIO_AD_B1_06__CMP4_IN1 0x0114 0x0304 0x0000 5 0
316
317/* GPIO_AD_B1_07 */
318#define IMXRT_PAD_GPIO_AD_B1_07__FLEXSPI_FLEXSPI_B_DATA0 0x0118 0x0308 0x04b8 0 1
319#define IMXRT_PAD_GPIO_AD_B1_07__LPI2C3_SCL 0x0118 0x0308 0x04dc 1 2
320#define IMXRT_PAD_GPIO_AD_B1_07__LPUART3_RX 0x0118 0x0308 0x0538 2 0
321#define IMXRT_PAD_GPIO_AD_B1_07__SPDIF_spdif_ext_clk 0x0118 0x0308 0x0000 3 0
322#define IMXRT_PAD_GPIO_AD_B1_07__CSI_csi_hsync 0x0118 0x0308 0x0420 4 1
323#define IMXRT_PAD_GPIO_AD_B1_07__GPIO1_gpio_io23 0x0118 0x0308 0x0000 5 0
324#define IMXRT_PAD_GPIO_AD_B1_07__USDHC2_usdhc_data3 0x0118 0x0308 0x05f4 6 1
325#define IMXRT_PAD_GPIO_AD_B1_07__KPP_kpp_col4 0x0118 0x0308 0x0000 7 0
326#define IMXRT_PAD_GPIO_AD_B1_07__ADC1_IN12 0x0118 0x0308 0x0000 5 0
327#define IMXRT_PAD_GPIO_AD_B1_07__ADC2_IN12 0x0118 0x0308 0x0000 5 0
328#define IMXRT_PAD_GPIO_AD_B1_07__CMP1_IN5 0x0118 0x0308 0x0000 5 0
329
330/* GPIO_AD_B1_08 */
331#define IMXRT_PAD_GPIO_AD_B1_08__FLEXSPI_FLEXSPI_A_SS1_B 0x011c 0x030c 0x0000 0 0
332#define IMXRT_PAD_GPIO_AD_B1_08__PWM4_A0 0x011c 0x030c 0x0494 1 1
333#define IMXRT_PAD_GPIO_AD_B1_08__CAN1_TX 0x011c 0x030c 0x0000 2 0
334#define IMXRT_PAD_GPIO_AD_B1_08__CCM_PMIC_RDY 0x011c 0x030c 0x03fc 3 3
335#define IMXRT_PAD_GPIO_AD_B1_08__CSI_csi_data09 0x011c 0x030c 0x041c 4 0
336#define IMXRT_PAD_GPIO_AD_B1_08__GPIO1_gpio_io24 0x011c 0x030c 0x0000 5 0
337#define IMXRT_PAD_GPIO_AD_B1_08__USDHC2_usdhc_cmd 0x011c 0x030c 0x05e4 6 1
338#define IMXRT_PAD_GPIO_AD_B1_08__KPP_kpp_row3 0x011c 0x030c 0x0000 7 0
339#define IMXRT_PAD_GPIO_AD_B1_08__ADC1_IN13 0x011c 0x030c 0x0000 5 0
340#define IMXRT_PAD_GPIO_AD_B1_08__ADC2_IN13 0x011c 0x030c 0x0000 5 0
341#define IMXRT_PAD_GPIO_AD_B1_08__CMP2_IN5 0x011c 0x030c 0x0000 5 0
342
343/* GPIO_AD_B1_09 */
344#define IMXRT_PAD_GPIO_AD_B1_09__FLEXSPI_FLEXSPI_A_DQS 0x0120 0x0310 0x04a4 0 1
345#define IMXRT_PAD_GPIO_AD_B1_09__PWM4_A1 0x0120 0x0310 0x0498 1 1
346#define IMXRT_PAD_GPIO_AD_B1_09__CAN1_RX 0x0120 0x0310 0x044c 2 2
347#define IMXRT_PAD_GPIO_AD_B1_09__SAI1_sai_mclk 0x0120 0x0310 0x058c 3 1
348#define IMXRT_PAD_GPIO_AD_B1_09__CSI_csi_data08 0x0120 0x0310 0x0418 4 0
349#define IMXRT_PAD_GPIO_AD_B1_09__GPIO1_gpio_io25 0x0120 0x0310 0x0000 5 0
350#define IMXRT_PAD_GPIO_AD_B1_09__USDHC2_usdhc_clk 0x0120 0x0310 0x05dc 6 1
351#define IMXRT_PAD_GPIO_AD_B1_09__KPP_kpp_col3 0x0120 0x0310 0x0000 7 0
352#define IMXRT_PAD_GPIO_AD_B1_09__ADC1_IN14 0x0120 0x0310 0x0000 5 0
353#define IMXRT_PAD_GPIO_AD_B1_09__ADC2_IN14 0x0120 0x0310 0x0000 5 0
354#define IMXRT_PAD_GPIO_AD_B1_09__CMP3_IN5 0x0120 0x0310 0x0000 5 0
355
356/* GPIO_AD_B1_10 */
357#define IMXRT_PAD_GPIO_AD_B1_10__FLEXSPI_FLEXSPI_A_DATA3 0x0124 0x0314 0x04b4 0 1
358#define IMXRT_PAD_GPIO_AD_B1_10__WDOG1_wdog_b 0x0124 0x0314 0x0000 1 0
359#define IMXRT_PAD_GPIO_AD_B1_10__LPUART8_TX 0x0124 0x0314 0x0564 2 1
360#define IMXRT_PAD_GPIO_AD_B1_10__SAI1_sai_rx_sync 0x0124 0x0314 0x05a4 3 1
361#define IMXRT_PAD_GPIO_AD_B1_10__CSI_csi_data07 0x0124 0x0314 0x0414 4 0
362#define IMXRT_PAD_GPIO_AD_B1_10__GPIO1_gpio_io26 0x0124 0x0314 0x0000 5 0
363#define IMXRT_PAD_GPIO_AD_B1_10__USDHC2_usdhc_wp 0x0124 0x0314 0x0608 6 1
364#define IMXRT_PAD_GPIO_AD_B1_10__KPP_kpp_row2 0x0124 0x0314 0x0000 7 0
365#define IMXRT_PAD_GPIO_AD_B1_10__ADC1_IN15 0x0124 0x0314 0x0000 5 0
366#define IMXRT_PAD_GPIO_AD_B1_10__ADC2_IN15 0x0124 0x0314 0x0000 5 0
367#define IMXRT_PAD_GPIO_AD_B1_10__CMP4_IN5 0x0124 0x0314 0x0000 5 0
368
369/* GPIO_AD_B1_11 */
370#define IMXRT_PAD_GPIO_AD_B1_11__FLEXSPI_FLEXSPI_A_DATA2 0x0128 0x0318 0x04b0 0 1
371#define IMXRT_PAD_GPIO_AD_B1_11__EWM_EWM_OUT_B 0x0128 0x0318 0x0000 1 0
372#define IMXRT_PAD_GPIO_AD_B1_11__LPUART8_RX 0x0128 0x0318 0x0560 2 1
373#define IMXRT_PAD_GPIO_AD_B1_11__SAI1_sai_rx_bclk 0x0128 0x0318 0x0590 3 1
374#define IMXRT_PAD_GPIO_AD_B1_11__CSI_csi_data06 0x0128 0x0318 0x0410 4 0
375#define IMXRT_PAD_GPIO_AD_B1_11__GPIO1_gpio_io27 0x0128 0x0318 0x0000 5 0
376#define IMXRT_PAD_GPIO_AD_B1_11__USDHC2_usdhc_reset_b 0x0128 0x0318 0x0000 6 0
377#define IMXRT_PAD_GPIO_AD_B1_11__KPP_kpp_col2 0x0128 0x0318 0x0000 7 0
378#define IMXRT_PAD_GPIO_AD_B1_11__ADC1_IN0 0x0128 0x0318 0x0000 5 0
379#define IMXRT_PAD_GPIO_AD_B1_11__ADC2_IN0 0x0128 0x0318 0x0000 5 0
380#define IMXRT_PAD_GPIO_AD_B1_11__CMP1_IN6 0x0128 0x0318 0x0000 5 0
381
382/* GPIO_AD_B1_12 */
383#define IMXRT_PAD_GPIO_AD_B1_12__FLEXSPI_FLEXSPI_A_DATA1 0x012c 0x031c 0x04ac 0 1
384#define IMXRT_PAD_GPIO_AD_B1_12__CMP1_OUT 0x012c 0x031c 0x0000 1 0
385#define IMXRT_PAD_GPIO_AD_B1_12__LPSPI3_PCS0 0x012c 0x031c 0x050c 2 1
386#define IMXRT_PAD_GPIO_AD_B1_12__SAI1_sai_rx_data0 0x012c 0x031c 0x0594 3 1
387#define IMXRT_PAD_GPIO_AD_B1_12__CSI_csi_data05 0x012c 0x031c 0x040c 4 0
388#define IMXRT_PAD_GPIO_AD_B1_12__GPIO1_gpio_io28 0x012c 0x031c 0x0000 5 0
389#define IMXRT_PAD_GPIO_AD_B1_12__USDHC2_usdhc_data4 0x012c 0x031c 0x05f8 6 1
390#define IMXRT_PAD_GPIO_AD_B1_12__KPP_kpp_row1 0x012c 0x031c 0x0000 7 0
391#define IMXRT_PAD_GPIO_AD_B1_12__ADC2_IN1 0x012c 0x031c 0x0000 5 0
392#define IMXRT_PAD_GPIO_AD_B1_12__CMP2_IN6 0x012c 0x031c 0x0000 5 0
393
394/* GPIO_AD_B1_13 */
395#define IMXRT_PAD_GPIO_AD_B1_13__FLEXSPI_FLEXSPI_A_DATA0 0x0130 0x0320 0x04a8 0 1
396#define IMXRT_PAD_GPIO_AD_B1_13__CMP2_OUT 0x0130 0x0320 0x0000 1 0
397#define IMXRT_PAD_GPIO_AD_B1_13__LPSPI3_SDI 0x0130 0x0320 0x0514 2 1
398#define IMXRT_PAD_GPIO_AD_B1_13__SAI1_sai_tx_data0 0x0130 0x0320 0x0000 3 0
399#define IMXRT_PAD_GPIO_AD_B1_13__CSI_csi_data04 0x0130 0x0320 0x0408 4 0
400#define IMXRT_PAD_GPIO_AD_B1_13__GPIO1_gpio_io29 0x0130 0x0320 0x0000 5 0
401#define IMXRT_PAD_GPIO_AD_B1_13__USDHC2_usdhc_data5 0x0130 0x0320 0x05fc 6 1
402#define IMXRT_PAD_GPIO_AD_B1_13__KPP_kpp_col1 0x0130 0x0320 0x0000 7 0
403#define IMXRT_PAD_GPIO_AD_B1_13__ADC2_IN2 0x0130 0x0320 0x0000 5 0
404#define IMXRT_PAD_GPIO_AD_B1_13__CMP3_IN6 0x0130 0x0320 0x0000 5 0
405
406/* GPIO_AD_B1_14 */
407#define IMXRT_PAD_GPIO_AD_B1_14__FLEXSPI_FLEXSPI_A_SCLK 0x0134 0x0324 0x04c8 0 1
408#define IMXRT_PAD_GPIO_AD_B1_14__CMP3_OUT 0x0134 0x0324 0x0000 1 0
409#define IMXRT_PAD_GPIO_AD_B1_14__LPSPI3_SDO 0x0134 0x0324 0x0518 2 1
410#define IMXRT_PAD_GPIO_AD_B1_14__SAI1_sai_tx_bclk 0x0134 0x0324 0x05a8 3 1
411#define IMXRT_PAD_GPIO_AD_B1_14__CSI_csi_data03 0x0134 0x0324 0x0404 4 0
412#define IMXRT_PAD_GPIO_AD_B1_14__GPIO1_gpio_io30 0x0134 0x0324 0x0000 5 0
413#define IMXRT_PAD_GPIO_AD_B1_14__USDHC2_usdhc_data6 0x0134 0x0324 0x0600 6 1
414#define IMXRT_PAD_GPIO_AD_B1_14__KPP_kpp_row0 0x0134 0x0324 0x0000 7 0
415#define IMXRT_PAD_GPIO_AD_B1_14__ADC2_IN3 0x0134 0x0324 0x0000 5 0
416#define IMXRT_PAD_GPIO_AD_B1_14__CMP4_IN6 0x0134 0x0324 0x0000 5 0
417
418/* GPIO_AD_B1_15 */
419#define IMXRT_PAD_GPIO_AD_B1_15__FLEXSPI_FLEXSPI_A_SS0_B 0x0138 0x0328 0x0000 0 0
420#define IMXRT_PAD_GPIO_AD_B1_15__CMP4_OUT 0x0138 0x0328 0x0000 1 0
421#define IMXRT_PAD_GPIO_AD_B1_15__LPSPI3_SCK 0x0138 0x0328 0x0000 2 0
422#define IMXRT_PAD_GPIO_AD_B1_15__SAI1_sai_tx_sync 0x0138 0x0328 0x05ac 3 1
423#define IMXRT_PAD_GPIO_AD_B1_15__CSI_csi_data02 0x0138 0x0328 0x0400 4 0
424#define IMXRT_PAD_GPIO_AD_B1_15__GPIO1_gpio_io31 0x0138 0x0328 0x0000 5 0
425#define IMXRT_PAD_GPIO_AD_B1_15__USDHC2_usdhc_data7 0x0138 0x0328 0x0604 6 1
426#define IMXRT_PAD_GPIO_AD_B1_15__KPP_kpp_col0 0x0138 0x0328 0x0000 7 0
427#define IMXRT_PAD_GPIO_AD_B1_15__ADC2_IN4 0x0138 0x0328 0x0000 5 0
428
429/* GPIO_B0_00 */
430#define IMXRT_PAD_GPIO_B0_00__LCDIF_lcdif_clk 0x013c 0x032c 0x0000 0 0
431#define IMXRT_PAD_GPIO_B0_00__TMR1_TIMER0 0x013c 0x032c 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER1_TRM0_INPUT_SEL to 0 */
432#define IMXRT_PAD_GPIO_B0_00__MQS_RIGHT 0x013c 0x032c 0x0000 2 0
433#define IMXRT_PAD_GPIO_B0_00__LPSPI4_PCS0 0x013c 0x032c 0x051c 3 0
434#define IMXRT_PAD_GPIO_B0_00__FLEXIO2_IO00 0x013c 0x032c 0x0000 4 0
435#define IMXRT_PAD_GPIO_B0_00__GPIO2_gpio_io00 0x013c 0x032c 0x0000 5 0
436#define IMXRT_PAD_GPIO_B0_00__SEMC_CSX1 0x013c 0x032c 0x0000 6 0
437
438/* GPIO_B0_01 */
439#define IMXRT_PAD_GPIO_B0_01__LCDIF_lcdif_enable 0x0140 0x0330 0x0000 0 0
440#define IMXRT_PAD_GPIO_B0_01__TMR1_TIMER1 0x0140 0x0330 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER1_TRM1_INPUT_SEL to 0 */
441#define IMXRT_PAD_GPIO_B0_01__MQS_LEFT 0x0140 0x0330 0x0000 2 0
442#define IMXRT_PAD_GPIO_B0_01__LPSPI4_SDI 0x0140 0x0330 0x0524 3 0
443#define IMXRT_PAD_GPIO_B0_01__FLEXIO2_IO01 0x0140 0x0330 0x0000 4 0
444#define IMXRT_PAD_GPIO_B0_01__GPIO2_gpio_io01 0x0140 0x0330 0x0000 5 0
445#define IMXRT_PAD_GPIO_B0_01__SEMC_CSX2 0x0140 0x0330 0x0000 6 0
446
447/* GPIO_B0_02 */
448#define IMXRT_PAD_GPIO_B0_02__LCDIF_lcdif_hsync 0x0144 0x0334 0x0000 0 0
449#define IMXRT_PAD_GPIO_B0_02__TMR1_TIMER2 0x0144 0x0334 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER1_TRM2_INPUT_SEL to 0 */
450#define IMXRT_PAD_GPIO_B0_02__CAN1_TX 0x0144 0x0334 0x0000 2 0
451#define IMXRT_PAD_GPIO_B0_02__LPSPI4_SDO 0x0144 0x0334 0x0528 3 0
452#define IMXRT_PAD_GPIO_B0_02__FLEXIO2_IO02 0x0144 0x0334 0x0000 4 0
453#define IMXRT_PAD_GPIO_B0_02__GPIO2_gpio_io02 0x0144 0x0334 0x0000 5 0
454#define IMXRT_PAD_GPIO_B0_02__SEMC_CSX3 0x0144 0x0334 0x0000 6 0
455
456/* GPIO_B0_03 */
457#define IMXRT_PAD_GPIO_B0_03__LCDIF_lcdif_vsync 0x0148 0x0338 0x0000 0 0
458#define IMXRT_PAD_GPIO_B0_03__TMR2_TIMER0 0x0148 0x0338 0x056c 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM0_INPUT_SEL to 0 */
459#define IMXRT_PAD_GPIO_B0_03__CAN1_RX 0x0148 0x0338 0x044c 2 3
460#define IMXRT_PAD_GPIO_B0_03__LPSPI4_SCK 0x0148 0x0338 0x0520 3 0
461#define IMXRT_PAD_GPIO_B0_03__FLEXIO2_IO03 0x0148 0x0338 0x0000 4 0
462#define IMXRT_PAD_GPIO_B0_03__GPIO2_gpio_io03 0x0148 0x0338 0x0000 5 0
463#define IMXRT_PAD_GPIO_B0_03__WDOG2_wdog_rst_b_deb 0x0148 0x0338 0x0000 6 0
464
465/* GPIO_B0_04 */
466#define IMXRT_PAD_GPIO_B0_04__LCDIF_lcdif_data00 0x014c 0x033c 0x0000 0 0
467#define IMXRT_PAD_GPIO_B0_04__TMR2_TIMER1 0x014c 0x033c 0x0570 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM1_INPUT_SEL to 0 */
468#define IMXRT_PAD_GPIO_B0_04__LPI2C2_SCL 0x014c 0x033c 0x04d4 2 1
469#define IMXRT_PAD_GPIO_B0_04__ARM_TRACE0 0x014c 0x033c 0x0000 3 0
470#define IMXRT_PAD_GPIO_B0_04__FLEXIO2_IO04 0x014c 0x033c 0x0000 4 0
471#define IMXRT_PAD_GPIO_B0_04__GPIO2_gpio_io04 0x014c 0x033c 0x0000 5 0
472#define IMXRT_PAD_GPIO_B0_04__SRC_BOOT_CFG0 0x014c 0x033c 0x0000 6 0
473
474/* GPIO_B0_05 */
475#define IMXRT_PAD_GPIO_B0_05__LCDIF_lcdif_data01 0x0150 0x0340 0x0000 0 0
476#define IMXRT_PAD_GPIO_B0_05__TMR2_TIMER2 0x0150 0x0340 0x0574 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM2_INPUT_SEL to 0 */
477#define IMXRT_PAD_GPIO_B0_05__LPI2C2_SDA 0x0150 0x0340 0x04d8 2 1
478#define IMXRT_PAD_GPIO_B0_05__ARM_TRACE1 0x0150 0x0340 0x0000 3 0
479#define IMXRT_PAD_GPIO_B0_05__FLEXIO2_IO05 0x0150 0x0340 0x0000 4 0
480#define IMXRT_PAD_GPIO_B0_05__GPIO2_gpio_io05 0x0150 0x0340 0x0000 5 0
481#define IMXRT_PAD_GPIO_B0_05__SRC_BOOT_CFG1 0x0150 0x0340 0x0000 6 0
482
483/* GPIO_B0_06 */
484#define IMXRT_PAD_GPIO_B0_06__LCDIF_lcdif_data02 0x0154 0x0344 0x0000 0 0
485#define IMXRT_PAD_GPIO_B0_06__TMR3_TIMER0 0x0154 0x0344 0x057c 1 2 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM0_INPUT_SEL to 0 */
486#define IMXRT_PAD_GPIO_B0_06__PWM2_A0 0x0154 0x0344 0x0478 2 1
487#define IMXRT_PAD_GPIO_B0_06__ARM_TRACE2 0x0154 0x0344 0x0000 3 0
488#define IMXRT_PAD_GPIO_B0_06__FLEXIO2_IO06 0x0154 0x0344 0x0000 4 0
489#define IMXRT_PAD_GPIO_B0_06__GPIO2_gpio_io06 0x0154 0x0344 0x0000 5 0
490#define IMXRT_PAD_GPIO_B0_06__SRC_BOOT_CFG2 0x0154 0x0344 0x0000 6 0
491
492/* GPIO_B0_07 */
493#define IMXRT_PAD_GPIO_B0_07__LCDIF_lcdif_data03 0x0158 0x0348 0x0000 0 0
494#define IMXRT_PAD_GPIO_B0_07__TMR3_TIMER1 0x0158 0x0348 0x0580 1 2 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM1_INPUT_SEL to 0 */
495#define IMXRT_PAD_GPIO_B0_07__PWM2_B0 0x0158 0x0348 0x0488 2 1
496#define IMXRT_PAD_GPIO_B0_07__ARM_TRACE3 0x0158 0x0348 0x0000 3 0
497#define IMXRT_PAD_GPIO_B0_07__FLEXIO2_IO07 0x0158 0x0348 0x0000 4 0
498#define IMXRT_PAD_GPIO_B0_07__GPIO2_gpio_io07 0x0158 0x0348 0x0000 5 0
499#define IMXRT_PAD_GPIO_B0_07__SRC_BOOT_CFG3 0x0158 0x0348 0x0000 6 0
500
501/* GPIO_B0_08 */
502#define IMXRT_PAD_GPIO_B0_08__LCDIF_lcdif_data04 0x015c 0x034c 0x0000 0 0
503#define IMXRT_PAD_GPIO_B0_08__TMR3_TIMER2 0x015c 0x034c 0x0584 1 2 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM2_INPUT_SEL to 0 */
504#define IMXRT_PAD_GPIO_B0_08__PWM2_A1 0x015c 0x034c 0x047c 2 1
505#define IMXRT_PAD_GPIO_B0_08__LPUART3_TX 0x015c 0x034c 0x053c 3 2
506#define IMXRT_PAD_GPIO_B0_08__FLEXIO2_IO08 0x015c 0x034c 0x0000 4 0
507#define IMXRT_PAD_GPIO_B0_08__GPIO2_gpio_io08 0x015c 0x034c 0x0000 5 0
508#define IMXRT_PAD_GPIO_B0_08__SRC_BOOT_CFG4 0x015c 0x034c 0x0000 6 0
509
510/* GPIO_B0_09 */
511#define IMXRT_PAD_GPIO_B0_09__LCDIF_lcdif_data05 0x0160 0x0350 0x0000 0 0
512#define IMXRT_PAD_GPIO_B0_09__TMR4_TIMER0 0x0160 0x0350 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER4_TRM0_INPUT_SEL to 0 */
513#define IMXRT_PAD_GPIO_B0_09__PWM2_B1 0x0160 0x0350 0x048c 2 1
514#define IMXRT_PAD_GPIO_B0_09__LPUART3_RX 0x0160 0x0350 0x0538 3 2
515#define IMXRT_PAD_GPIO_B0_09__FLEXIO2_IO09 0x0160 0x0350 0x0000 4 0
516#define IMXRT_PAD_GPIO_B0_09__GPIO2_gpio_io09 0x0160 0x0350 0x0000 5 0
517#define IMXRT_PAD_GPIO_B0_09__SRC_BOOT_CFG5 0x0160 0x0350 0x0000 6 0
518
519/* GPIO_B0_10 */
520#define IMXRT_PAD_GPIO_B0_10__LCDIF_lcdif_data06 0x0164 0x0354 0x0000 0 0
521#define IMXRT_PAD_GPIO_B0_10__TMR4_TIMER1 0x0164 0x0354 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER4_TRM1_INPUT_SEL to 0 */
522#define IMXRT_PAD_GPIO_B0_10__PWM2_A2 0x0164 0x0354 0x0480 2 1
523#define IMXRT_PAD_GPIO_B0_10__SAI1_sai_tx_data3 0x0164 0x0354 0x0598 3 1
524#define IMXRT_PAD_GPIO_B0_10__FLEXIO2_IO10 0x0164 0x0354 0x0000 4 0
525#define IMXRT_PAD_GPIO_B0_10__GPIO2_gpio_io10 0x0164 0x0354 0x0000 5 0
526#define IMXRT_PAD_GPIO_B0_10__SRC_BOOT_CFG6 0x0164 0x0354 0x0000 6 0
527
528/* GPIO_B0_11 */
529#define IMXRT_PAD_GPIO_B0_11__LCDIF_lcdif_data07 0x0168 0x0358 0x0000 0 0
530#define IMXRT_PAD_GPIO_B0_11__TMR4_TIMER2 0x0168 0x0358 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER4_TRM2_INPUT_SEL to 0 */
531#define IMXRT_PAD_GPIO_B0_11__PWM2_B2 0x0168 0x0358 0x0490 2 1
532#define IMXRT_PAD_GPIO_B0_11__SAI1_sai_tx_data2 0x0168 0x0358 0x059c 3 1
533#define IMXRT_PAD_GPIO_B0_11__FLEXIO2_IO11 0x0168 0x0358 0x0000 4 0
534#define IMXRT_PAD_GPIO_B0_11__GPIO2_gpio_io11 0x0168 0x0358 0x0000 5 0
535#define IMXRT_PAD_GPIO_B0_11__SRC_BOOT_CFG7 0x0168 0x0358 0x0000 6 0
536
537/* GPIO_B0_12 */
538#define IMXRT_PAD_GPIO_B0_12__LCDIF_lcdif_data08 0x016c 0x035c 0x0000 0 0
539#define IMXRT_PAD_GPIO_B0_12__XBARA1_OUT10 0x016c 0x035c 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_10 to 0x1 */
540#define IMXRT_PAD_GPIO_B0_12__XBARA1_IN10 0x016c 0x035c 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_10 to 0 */
541#define IMXRT_PAD_GPIO_B0_12__ARM_arm_trace_clk 0x016c 0x035c 0x0000 2 0
542#define IMXRT_PAD_GPIO_B0_12__SAI1_sai_tx_data1 0x016c 0x035c 0x05a0 3 1
543#define IMXRT_PAD_GPIO_B0_12__FLEXIO2_IO12 0x016c 0x035c 0x0000 4 0
544#define IMXRT_PAD_GPIO_B0_12__GPIO2_gpio_io12 0x016c 0x035c 0x0000 5 0
545#define IMXRT_PAD_GPIO_B0_12__SRC_BOOT_CFG8 0x016c 0x035c 0x0000 6 0
546
547/* GPIO_B0_13 */
548#define IMXRT_PAD_GPIO_B0_13__LCDIF_lcdif_data09 0x0170 0x0360 0x0000 0 0
549#define IMXRT_PAD_GPIO_B0_13__XBARA1_OUT11 0x0170 0x0360 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_11 to 0x1 */
550#define IMXRT_PAD_GPIO_B0_13__XBARA1_IN11 0x0170 0x0360 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_11 to 0 */
551#define IMXRT_PAD_GPIO_B0_13__ARM_arm_trace_swo 0x0170 0x0360 0x0000 2 0
552#define IMXRT_PAD_GPIO_B0_13__SAI1_sai_mclk 0x0170 0x0360 0x058c 3 2
553#define IMXRT_PAD_GPIO_B0_13__FLEXIO2_IO13 0x0170 0x0360 0x0000 4 0
554#define IMXRT_PAD_GPIO_B0_13__GPIO2_gpio_io13 0x0170 0x0360 0x0000 5 0
555#define IMXRT_PAD_GPIO_B0_13__SRC_BOOT_CFG9 0x0170 0x0360 0x0000 6 0
556
557/* GPIO_B0_14 */
558#define IMXRT_PAD_GPIO_B0_14__LCDIF_lcdif_data10 0x0174 0x0364 0x0000 0 0
559#define IMXRT_PAD_GPIO_B0_14__XBARA1_OUT12 0x0174 0x0364 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_12 to 0x1 */
560#define IMXRT_PAD_GPIO_B0_14__XBARA1_IN12 0x0174 0x0364 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_12 to 0 */
561#define IMXRT_PAD_GPIO_B0_14__ARM_arm_cm7_txev 0x0174 0x0364 0x0000 2 0
562#define IMXRT_PAD_GPIO_B0_14__SAI1_sai_rx_sync 0x0174 0x0364 0x05a4 3 2
563#define IMXRT_PAD_GPIO_B0_14__FLEXIO2_IO14 0x0174 0x0364 0x0000 4 0
564#define IMXRT_PAD_GPIO_B0_14__GPIO2_gpio_io14 0x0174 0x0364 0x0000 5 0
565#define IMXRT_PAD_GPIO_B0_14__SRC_BOOT_CFG10 0x0174 0x0364 0x0000 6 0
566
567/* GPIO_B0_15 */
568#define IMXRT_PAD_GPIO_B0_15__LCDIF_lcdif_data11 0x0178 0x0368 0x0000 0 0
569#define IMXRT_PAD_GPIO_B0_15__XBARA1_OUT13 0x0178 0x0368 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_13 to 0x1 */
570#define IMXRT_PAD_GPIO_B0_15__XBARA1_IN13 0x0178 0x0368 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_13 to 0 */
571#define IMXRT_PAD_GPIO_B0_15__ARM_arm_cm7_rxev 0x0178 0x0368 0x0000 2 0
572#define IMXRT_PAD_GPIO_B0_15__SAI1_sai_rx_bclk 0x0178 0x0368 0x0590 3 2
573#define IMXRT_PAD_GPIO_B0_15__FLEXIO2_IO15 0x0178 0x0368 0x0000 4 0
574#define IMXRT_PAD_GPIO_B0_15__GPIO2_gpio_io15 0x0178 0x0368 0x0000 5 0
575#define IMXRT_PAD_GPIO_B0_15__SRC_BOOT_CFG11 0x0178 0x0368 0x0000 6 0
576
577/* GPIO_B1_00 */
578#define IMXRT_PAD_GPIO_B1_00__LCDIF_lcdif_data12 0x017c 0x036c 0x0000 0 0
579#define IMXRT_PAD_GPIO_B1_00__XBARA1_OUT14 0x017c 0x036c 0x0644 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_14 to 0x1 */
580#define IMXRT_PAD_GPIO_B1_00__XBARA1_IN14 0x017c 0x036c 0x0644 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_14 to 0 */
581#define IMXRT_PAD_GPIO_B1_00__LPUART4_TX 0x017c 0x036c 0x0544 2 2
582#define IMXRT_PAD_GPIO_B1_00__SAI1_sai_rx_data0 0x017c 0x036c 0x0594 3 2
583#define IMXRT_PAD_GPIO_B1_00__FLEXIO2_IO16 0x017c 0x036c 0x0000 4 0
584#define IMXRT_PAD_GPIO_B1_00__GPIO2_gpio_io16 0x017c 0x036c 0x0000 5 0
585#define IMXRT_PAD_GPIO_B1_00__PWM1_A3 0x017c 0x036c 0x0454 6 4
586
587/* GPIO_B1_01 */
588#define IMXRT_PAD_GPIO_B1_01__LCDIF_lcdif_data13 0x0180 0x0370 0x0000 0 0
589#define IMXRT_PAD_GPIO_B1_01__XBARA1_OUT15 0x0180 0x0370 0x0648 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_15 to 0x1 */
590#define IMXRT_PAD_GPIO_B1_01__XBARA1_IN15 0x0180 0x0370 0x0648 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_15 to 0 */
591#define IMXRT_PAD_GPIO_B1_01__LPUART4_RX 0x0180 0x0370 0x0540 2 2
592#define IMXRT_PAD_GPIO_B1_01__SAI1_sai_tx_data0 0x0180 0x0370 0x0000 3 0
593#define IMXRT_PAD_GPIO_B1_01__FLEXIO2_IO17 0x0180 0x0370 0x0000 4 0
594#define IMXRT_PAD_GPIO_B1_01__GPIO2_gpio_io17 0x0180 0x0370 0x0000 5 0
595#define IMXRT_PAD_GPIO_B1_01__PWM1_B3 0x0180 0x0370 0x0464 6 4
596
597/* GPIO_B1_02 */
598#define IMXRT_PAD_GPIO_B1_02__LCDIF_lcdif_data14 0x0184 0x0374 0x0000 0 0
599#define IMXRT_PAD_GPIO_B1_02__XBARA1_OUT16 0x0184 0x0374 0x064c 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_16 to 0x1 */
600#define IMXRT_PAD_GPIO_B1_02__XBARA1_IN16 0x0184 0x0374 0x064c 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_16 to 0 */
601#define IMXRT_PAD_GPIO_B1_02__LPSPI4_PCS2 0x0184 0x0374 0x0000 2 0
602#define IMXRT_PAD_GPIO_B1_02__SAI1_sai_tx_bclk 0x0184 0x0374 0x05a8 3 2
603#define IMXRT_PAD_GPIO_B1_02__FLEXIO2_IO18 0x0184 0x0374 0x0000 4 0
604#define IMXRT_PAD_GPIO_B1_02__GPIO2_gpio_io18 0x0184 0x0374 0x0000 5 0
605#define IMXRT_PAD_GPIO_B1_02__PWM2_A3 0x0184 0x0374 0x0474 6 4
606
607/* GPIO_B1_03 */
608#define IMXRT_PAD_GPIO_B1_03__LCDIF_lcdif_data15 0x0188 0x0378 0x0000 0 0
609#define IMXRT_PAD_GPIO_B1_03__XBARA1_OUT17 0x0188 0x0378 0x062c 1 3 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0x1 */
610#define IMXRT_PAD_GPIO_B1_03__XBARA1_IN17 0x0188 0x0378 0x062c 1 3 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0 */
611#define IMXRT_PAD_GPIO_B1_03__LPSPI4_PCS1 0x0188 0x0378 0x0000 2 0
612#define IMXRT_PAD_GPIO_B1_03__SAI1_sai_tx_sync 0x0188 0x0378 0x05ac 3 2
613#define IMXRT_PAD_GPIO_B1_03__FLEXIO2_IO19 0x0188 0x0378 0x0000 4 0
614#define IMXRT_PAD_GPIO_B1_03__GPIO2_gpio_io19 0x0188 0x0378 0x0000 5 0
615#define IMXRT_PAD_GPIO_B1_03__PWM2_B3 0x0188 0x0378 0x0484 6 3
616
617/* GPIO_B1_04 */
618#define IMXRT_PAD_GPIO_B1_04__LCDIF_lcdif_data16 0x018c 0x037c 0x0000 0 0
619#define IMXRT_PAD_GPIO_B1_04__LPSPI4_PCS0 0x018c 0x037c 0x051c 1 1
620#define IMXRT_PAD_GPIO_B1_04__CSI_csi_data15 0x018c 0x037c 0x0000 2 0
621#define IMXRT_PAD_GPIO_B1_04__ENET_enet_rx_data0 0x018c 0x037c 0x0434 3 1
622#define IMXRT_PAD_GPIO_B1_04__FLEXIO2_IO20 0x018c 0x037c 0x0000 4 0
623#define IMXRT_PAD_GPIO_B1_04__GPIO2_gpio_io20 0x018c 0x037c 0x0000 5 0
624
625/* GPIO_B1_05 */
626#define IMXRT_PAD_GPIO_B1_05__LCDIF_lcdif_data17 0x0190 0x0380 0x0000 0 0
627#define IMXRT_PAD_GPIO_B1_05__LPSPI4_SDI 0x0190 0x0380 0x0524 1 1
628#define IMXRT_PAD_GPIO_B1_05__CSI_csi_data14 0x0190 0x0380 0x0000 2 0
629#define IMXRT_PAD_GPIO_B1_05__ENET_enet_rx_data1 0x0190 0x0380 0x0438 3 1
630#define IMXRT_PAD_GPIO_B1_05__FLEXIO2_IO21 0x0190 0x0380 0x0000 4 0
631#define IMXRT_PAD_GPIO_B1_05__GPIO2_gpio_io21 0x0190 0x0380 0x0000 5 0
632
633/* GPIO_B1_06 */
634#define IMXRT_PAD_GPIO_B1_06__LCDIF_lcdif_data18 0x0194 0x0384 0x0000 0 0
635#define IMXRT_PAD_GPIO_B1_06__LPSPI4_SDO 0x0194 0x0384 0x0528 1 1
636#define IMXRT_PAD_GPIO_B1_06__CSI_csi_data13 0x0194 0x0384 0x0000 2 0
637#define IMXRT_PAD_GPIO_B1_06__ENET_enet_rx_en 0x0194 0x0384 0x043c 3 1
638#define IMXRT_PAD_GPIO_B1_06__FLEXIO2_IO22 0x0194 0x0384 0x0000 4 0
639#define IMXRT_PAD_GPIO_B1_06__GPIO2_gpio_io22 0x0194 0x0384 0x0000 5 0
640
641/* GPIO_B1_07 */
642#define IMXRT_PAD_GPIO_B1_07__LCDIF_lcdif_data19 0x0198 0x0388 0x0000 0 0
643#define IMXRT_PAD_GPIO_B1_07__LPSPI4_SCK 0x0198 0x0388 0x0520 1 1
644#define IMXRT_PAD_GPIO_B1_07__CSI_csi_data12 0x0198 0x0388 0x0000 2 0
645#define IMXRT_PAD_GPIO_B1_07__ENET_enet_tx_data0 0x0198 0x0388 0x0000 3 0
646#define IMXRT_PAD_GPIO_B1_07__FLEXIO2_IO23 0x0198 0x0388 0x0000 4 0
647#define IMXRT_PAD_GPIO_B1_07__GPIO2_gpio_io23 0x0198 0x0388 0x0000 5 0
648
649/* GPIO_B1_08 */
650#define IMXRT_PAD_GPIO_B1_08__LCDIF_lcdif_data20 0x019c 0x038c 0x0000 0 0
651#define IMXRT_PAD_GPIO_B1_08__TMR1_TIMER3 0x019c 0x038c 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER1_TRM3_INPUT_SEL to 0 */
652#define IMXRT_PAD_GPIO_B1_08__CSI_csi_data11 0x019c 0x038c 0x0000 2 0
653#define IMXRT_PAD_GPIO_B1_08__ENET_enet_tx_data1 0x019c 0x038c 0x0000 3 0
654#define IMXRT_PAD_GPIO_B1_08__FLEXIO2_IO24 0x019c 0x038c 0x0000 4 0
655#define IMXRT_PAD_GPIO_B1_08__GPIO2_gpio_io24 0x019c 0x038c 0x0000 5 0
656#define IMXRT_PAD_GPIO_B1_08__CAN2_TX 0x019c 0x038c 0x0000 6 0
657
658/* GPIO_B1_09 */
659#define IMXRT_PAD_GPIO_B1_09__LCDIF_lcdif_data21 0x01a0 0x0390 0x0000 0 0
660#define IMXRT_PAD_GPIO_B1_09__TMR2_TIMER3 0x01a0 0x0390 0x0578 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM3_INPUT_SEL to 0 */
661#define IMXRT_PAD_GPIO_B1_09__CSI_csi_data10 0x01a0 0x0390 0x0000 2 0
662#define IMXRT_PAD_GPIO_B1_09__ENET_enet_tx_en 0x01a0 0x0390 0x0000 3 0
663#define IMXRT_PAD_GPIO_B1_09__FLEXIO2_IO25 0x01a0 0x0390 0x0000 4 0
664#define IMXRT_PAD_GPIO_B1_09__GPIO2_gpio_io25 0x01a0 0x0390 0x0000 5 0
665#define IMXRT_PAD_GPIO_B1_09__CAN2_RX 0x01a0 0x0390 0x0450 6 3
666
667/* GPIO_B1_10 */
668#define IMXRT_PAD_GPIO_B1_10__LCDIF_lcdif_data22 0x01a4 0x0394 0x0000 0 0
669#define IMXRT_PAD_GPIO_B1_10__TMR3_TIMER3 0x01a4 0x0394 0x0588 1 2 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM3_INPUT_SEL to 0 */
670#define IMXRT_PAD_GPIO_B1_10__CSI_csi_data00 0x01a4 0x0394 0x0000 2 0
671#define IMXRT_PAD_GPIO_B1_10__ENET_enet_tx_clk 0x01a4 0x0394 0x0448 3 1
672#define IMXRT_PAD_GPIO_B1_10__FLEXIO2_IO26 0x01a4 0x0394 0x0000 4 0
673#define IMXRT_PAD_GPIO_B1_10__GPIO2_gpio_io26 0x01a4 0x0394 0x0000 5 0
674#define IMXRT_PAD_GPIO_B1_10__ENET_enet_ref_clk 0x01a4 0x0394 0x042c 6 1
675
676/* GPIO_B1_11 */
677#define IMXRT_PAD_GPIO_B1_11__LCDIF_lcdif_data23 0x01a8 0x0398 0x0000 0 0
678#define IMXRT_PAD_GPIO_B1_11__TMR4_TIMER3 0x01a8 0x0398 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER4_TRM3_INPUT_SEL to 0 */
679#define IMXRT_PAD_GPIO_B1_11__CSI_csi_data01 0x01a8 0x0398 0x0000 2 0
680#define IMXRT_PAD_GPIO_B1_11__ENET_enet_rx_er 0x01a8 0x0398 0x0440 3 1
681#define IMXRT_PAD_GPIO_B1_11__FLEXIO2_IO27 0x01a8 0x0398 0x0000 4 0
682#define IMXRT_PAD_GPIO_B1_11__GPIO2_gpio_io27 0x01a8 0x0398 0x0000 5 0
683#define IMXRT_PAD_GPIO_B1_11__LPSPI4_PCS3 0x01a8 0x0398 0x0000 6 0
684
685/* GPIO_B1_12 */
686#define IMXRT_PAD_GPIO_B1_12__LPUART5_TX 0x01ac 0x039c 0x054c 1 1
687#define IMXRT_PAD_GPIO_B1_12__CSI_csi_pixclk 0x01ac 0x039c 0x0424 2 1
688#define IMXRT_PAD_GPIO_B1_12__ENET_1588_EVENT0_IN 0x01ac 0x039c 0x0444 3 2
689#define IMXRT_PAD_GPIO_B1_12__FLEXIO2_IO28 0x01ac 0x039c 0x0000 4 0
690#define IMXRT_PAD_GPIO_B1_12__GPIO2_gpio_io28 0x01ac 0x039c 0x0000 5 0
691#define IMXRT_PAD_GPIO_B1_12__USDHC1_usdhc_cd_b 0x01ac 0x039c 0x05d4 6 2
692
693/* GPIO_B1_13 */
694#define IMXRT_PAD_GPIO_B1_13__WDOG1_wdog_b 0x01b0 0x03a0 0x0000 0 0
695#define IMXRT_PAD_GPIO_B1_13__LPUART5_RX 0x01b0 0x03a0 0x0548 1 1
696#define IMXRT_PAD_GPIO_B1_13__CSI_csi_vsync 0x01b0 0x03a0 0x0428 2 2
697#define IMXRT_PAD_GPIO_B1_13__ENET_1588_EVENT0_OUT 0x01b0 0x03a0 0x0000 3 0
698#define IMXRT_PAD_GPIO_B1_13__FLEXIO2_IO29 0x01b0 0x03a0 0x0000 4 0
699#define IMXRT_PAD_GPIO_B1_13__GPIO2_gpio_io29 0x01b0 0x03a0 0x0000 5 0
700#define IMXRT_PAD_GPIO_B1_13__USDHC1_usdhc_wp 0x01b0 0x03a0 0x05d8 6 3
701
702/* GPIO_B1_14 */
703#define IMXRT_PAD_GPIO_B1_14__ENET_enet_mdc 0x01b4 0x03a4 0x0000 0 0
704#define IMXRT_PAD_GPIO_B1_14__PWM4_A2 0x01b4 0x03a4 0x049c 1 1
705#define IMXRT_PAD_GPIO_B1_14__CSI_csi_hsync 0x01b4 0x03a4 0x0420 2 2
706#define IMXRT_PAD_GPIO_B1_14__XBARA1_IN02 0x01b4 0x03a4 0x060c 3 1
707#define IMXRT_PAD_GPIO_B1_14__FLEXIO2_IO30 0x01b4 0x03a4 0x0000 4 0
708#define IMXRT_PAD_GPIO_B1_14__GPIO2_gpio_io30 0x01b4 0x03a4 0x0000 5 0
709#define IMXRT_PAD_GPIO_B1_14__USDHC1_usdhc_vselect 0x01b4 0x03a4 0x0000 6 0
710
711/* GPIO_B1_15 */
712#define IMXRT_PAD_GPIO_B1_15__ENET_enet_mdio 0x01b8 0x03a8 0x0430 0 2
713#define IMXRT_PAD_GPIO_B1_15__PWM4_A3 0x01b8 0x03a8 0x04a0 1 1
714#define IMXRT_PAD_GPIO_B1_15__CSI_csi_mclk 0x01b8 0x03a8 0x0000 2 0
715#define IMXRT_PAD_GPIO_B1_15__XBARA1_IN03 0x01b8 0x03a8 0x0610 3 1
716#define IMXRT_PAD_GPIO_B1_15__FLEXIO2_IO31 0x01b8 0x03a8 0x0000 4 0
717#define IMXRT_PAD_GPIO_B1_15__GPIO2_gpio_io31 0x01b8 0x03a8 0x0000 5 0
718#define IMXRT_PAD_GPIO_B1_15__USDHC1_usdhc_reset_b 0x01b8 0x03a8 0x0000 6 0
719
720/* GPIO_EMC_00 */
721#define IMXRT_PAD_GPIO_EMC_00__SEMC_DATA00 0x0014 0x0204 0x0000 0 0
722#define IMXRT_PAD_GPIO_EMC_00__PWM4_A0 0x0014 0x0204 0x0494 1 0
723#define IMXRT_PAD_GPIO_EMC_00__LPSPI2_SCK 0x0014 0x0204 0x0500 2 1
724#define IMXRT_PAD_GPIO_EMC_00__XBARA1_IN02 0x0014 0x0204 0x060c 3 0
725#define IMXRT_PAD_GPIO_EMC_00__FLEXIO1_IO00 0x0014 0x0204 0x0000 4 0
726#define IMXRT_PAD_GPIO_EMC_00__GPIO4_gpio_io00 0x0014 0x0204 0x0000 5 0
727
728/* GPIO_EMC_01 */
729#define IMXRT_PAD_GPIO_EMC_01__SEMC_DATA01 0x0018 0x0208 0x0000 0 0
730#define IMXRT_PAD_GPIO_EMC_01__PWM4_B0 0x0018 0x0208 0x0000 1 0
731#define IMXRT_PAD_GPIO_EMC_01__LPSPI2_PCS0 0x0018 0x0208 0x04fc 2 1
732#define IMXRT_PAD_GPIO_EMC_01__XBARA1_IN03 0x0018 0x0208 0x0610 3 0
733#define IMXRT_PAD_GPIO_EMC_01__FLEXIO1_IO01 0x0018 0x0208 0x0000 4 0
734#define IMXRT_PAD_GPIO_EMC_01__GPIO4_gpio_io01 0x0018 0x0208 0x0000 5 0
735
736/* GPIO_EMC_02 */
737#define IMXRT_PAD_GPIO_EMC_02__SEMC_DATA02 0x001c 0x020c 0x0000 0 0
738#define IMXRT_PAD_GPIO_EMC_02__PWM4_A1 0x001c 0x020c 0x0498 1 0
739#define IMXRT_PAD_GPIO_EMC_02__LPSPI2_SDO 0x001c 0x020c 0x0508 2 1
740#define IMXRT_PAD_GPIO_EMC_02__XBARA1_OUT04 0x001c 0x020c 0x0614 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_4 to 0x1 */
741#define IMXRT_PAD_GPIO_EMC_02__XBARA1_IN04 0x001c 0x020c 0x0614 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_4 to 0 */
742#define IMXRT_PAD_GPIO_EMC_02__FLEXIO1_IO02 0x001c 0x020c 0x0000 4 0
743#define IMXRT_PAD_GPIO_EMC_02__GPIO4_gpio_io02 0x001c 0x020c 0x0000 5 0
744
745/* GPIO_EMC_03 */
746#define IMXRT_PAD_GPIO_EMC_03__SEMC_DATA03 0x0020 0x0210 0x0000 0 0
747#define IMXRT_PAD_GPIO_EMC_03__PWM4_B1 0x0020 0x0210 0x0000 1 0
748#define IMXRT_PAD_GPIO_EMC_03__LPSPI2_SDI 0x0020 0x0210 0x0504 2 1
749#define IMXRT_PAD_GPIO_EMC_03__XBARA1_OUT05 0x0020 0x0210 0x0618 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_5 to 0x1 */
750#define IMXRT_PAD_GPIO_EMC_03__XBARA1_IN05 0x0020 0x0210 0x0618 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_5 to 0 */
751#define IMXRT_PAD_GPIO_EMC_03__FLEXIO1_IO03 0x0020 0x0210 0x0000 4 0
752#define IMXRT_PAD_GPIO_EMC_03__GPIO4_gpio_io03 0x0020 0x0210 0x0000 5 0
753
754/* GPIO_EMC_04 */
755#define IMXRT_PAD_GPIO_EMC_04__SEMC_DATA04 0x0024 0x0214 0x0000 0 0
756#define IMXRT_PAD_GPIO_EMC_04__PWM4_A2 0x0024 0x0214 0x049c 1 0
757#define IMXRT_PAD_GPIO_EMC_04__SAI2_sai_tx_data 0x0024 0x0214 0x0000 2 0
758#define IMXRT_PAD_GPIO_EMC_04__XBARA1_OUT06 0x0024 0x0214 0x061c 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_6 to 0x1 */
759#define IMXRT_PAD_GPIO_EMC_04__XBARA1_IN06 0x0024 0x0214 0x061c 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_6 to 0 */
760#define IMXRT_PAD_GPIO_EMC_04__FLEXIO1_IO04 0x0024 0x0214 0x0000 4 0
761#define IMXRT_PAD_GPIO_EMC_04__GPIO4_gpio_io04 0x0024 0x0214 0x0000 5 0
762
763/* GPIO_EMC_05 */
764#define IMXRT_PAD_GPIO_EMC_05__SEMC_DATA05 0x0028 0x0218 0x0000 0 0
765#define IMXRT_PAD_GPIO_EMC_05__PWM4_B2 0x0028 0x0218 0x0000 1 0
766#define IMXRT_PAD_GPIO_EMC_05__SAI2_sai_tx_sync 0x0028 0x0218 0x05c4 2 0
767#define IMXRT_PAD_GPIO_EMC_05__XBARA1_OUT07 0x0028 0x0218 0x0620 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_7 to 0x1 */
768#define IMXRT_PAD_GPIO_EMC_05__XBARA1_IN07 0x0028 0x0218 0x0620 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_7 to 0 */
769#define IMXRT_PAD_GPIO_EMC_05__FLEXIO1_IO05 0x0028 0x0218 0x0000 4 0
770#define IMXRT_PAD_GPIO_EMC_05__GPIO4_gpio_io05 0x0028 0x0218 0x0000 5 0
771
772/* GPIO_EMC_06 */
773#define IMXRT_PAD_GPIO_EMC_06__SEMC_DATA06 0x002c 0x021c 0x0000 0 0
774#define IMXRT_PAD_GPIO_EMC_06__PWM2_A0 0x002c 0x021c 0x0478 1 0
775#define IMXRT_PAD_GPIO_EMC_06__SAI2_sai_tx_bclk 0x002c 0x021c 0x05c0 2 0
776#define IMXRT_PAD_GPIO_EMC_06__XBARA1_OUT08 0x002c 0x021c 0x0624 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_8 to 0x1 */
777#define IMXRT_PAD_GPIO_EMC_06__XBARA1_IN08 0x002c 0x021c 0x0624 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_8 to 0 */
778#define IMXRT_PAD_GPIO_EMC_06__FLEXIO1_IO06 0x002c 0x021c 0x0000 4 0
779#define IMXRT_PAD_GPIO_EMC_06__GPIO4_gpio_io06 0x002c 0x021c 0x0000 5 0
780
781/* GPIO_EMC_07 */
782#define IMXRT_PAD_GPIO_EMC_07__SEMC_DATA07 0x0030 0x0220 0x0000 0 0
783#define IMXRT_PAD_GPIO_EMC_07__PWM2_B0 0x0030 0x0220 0x0488 1 0
784#define IMXRT_PAD_GPIO_EMC_07__SAI2_sai_mclk 0x0030 0x0220 0x05b0 2 0
785#define IMXRT_PAD_GPIO_EMC_07__XBARA1_OUT09 0x0030 0x0220 0x0628 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_9 to 0x1 */
786#define IMXRT_PAD_GPIO_EMC_07__XBARA1_IN09 0x0030 0x0220 0x0628 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_9 to 0 */
787#define IMXRT_PAD_GPIO_EMC_07__FLEXIO1_IO07 0x0030 0x0220 0x0000 4 0
788#define IMXRT_PAD_GPIO_EMC_07__GPIO4_gpio_io07 0x0030 0x0220 0x0000 5 0
789
790/* GPIO_EMC_08 */
791#define IMXRT_PAD_GPIO_EMC_08__SEMC_DM0 0x0034 0x0224 0x0000 0 0
792#define IMXRT_PAD_GPIO_EMC_08__PWM2_A1 0x0034 0x0224 0x047c 1 0
793#define IMXRT_PAD_GPIO_EMC_08__SAI2_sai_rx_data 0x0034 0x0224 0x05b8 2 0
794#define IMXRT_PAD_GPIO_EMC_08__XBARA1_OUT17 0x0034 0x0224 0x062c 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0x1 */
795#define IMXRT_PAD_GPIO_EMC_08__XBARA1_IN17 0x0034 0x0224 0x062c 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0 */
796#define IMXRT_PAD_GPIO_EMC_08__FLEXIO1_IO08 0x0034 0x0224 0x0000 4 0
797#define IMXRT_PAD_GPIO_EMC_08__GPIO4_gpio_io08 0x0034 0x0224 0x0000 5 0
798
799/* GPIO_EMC_09 */
800#define IMXRT_PAD_GPIO_EMC_09__SEMC_ADDR00 0x0038 0x0228 0x0000 0 0
801#define IMXRT_PAD_GPIO_EMC_09__PWM2_B1 0x0038 0x0228 0x048c 1 0
802#define IMXRT_PAD_GPIO_EMC_09__SAI2_sai_rx_sync 0x0038 0x0228 0x05bc 2 0
803#define IMXRT_PAD_GPIO_EMC_09__CAN2_TX 0x0038 0x0228 0x0000 3 0
804#define IMXRT_PAD_GPIO_EMC_09__FLEXIO1_IO09 0x0038 0x0228 0x0000 4 0
805#define IMXRT_PAD_GPIO_EMC_09__GPIO4_gpio_io09 0x0038 0x0228 0x0000 5 0
806
807/* GPIO_EMC_10 */
808#define IMXRT_PAD_GPIO_EMC_10__SEMC_ADDR01 0x003c 0x022c 0x0000 0 0
809#define IMXRT_PAD_GPIO_EMC_10__PWM2_A2 0x003c 0x022c 0x0480 1 0
810#define IMXRT_PAD_GPIO_EMC_10__SAI2_sai_rx_bclk 0x003c 0x022c 0x05b4 2 0
811#define IMXRT_PAD_GPIO_EMC_10__CAN2_RX 0x003c 0x022c 0x0450 3 0
812#define IMXRT_PAD_GPIO_EMC_10__FLEXIO1_IO10 0x003c 0x022c 0x0000 4 0
813#define IMXRT_PAD_GPIO_EMC_10__GPIO4_gpio_io10 0x003c 0x022c 0x0000 5 0
814
815/* GPIO_EMC_11 */
816#define IMXRT_PAD_GPIO_EMC_11__SEMC_ADDR02 0x0040 0x0230 0x0000 0 0
817#define IMXRT_PAD_GPIO_EMC_11__PWM2_B2 0x0040 0x0230 0x0490 1 0
818#define IMXRT_PAD_GPIO_EMC_11__LPI2C4_SDA 0x0040 0x0230 0x04e8 2 0
819#define IMXRT_PAD_GPIO_EMC_11__USDHC2_usdhc_reset_b 0x0040 0x0230 0x0000 3 0
820#define IMXRT_PAD_GPIO_EMC_11__FLEXIO1_IO11 0x0040 0x0230 0x0000 4 0
821#define IMXRT_PAD_GPIO_EMC_11__GPIO4_gpio_io11 0x0040 0x0230 0x0000 5 0
822
823/* GPIO_EMC_12 */
824#define IMXRT_PAD_GPIO_EMC_12__SEMC_ADDR03 0x0044 0x0234 0x0000 0 0
825#define IMXRT_PAD_GPIO_EMC_12__XBARA1_IN24 0x0044 0x0234 0x0640 1 0
826#define IMXRT_PAD_GPIO_EMC_12__LPI2C4_SCL 0x0044 0x0234 0x04e4 2 0
827#define IMXRT_PAD_GPIO_EMC_12__USDHC1_usdhc_wp 0x0044 0x0234 0x05d8 3 0
828#define IMXRT_PAD_GPIO_EMC_12__PWM1_A3 0x0044 0x0234 0x0454 4 1
829#define IMXRT_PAD_GPIO_EMC_12__GPIO4_gpio_io12 0x0044 0x0234 0x0000 5 0
830
831/* GPIO_EMC_13 */
832#define IMXRT_PAD_GPIO_EMC_13__SEMC_ADDR04 0x0048 0x0238 0x0000 0 0
833#define IMXRT_PAD_GPIO_EMC_13__XBARA1_IN25 0x0048 0x0238 0x0650 1 1
834#define IMXRT_PAD_GPIO_EMC_13__LPUART3_TX 0x0048 0x0238 0x053c 2 1
835#define IMXRT_PAD_GPIO_EMC_13__MQS_RIGHT 0x0048 0x0238 0x0000 3 0
836#define IMXRT_PAD_GPIO_EMC_13__PWM1_B3 0x0048 0x0238 0x0464 4 1
837#define IMXRT_PAD_GPIO_EMC_13__GPIO4_gpio_io13 0x0048 0x0238 0x0000 5 0
838
839/* GPIO_EMC_14 */
840#define IMXRT_PAD_GPIO_EMC_14__SEMC_ADDR05 0x004c 0x023c 0x0000 0 0
841#define IMXRT_PAD_GPIO_EMC_14__XBARA1_OUT19 0x004c 0x023c 0x0654 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_19 to 0x1 */
842#define IMXRT_PAD_GPIO_EMC_14__XBARA1_IN19 0x004c 0x023c 0x0654 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_19 to 0 */
843#define IMXRT_PAD_GPIO_EMC_14__LPUART3_RX 0x004c 0x023c 0x0538 2 1
844#define IMXRT_PAD_GPIO_EMC_14__MQS_LEFT 0x004c 0x023c 0x0000 3 0
845#define IMXRT_PAD_GPIO_EMC_14__LPSPI2_PCS1 0x004c 0x023c 0x0000 4 0
846#define IMXRT_PAD_GPIO_EMC_14__GPIO4_gpio_io14 0x004c 0x023c 0x0000 5 0
847
848/* GPIO_EMC_15 */
849#define IMXRT_PAD_GPIO_EMC_15__SEMC_ADDR06 0x0050 0x0240 0x0000 0 0
850#define IMXRT_PAD_GPIO_EMC_15__XBARA1_IN20 0x0050 0x0240 0x0634 1 0
851#define IMXRT_PAD_GPIO_EMC_15__LPUART3_CTS_B 0x0050 0x0240 0x0534 2 0
852#define IMXRT_PAD_GPIO_EMC_15__SPDIF_spdif_out 0x0050 0x0240 0x0000 3 0
853#define IMXRT_PAD_GPIO_EMC_15__TMR3_TIMER0 0x0050 0x0240 0x057c 4 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM0_INPUT_SEL to 0 */
854#define IMXRT_PAD_GPIO_EMC_15__GPIO4_gpio_io15 0x0050 0x0240 0x0000 5 0
855
856/* GPIO_EMC_16 */
857#define IMXRT_PAD_GPIO_EMC_16__SEMC_ADDR07 0x0054 0x0244 0x0000 0 0
858#define IMXRT_PAD_GPIO_EMC_16__XBARA1_IN21 0x0054 0x0244 0x0658 1 0
859#define IMXRT_PAD_GPIO_EMC_16__LPUART3_RTS_B 0x0054 0x0244 0x0000 2 0
860#define IMXRT_PAD_GPIO_EMC_16__SPDIF_spdif_in 0x0054 0x0244 0x05c8 3 1
861#define IMXRT_PAD_GPIO_EMC_16__TMR3_TIMER1 0x0054 0x0244 0x0580 4 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM1_INPUT_SEL to 0 */
862#define IMXRT_PAD_GPIO_EMC_16__GPIO4_gpio_io16 0x0054 0x0244 0x0000 5 0
863
864/* GPIO_EMC_17 */
865#define IMXRT_PAD_GPIO_EMC_17__SEMC_ADDR08 0x0058 0x0248 0x0000 0 0
866#define IMXRT_PAD_GPIO_EMC_17__PWM4_A3 0x0058 0x0248 0x04a0 1 0
867#define IMXRT_PAD_GPIO_EMC_17__LPUART4_CTS_B 0x0058 0x0248 0x0000 2 0
868#define IMXRT_PAD_GPIO_EMC_17__CAN1_TX 0x0058 0x0248 0x0000 3 0
869#define IMXRT_PAD_GPIO_EMC_17__TMR3_TIMER2 0x0058 0x0248 0x0584 4 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM2_INPUT_SEL to 0 */
870#define IMXRT_PAD_GPIO_EMC_17__GPIO4_gpio_io17 0x0058 0x0248 0x0000 5 0
871
872/* GPIO_EMC_18 */
873#define IMXRT_PAD_GPIO_EMC_18__SEMC_ADDR09 0x005c 0x024c 0x0000 0 0
874#define IMXRT_PAD_GPIO_EMC_18__PWM4_B3 0x005c 0x024c 0x0000 1 0
875#define IMXRT_PAD_GPIO_EMC_18__LPUART4_RTS_B 0x005c 0x024c 0x0000 2 0
876#define IMXRT_PAD_GPIO_EMC_18__CAN1_RX 0x005c 0x024c 0x044c 3 1
877#define IMXRT_PAD_GPIO_EMC_18__TMR3_TIMER3 0x005c 0x024c 0x0588 4 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM3_INPUT_SEL to 0 */
878#define IMXRT_PAD_GPIO_EMC_18__GPIO4_gpio_io18 0x005c 0x024c 0x0000 5 0
879#define IMXRT_PAD_GPIO_EMC_18__SNVS_snvs_vio_5_ctl 0x005c 0x024c 0x0000 6 0
880
881/* GPIO_EMC_19 */
882#define IMXRT_PAD_GPIO_EMC_19__SEMC_ADDR11 0x0060 0x0250 0x0000 0 0
883#define IMXRT_PAD_GPIO_EMC_19__PWM2_A3 0x0060 0x0250 0x0474 1 1
884#define IMXRT_PAD_GPIO_EMC_19__LPUART4_TX 0x0060 0x0250 0x0544 2 1
885#define IMXRT_PAD_GPIO_EMC_19__ENET_enet_rx_data1 0x0060 0x0250 0x0438 3 0
886#define IMXRT_PAD_GPIO_EMC_19__TMR2_TIMER0 0x0060 0x0250 0x056c 4 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM0_INPUT_SEL to 0 */
887#define IMXRT_PAD_GPIO_EMC_19__GPIO4_gpio_io19 0x0060 0x0250 0x0000 5 0
888#define IMXRT_PAD_GPIO_EMC_19__SNVS_snvs_vio_5_b 0x0060 0x0250 0x0000 6 0
889
890/* GPIO_EMC_20 */
891#define IMXRT_PAD_GPIO_EMC_20__SEMC_ADDR12 0x0064 0x0254 0x0000 0 0
892#define IMXRT_PAD_GPIO_EMC_20__PWM2_B3 0x0064 0x0254 0x0484 1 1
893#define IMXRT_PAD_GPIO_EMC_20__LPUART4_RX 0x0064 0x0254 0x0540 2 1
894#define IMXRT_PAD_GPIO_EMC_20__ENET_enet_rx_data0 0x0064 0x0254 0x0434 3 0
895#define IMXRT_PAD_GPIO_EMC_20__TMR2_TIMER1 0x0064 0x0254 0x0570 4 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM1_INPUT_SEL to 0 */
896#define IMXRT_PAD_GPIO_EMC_20__GPIO4_gpio_io20 0x0064 0x0254 0x0000 5 0
897
898/* GPIO_EMC_21 */
899#define IMXRT_PAD_GPIO_EMC_21__SEMC_BA0 0x0068 0x0258 0x0000 0 0
900#define IMXRT_PAD_GPIO_EMC_21__PWM3_A3 0x0068 0x0258 0x0000 1 0
901#define IMXRT_PAD_GPIO_EMC_21__LPI2C3_SDA 0x0068 0x0258 0x04e0 2 0
902#define IMXRT_PAD_GPIO_EMC_21__ENET_enet_tx_data1 0x0068 0x0258 0x0000 3 0
903#define IMXRT_PAD_GPIO_EMC_21__TMR2_TIMER2 0x0068 0x0258 0x0574 4 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM2_INPUT_SEL to 0 */
904#define IMXRT_PAD_GPIO_EMC_21__GPIO4_gpio_io21 0x0068 0x0258 0x0000 5 0
905
906/* GPIO_EMC_22 */
907#define IMXRT_PAD_GPIO_EMC_22__SEMC_BA1 0x006c 0x025c 0x0000 0 0
908#define IMXRT_PAD_GPIO_EMC_22__PWM3_B3 0x006c 0x025c 0x0000 1 0
909#define IMXRT_PAD_GPIO_EMC_22__LPI2C3_SCL 0x006c 0x025c 0x04dc 2 0
910#define IMXRT_PAD_GPIO_EMC_22__ENET_enet_tx_data0 0x006c 0x025c 0x0000 3 0
911#define IMXRT_PAD_GPIO_EMC_22__TMR2_TIMER3 0x006c 0x025c 0x0578 4 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM3_INPUT_SEL to 0 */
912#define IMXRT_PAD_GPIO_EMC_22__GPIO4_gpio_io22 0x006c 0x025c 0x0000 5 0
913
914/* GPIO_EMC_23 */
915#define IMXRT_PAD_GPIO_EMC_23__SEMC_ADDR10 0x0070 0x0260 0x0000 0 0
916#define IMXRT_PAD_GPIO_EMC_23__PWM1_A0 0x0070 0x0260 0x0458 1 0
917#define IMXRT_PAD_GPIO_EMC_23__LPUART5_TX 0x0070 0x0260 0x054c 2 0
918#define IMXRT_PAD_GPIO_EMC_23__ENET_enet_rx_en 0x0070 0x0260 0x043c 3 0
919#define IMXRT_PAD_GPIO_EMC_23__GPT1_gpt_capture2 0x0070 0x0260 0x0000 4 0
920#define IMXRT_PAD_GPIO_EMC_23__GPIO4_gpio_io23 0x0070 0x0260 0x0000 5 0
921
922/* GPIO_EMC_24 */
923#define IMXRT_PAD_GPIO_EMC_24__SEMC_semc_cas 0x0074 0x0264 0x0000 0 0
924#define IMXRT_PAD_GPIO_EMC_24__PWM1_B0 0x0074 0x0264 0x0468 1 0
925#define IMXRT_PAD_GPIO_EMC_24__LPUART5_RX 0x0074 0x0264 0x0548 2 0
926#define IMXRT_PAD_GPIO_EMC_24__ENET_enet_tx_en 0x0074 0x0264 0x0000 3 0
927#define IMXRT_PAD_GPIO_EMC_24__GPT1_gpt_capture1 0x0074 0x0264 0x0000 4 0
928#define IMXRT_PAD_GPIO_EMC_24__GPIO4_gpio_io24 0x0074 0x0264 0x0000 5 0
929
930/* GPIO_EMC_25 */
931#define IMXRT_PAD_GPIO_EMC_25__SEMC_semc_ras 0x0078 0x0268 0x0000 0 0
932#define IMXRT_PAD_GPIO_EMC_25__PWM1_A1 0x0078 0x0268 0x045c 1 0
933#define IMXRT_PAD_GPIO_EMC_25__LPUART6_TX 0x0078 0x0268 0x0554 2 0
934#define IMXRT_PAD_GPIO_EMC_25__ENET_enet_tx_clk 0x0078 0x0268 0x0448 3 0
935#define IMXRT_PAD_GPIO_EMC_25__ENET_enet_ref_clk 0x0078 0x0268 0x042c 4 0
936#define IMXRT_PAD_GPIO_EMC_25__GPIO4_gpio_io25 0x0078 0x0268 0x0000 5 0
937
938/* GPIO_EMC_26 */
939#define IMXRT_PAD_GPIO_EMC_26__SEMC_semc_clk 0x007c 0x026c 0x0000 0 0
940#define IMXRT_PAD_GPIO_EMC_26__PWM1_B1 0x007c 0x026c 0x046c 1 0
941#define IMXRT_PAD_GPIO_EMC_26__LPUART6_RX 0x007c 0x026c 0x0550 2 0
942#define IMXRT_PAD_GPIO_EMC_26__ENET_enet_rx_er 0x007c 0x026c 0x0440 3 0
943#define IMXRT_PAD_GPIO_EMC_26__FLEXIO1_IO12 0x007c 0x026c 0x0000 4 0
944#define IMXRT_PAD_GPIO_EMC_26__GPIO4_gpio_io26 0x007c 0x026c 0x0000 5 0
945
946/* GPIO_EMC_27 */
947#define IMXRT_PAD_GPIO_EMC_27__SEMC_semc_cke 0x0080 0x0270 0x0000 0 0
948#define IMXRT_PAD_GPIO_EMC_27__PWM1_A2 0x0080 0x0270 0x0460 1 0
949#define IMXRT_PAD_GPIO_EMC_27__LPUART5_RTS_B 0x0080 0x0270 0x0000 2 0
950#define IMXRT_PAD_GPIO_EMC_27__LPSPI1_SCK 0x0080 0x0270 0x04f0 3 0
951#define IMXRT_PAD_GPIO_EMC_27__FLEXIO1_IO13 0x0080 0x0270 0x0000 4 0
952#define IMXRT_PAD_GPIO_EMC_27__GPIO4_gpio_io27 0x0080 0x0270 0x0000 5 0
953
954/* GPIO_EMC_28 */
955#define IMXRT_PAD_GPIO_EMC_28__SEMC_semc_we 0x0084 0x0274 0x0000 0 0
956#define IMXRT_PAD_GPIO_EMC_28__PWM1_B2 0x0084 0x0274 0x0470 1 0
957#define IMXRT_PAD_GPIO_EMC_28__LPUART5_CTS_B 0x0084 0x0274 0x0000 2 0
958#define IMXRT_PAD_GPIO_EMC_28__LPSPI1_SDO 0x0084 0x0274 0x04f8 3 0
959#define IMXRT_PAD_GPIO_EMC_28__FLEXIO1_IO14 0x0084 0x0274 0x0000 4 0
960#define IMXRT_PAD_GPIO_EMC_28__GPIO4_gpio_io28 0x0084 0x0274 0x0000 5 0
961
962/* GPIO_EMC_29 */
963#define IMXRT_PAD_GPIO_EMC_29__SEMC_CS0 0x0088 0x0278 0x0000 0 0
964#define IMXRT_PAD_GPIO_EMC_29__PWM3_A0 0x0088 0x0278 0x0000 1 0
965#define IMXRT_PAD_GPIO_EMC_29__LPUART6_RTS_B 0x0088 0x0278 0x0000 2 0
966#define IMXRT_PAD_GPIO_EMC_29__LPSPI1_SDI 0x0088 0x0278 0x04f4 3 0
967#define IMXRT_PAD_GPIO_EMC_29__FLEXIO1_IO15 0x0088 0x0278 0x0000 4 0
968#define IMXRT_PAD_GPIO_EMC_29__GPIO4_gpio_io29 0x0088 0x0278 0x0000 5 0
969
970/* GPIO_EMC_30 */
971#define IMXRT_PAD_GPIO_EMC_30__SEMC_DATA08 0x008c 0x027c 0x0000 0 0
972#define IMXRT_PAD_GPIO_EMC_30__PWM3_B0 0x008c 0x027c 0x0000 1 0
973#define IMXRT_PAD_GPIO_EMC_30__LPUART6_CTS_B 0x008c 0x027c 0x0000 2 0
974#define IMXRT_PAD_GPIO_EMC_30__LPSPI1_PCS0 0x008c 0x027c 0x04ec 3 1
975#define IMXRT_PAD_GPIO_EMC_30__CSI_csi_data23 0x008c 0x027c 0x0000 4 0
976#define IMXRT_PAD_GPIO_EMC_30__GPIO4_gpio_io30 0x008c 0x027c 0x0000 5 0
977
978/* GPIO_EMC_31 */
979#define IMXRT_PAD_GPIO_EMC_31__SEMC_DATA09 0x0090 0x0280 0x0000 0 0
980#define IMXRT_PAD_GPIO_EMC_31__PWM3_A1 0x0090 0x0280 0x0000 1 0
981#define IMXRT_PAD_GPIO_EMC_31__LPUART7_TX 0x0090 0x0280 0x055c 2 1
982#define IMXRT_PAD_GPIO_EMC_31__LPSPI1_PCS1 0x0090 0x0280 0x0000 3 0
983#define IMXRT_PAD_GPIO_EMC_31__CSI_csi_data22 0x0090 0x0280 0x0000 4 0
984#define IMXRT_PAD_GPIO_EMC_31__GPIO4_gpio_io31 0x0090 0x0280 0x0000 5 0
985
986/* GPIO_EMC_32 */
987#define IMXRT_PAD_GPIO_EMC_32__SEMC_DATA10 0x0094 0x0284 0x0000 0 0
988#define IMXRT_PAD_GPIO_EMC_32__PWM3_B1 0x0094 0x0284 0x0000 1 0
989#define IMXRT_PAD_GPIO_EMC_32__LPUART7_RX 0x0094 0x0284 0x0558 2 1
990#define IMXRT_PAD_GPIO_EMC_32__CCM_PMIC_RDY 0x0094 0x0284 0x03fc 3 4
991#define IMXRT_PAD_GPIO_EMC_32__CSI_csi_data21 0x0094 0x0284 0x0000 4 0
992#define IMXRT_PAD_GPIO_EMC_32__GPIO3_gpio_io18 0x0094 0x0284 0x0000 5 0
993
994/* GPIO_EMC_33 */
995#define IMXRT_PAD_GPIO_EMC_33__SEMC_DATA11 0x0098 0x0288 0x0000 0 0
996#define IMXRT_PAD_GPIO_EMC_33__PWM3_A2 0x0098 0x0288 0x0000 1 0
997#define IMXRT_PAD_GPIO_EMC_33__USDHC1_usdhc_reset_b 0x0098 0x0288 0x0000 2 0
998#define IMXRT_PAD_GPIO_EMC_33__SAI3_sai_rx_data 0x0098 0x0288 0x0000 3 0
999#define IMXRT_PAD_GPIO_EMC_33__CSI_csi_data20 0x0098 0x0288 0x0000 4 0
1000#define IMXRT_PAD_GPIO_EMC_33__GPIO3_gpio_io19 0x0098 0x0288 0x0000 5 0
1001
1002/* GPIO_EMC_34 */
1003#define IMXRT_PAD_GPIO_EMC_34__SEMC_DATA12 0x009c 0x028c 0x0000 0 0
1004#define IMXRT_PAD_GPIO_EMC_34__PWM3_B2 0x009c 0x028c 0x0000 1 0
1005#define IMXRT_PAD_GPIO_EMC_34__USDHC1_usdhc_vselect 0x009c 0x028c 0x0000 2 0
1006#define IMXRT_PAD_GPIO_EMC_34__SAI3_sai_rx_sync 0x009c 0x028c 0x0000 3 0
1007#define IMXRT_PAD_GPIO_EMC_34__CSI_csi_data19 0x009c 0x028c 0x0000 4 0
1008#define IMXRT_PAD_GPIO_EMC_34__GPIO3_gpio_io20 0x009c 0x028c 0x0000 5 0
1009
1010/* GPIO_EMC_35 */
1011#define IMXRT_PAD_GPIO_EMC_35__SEMC_DATA13 0x00a0 0x0290 0x0000 0 0
1012#define IMXRT_PAD_GPIO_EMC_35__XBARA1_OUT18 0x00a0 0x0290 0x0630 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_18 to 0x1 */
1013#define IMXRT_PAD_GPIO_EMC_35__XBARA1_IN18 0x00a0 0x0290 0x0630 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_18 to 0 */
1014#define IMXRT_PAD_GPIO_EMC_35__GPT1_gpt_compare1 0x00a0 0x0290 0x0000 2 0
1015#define IMXRT_PAD_GPIO_EMC_35__SAI3_sai_rx_bclk 0x00a0 0x0290 0x0000 3 0
1016#define IMXRT_PAD_GPIO_EMC_35__CSI_csi_data18 0x00a0 0x0290 0x0000 4 0
1017#define IMXRT_PAD_GPIO_EMC_35__GPIO3_gpio_io21 0x00a0 0x0290 0x0000 5 0
1018#define IMXRT_PAD_GPIO_EMC_35__USDHC1_usdhc_cd_b 0x00a0 0x0290 0x05d4 6 0
1019
1020/* GPIO_EMC_36 */
1021#define IMXRT_PAD_GPIO_EMC_36__SEMC_DATA14 0x00a4 0x0294 0x0000 0 0
1022#define IMXRT_PAD_GPIO_EMC_36__XBARA1_IN22 0x00a4 0x0294 0x0638 1 0
1023#define IMXRT_PAD_GPIO_EMC_36__GPT1_gpt_compare2 0x00a4 0x0294 0x0000 2 0
1024#define IMXRT_PAD_GPIO_EMC_36__SAI3_sai_tx_data 0x00a4 0x0294 0x0000 3 0
1025#define IMXRT_PAD_GPIO_EMC_36__CSI_csi_data17 0x00a4 0x0294 0x0000 4 0
1026#define IMXRT_PAD_GPIO_EMC_36__GPIO3_gpio_io22 0x00a4 0x0294 0x0000 5 0
1027#define IMXRT_PAD_GPIO_EMC_36__USDHC1_usdhc_wp 0x00a4 0x0294 0x05d8 6 1
1028
1029/* GPIO_EMC_37 */
1030#define IMXRT_PAD_GPIO_EMC_37__SEMC_DATA15 0x00a8 0x0298 0x0000 0 0
1031#define IMXRT_PAD_GPIO_EMC_37__XBARA1_IN23 0x00a8 0x0298 0x063c 1 0
1032#define IMXRT_PAD_GPIO_EMC_37__GPT1_gpt_compare3 0x00a8 0x0298 0x0000 2 0
1033#define IMXRT_PAD_GPIO_EMC_37__SAI3_sai_mclk 0x00a8 0x0298 0x0000 3 0
1034#define IMXRT_PAD_GPIO_EMC_37__CSI_csi_data16 0x00a8 0x0298 0x0000 4 0
1035#define IMXRT_PAD_GPIO_EMC_37__GPIO3_gpio_io23 0x00a8 0x0298 0x0000 5 0
1036#define IMXRT_PAD_GPIO_EMC_37__USDHC2_usdhc_wp 0x00a8 0x0298 0x0608 6 0
1037
1038/* GPIO_EMC_38 */
1039#define IMXRT_PAD_GPIO_EMC_38__SEMC_DM1 0x00ac 0x029c 0x0000 0 0
1040#define IMXRT_PAD_GPIO_EMC_38__PWM1_A3 0x00ac 0x029c 0x0454 1 2
1041#define IMXRT_PAD_GPIO_EMC_38__LPUART8_TX 0x00ac 0x029c 0x0564 2 2
1042#define IMXRT_PAD_GPIO_EMC_38__SAI3_sai_tx_bclk 0x00ac 0x029c 0x0000 3 0
1043#define IMXRT_PAD_GPIO_EMC_38__CSI_csi_field 0x00ac 0x029c 0x0000 4 0
1044#define IMXRT_PAD_GPIO_EMC_38__GPIO3_gpio_io24 0x00ac 0x029c 0x0000 5 0
1045#define IMXRT_PAD_GPIO_EMC_38__USDHC2_usdhc_vselect 0x00ac 0x029c 0x0000 6 0
1046
1047/* GPIO_EMC_39 */
1048#define IMXRT_PAD_GPIO_EMC_39__SEMC_semc_dqs 0x00b0 0x02a0 0x0000 0 0
1049#define IMXRT_PAD_GPIO_EMC_39__PWM1_B3 0x00b0 0x02a0 0x0464 1 2
1050#define IMXRT_PAD_GPIO_EMC_39__LPUART8_RX 0x00b0 0x02a0 0x0560 2 2
1051#define IMXRT_PAD_GPIO_EMC_39__SAI3_sai_tx_sync 0x00b0 0x02a0 0x0000 3 0
1052#define IMXRT_PAD_GPIO_EMC_39__WDOG1_wdog_b 0x00b0 0x02a0 0x0000 4 0
1053#define IMXRT_PAD_GPIO_EMC_39__GPIO3_gpio_io25 0x00b0 0x02a0 0x0000 5 0
1054#define IMXRT_PAD_GPIO_EMC_39__USDHC2_usdhc_cd_b 0x00b0 0x02a0 0x05e0 6 1
1055
1056/* GPIO_EMC_40 */
1057#define IMXRT_PAD_GPIO_EMC_40__SEMC_semc_rdy 0x00b4 0x02a4 0x0000 0 0
1058#define IMXRT_PAD_GPIO_EMC_40__GPT2_gpt_capture2 0x00b4 0x02a4 0x0000 1 0
1059#define IMXRT_PAD_GPIO_EMC_40__LPSPI1_PCS2 0x00b4 0x02a4 0x0000 2 0
1060#define IMXRT_PAD_GPIO_EMC_40__USB2_usb_otg2_oc 0x00b4 0x02a4 0x05cc 3 1
1061#define IMXRT_PAD_GPIO_EMC_40__ENET_enet_mdc 0x00b4 0x02a4 0x0000 4 0
1062#define IMXRT_PAD_GPIO_EMC_40__GPIO3_gpio_io26 0x00b4 0x02a4 0x0000 5 0
1063#define IMXRT_PAD_GPIO_EMC_40__USDHC2_usdhc_reset_b 0x00b4 0x02a4 0x0000 6 0
1064
1065/* GPIO_EMC_41 */
1066#define IMXRT_PAD_GPIO_EMC_41__SEMC_CSX0 0x00b8 0x02a8 0x0000 0 0
1067#define IMXRT_PAD_GPIO_EMC_41__GPT2_gpt_capture1 0x00b8 0x02a8 0x0000 1 0
1068#define IMXRT_PAD_GPIO_EMC_41__LPSPI1_PCS3 0x00b8 0x02a8 0x0000 2 0
1069#define IMXRT_PAD_GPIO_EMC_41__USB2_usb_otg2_pwr 0x00b8 0x02a8 0x0000 3 0
1070#define IMXRT_PAD_GPIO_EMC_41__ENET_enet_mdio 0x00b8 0x02a8 0x0430 4 1
1071#define IMXRT_PAD_GPIO_EMC_41__GPIO3_gpio_io27 0x00b8 0x02a8 0x0000 5 0
1072#define IMXRT_PAD_GPIO_EMC_41__USDHC1_usdhc_vselect 0x00b8 0x02a8 0x0000 6 0
1073
1074/* GPIO_SD_B0_00 */
1075#define IMXRT_PAD_GPIO_SD_B0_00__USDHC1_usdhc_cmd 0x01bc 0x03ac 0x0000 0 0
1076#define IMXRT_PAD_GPIO_SD_B0_00__PWM1_A0 0x01bc 0x03ac 0x0458 1 1
1077#define IMXRT_PAD_GPIO_SD_B0_00__LPI2C3_SCL 0x01bc 0x03ac 0x04dc 2 1
1078#define IMXRT_PAD_GPIO_SD_B0_00__XBARA1_OUT04 0x01bc 0x03ac 0x0614 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_4 to 0x1 */
1079#define IMXRT_PAD_GPIO_SD_B0_00__XBARA1_IN04 0x01bc 0x03ac 0x0614 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_4 to 0 */
1080#define IMXRT_PAD_GPIO_SD_B0_00__LPSPI1_SCK 0x01bc 0x03ac 0x04f0 4 1
1081#define IMXRT_PAD_GPIO_SD_B0_00__GPIO3_gpio_io12 0x01bc 0x03ac 0x0000 5 0
1082#define IMXRT_PAD_GPIO_SD_B0_00__FLEXSPI_FLEXSPI_A_SS1_B 0x01bc 0x03ac 0x0000 6 0
1083
1084/* GPIO_SD_B0_01 */
1085#define IMXRT_PAD_GPIO_SD_B0_01__USDHC1_usdhc_clk 0x01c0 0x03b0 0x0000 0 0
1086#define IMXRT_PAD_GPIO_SD_B0_01__PWM1_B0 0x01c0 0x03b0 0x0468 1 1
1087#define IMXRT_PAD_GPIO_SD_B0_01__LPI2C3_SDA 0x01c0 0x03b0 0x04e0 2 1
1088#define IMXRT_PAD_GPIO_SD_B0_01__XBARA1_OUT05 0x01c0 0x03b0 0x0618 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_5 to 0x1 */
1089#define IMXRT_PAD_GPIO_SD_B0_01__XBARA1_IN05 0x01c0 0x03b0 0x0618 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_5 to 0 */
1090#define IMXRT_PAD_GPIO_SD_B0_01__LPSPI1_PCS0 0x01c0 0x03b0 0x04ec 4 0
1091#define IMXRT_PAD_GPIO_SD_B0_01__GPIO3_gpio_io13 0x01c0 0x03b0 0x0000 5 0
1092#define IMXRT_PAD_GPIO_SD_B0_01__FLEXSPI_FLEXSPI_B_SS1_B 0x01c0 0x03b0 0x0000 6 0
1093
1094/* GPIO_SD_B0_02 */
1095#define IMXRT_PAD_GPIO_SD_B0_02__USDHC1_usdhc_data0 0x01c4 0x03b4 0x0000 0 0
1096#define IMXRT_PAD_GPIO_SD_B0_02__PWM1_A1 0x01c4 0x03b4 0x045c 1 1
1097#define IMXRT_PAD_GPIO_SD_B0_02__LPUART8_CTS_B 0x01c4 0x03b4 0x0000 2 0
1098#define IMXRT_PAD_GPIO_SD_B0_02__XBARA1_OUT06 0x01c4 0x03b4 0x061c 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_6 to 0x1 */
1099#define IMXRT_PAD_GPIO_SD_B0_02__XBARA1_IN06 0x01c4 0x03b4 0x061c 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_6 to 0 */
1100#define IMXRT_PAD_GPIO_SD_B0_02__LPSPI1_SDO 0x01c4 0x03b4 0x04f8 4 1
1101#define IMXRT_PAD_GPIO_SD_B0_02__GPIO3_gpio_io14 0x01c4 0x03b4 0x0000 5 0
1102
1103/* GPIO_SD_B0_03 */
1104#define IMXRT_PAD_GPIO_SD_B0_03__USDHC1_usdhc_data1 0x01c8 0x03b8 0x0000 0 0
1105#define IMXRT_PAD_GPIO_SD_B0_03__PWM1_B1 0x01c8 0x03b8 0x046c 1 1
1106#define IMXRT_PAD_GPIO_SD_B0_03__LPUART8_RTS_B 0x01c8 0x03b8 0x0000 2 0
1107#define IMXRT_PAD_GPIO_SD_B0_03__XBARA1_OUT07 0x01c8 0x03b8 0x0620 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_7 to 0x1 */
1108#define IMXRT_PAD_GPIO_SD_B0_03__XBARA1_IN07 0x01c8 0x03b8 0x0620 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_7 to 0 */
1109#define IMXRT_PAD_GPIO_SD_B0_03__LPSPI1_SDI 0x01c8 0x03b8 0x04f4 4 1
1110#define IMXRT_PAD_GPIO_SD_B0_03__GPIO3_gpio_io15 0x01c8 0x03b8 0x0000 5 0
1111
1112/* GPIO_SD_B0_04 */
1113#define IMXRT_PAD_GPIO_SD_B0_04__USDHC1_usdhc_data2 0x01cc 0x03bc 0x0000 0 0
1114#define IMXRT_PAD_GPIO_SD_B0_04__PWM1_A2 0x01cc 0x03bc 0x0460 1 1
1115#define IMXRT_PAD_GPIO_SD_B0_04__LPUART8_TX 0x01cc 0x03bc 0x0564 2 0
1116#define IMXRT_PAD_GPIO_SD_B0_04__XBARA1_OUT08 0x01cc 0x03bc 0x0624 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_8 to 0x1 */
1117#define IMXRT_PAD_GPIO_SD_B0_04__XBARA1_IN08 0x01cc 0x03bc 0x0624 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_8 to 0 */
1118#define IMXRT_PAD_GPIO_SD_B0_04__FLEXSPI_FLEXSPI_B_SS0_B 0x01cc 0x03bc 0x0000 4 0
1119#define IMXRT_PAD_GPIO_SD_B0_04__GPIO3_gpio_io16 0x01cc 0x03bc 0x0000 5 0
1120#define IMXRT_PAD_GPIO_SD_B0_04__CCM_CLKO1 0x01cc 0x03bc 0x0000 6 0
1121
1122/* GPIO_SD_B0_05 */
1123#define IMXRT_PAD_GPIO_SD_B0_05__USDHC1_usdhc_data3 0x01d0 0x03c0 0x0000 0 0
1124#define IMXRT_PAD_GPIO_SD_B0_05__PWM1_B2 0x01d0 0x03c0 0x0470 1 1
1125#define IMXRT_PAD_GPIO_SD_B0_05__LPUART8_RX 0x01d0 0x03c0 0x0560 2 0
1126#define IMXRT_PAD_GPIO_SD_B0_05__XBARA1_OUT09 0x01d0 0x03c0 0x0628 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_9 to 0x1 */
1127#define IMXRT_PAD_GPIO_SD_B0_05__XBARA1_IN09 0x01d0 0x03c0 0x0628 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_9 to 0 */
1128#define IMXRT_PAD_GPIO_SD_B0_05__FLEXSPI_FLEXSPI_B_DQS 0x01d0 0x03c0 0x0000 4 0
1129#define IMXRT_PAD_GPIO_SD_B0_05__GPIO3_gpio_io17 0x01d0 0x03c0 0x0000 5 0
1130#define IMXRT_PAD_GPIO_SD_B0_05__CCM_CLKO2 0x01d0 0x03c0 0x0000 6 0
1131
1132/* GPIO_SD_B1_00 */
1133#define IMXRT_PAD_GPIO_SD_B1_00__USDHC2_usdhc_data3 0x01d4 0x03c4 0x05f4 0 0
1134#define IMXRT_PAD_GPIO_SD_B1_00__FLEXSPI_FLEXSPI_B_DATA3 0x01d4 0x03c4 0x04c4 1 0
1135#define IMXRT_PAD_GPIO_SD_B1_00__PWM1_A3 0x01d4 0x03c4 0x0454 2 0
1136#define IMXRT_PAD_GPIO_SD_B1_00__SAI1_sai_tx_data3 0x01d4 0x03c4 0x0598 3 0
1137#define IMXRT_PAD_GPIO_SD_B1_00__LPUART4_TX 0x01d4 0x03c4 0x0544 4 0
1138#define IMXRT_PAD_GPIO_SD_B1_00__GPIO3_gpio_io00 0x01d4 0x03c4 0x0000 5 0
1139
1140/* GPIO_SD_B1_01 */
1141#define IMXRT_PAD_GPIO_SD_B1_01__USDHC2_usdhc_data2 0x01d8 0x03c8 0x05f0 0 0
1142#define IMXRT_PAD_GPIO_SD_B1_01__FLEXSPI_FLEXSPI_B_DATA2 0x01d8 0x03c8 0x04c0 1 0
1143#define IMXRT_PAD_GPIO_SD_B1_01__PWM1_B3 0x01d8 0x03c8 0x0464 2 0
1144#define IMXRT_PAD_GPIO_SD_B1_01__SAI1_sai_tx_data2 0x01d8 0x03c8 0x059c 3 0
1145#define IMXRT_PAD_GPIO_SD_B1_01__LPUART4_RX 0x01d8 0x03c8 0x0540 4 0
1146#define IMXRT_PAD_GPIO_SD_B1_01__GPIO3_gpio_io01 0x01d8 0x03c8 0x0000 5 0
1147
1148/* GPIO_SD_B1_02 */
1149#define IMXRT_PAD_GPIO_SD_B1_02__USDHC2_usdhc_data1 0x01dc 0x03cc 0x05ec 0 0
1150#define IMXRT_PAD_GPIO_SD_B1_02__FLEXSPI_FLEXSPI_B_DATA1 0x01dc 0x03cc 0x04bc 1 0
1151#define IMXRT_PAD_GPIO_SD_B1_02__PWM2_A3 0x01dc 0x03cc 0x0474 2 0
1152#define IMXRT_PAD_GPIO_SD_B1_02__SAI1_sai_tx_data1 0x01dc 0x03cc 0x05a0 3 0
1153#define IMXRT_PAD_GPIO_SD_B1_02__CAN1_TX 0x01dc 0x03cc 0x0000 4 0
1154#define IMXRT_PAD_GPIO_SD_B1_02__GPIO3_gpio_io02 0x01dc 0x03cc 0x0000 5 0
1155#define IMXRT_PAD_GPIO_SD_B1_02__CCM_WAIT 0x01dc 0x03cc 0x0000 6 0
1156
1157/* GPIO_SD_B1_03 */
1158#define IMXRT_PAD_GPIO_SD_B1_03__USDHC2_usdhc_data0 0x01e0 0x03d0 0x05e8 0 0
1159#define IMXRT_PAD_GPIO_SD_B1_03__FLEXSPI_FLEXSPI_B_DATA0 0x01e0 0x03d0 0x04b8 1 0
1160#define IMXRT_PAD_GPIO_SD_B1_03__PWM2_B3 0x01e0 0x03d0 0x0484 2 0
1161#define IMXRT_PAD_GPIO_SD_B1_03__SAI1_sai_mclk 0x01e0 0x03d0 0x058c 3 0
1162#define IMXRT_PAD_GPIO_SD_B1_03__CAN1_RX 0x01e0 0x03d0 0x044c 4 0
1163#define IMXRT_PAD_GPIO_SD_B1_03__GPIO3_gpio_io03 0x01e0 0x03d0 0x0000 5 0
1164#define IMXRT_PAD_GPIO_SD_B1_03__CCM_PMIC_RDY 0x01e0 0x03d0 0x03fc 6 0
1165
1166/* GPIO_SD_B1_04 */
1167#define IMXRT_PAD_GPIO_SD_B1_04__USDHC2_usdhc_clk 0x01e4 0x03d4 0x05dc 0 0
1168#define IMXRT_PAD_GPIO_SD_B1_04__FLEXSPI_FLEXSPI_B_SCLK 0x01e4 0x03d4 0x0000 1 0
1169#define IMXRT_PAD_GPIO_SD_B1_04__LPI2C1_SCL 0x01e4 0x03d4 0x04cc 2 0
1170#define IMXRT_PAD_GPIO_SD_B1_04__SAI1_sai_rx_sync 0x01e4 0x03d4 0x05a4 3 0
1171#define IMXRT_PAD_GPIO_SD_B1_04__FLEXSPI_FLEXSPI_A_SS1_B 0x01e4 0x03d4 0x0000 4 0
1172#define IMXRT_PAD_GPIO_SD_B1_04__GPIO3_gpio_io04 0x01e4 0x03d4 0x0000 5 0
1173#define IMXRT_PAD_GPIO_SD_B1_04__CCM_STOP 0x01e4 0x03d4 0x0000 6 0
1174
1175/* GPIO_SD_B1_05 */
1176#define IMXRT_PAD_GPIO_SD_B1_05__USDHC2_usdhc_cmd 0x01e8 0x03d8 0x05e4 0 0
1177#define IMXRT_PAD_GPIO_SD_B1_05__FLEXSPI_FLEXSPI_A_DQS 0x01e8 0x03d8 0x04a4 1 0
1178#define IMXRT_PAD_GPIO_SD_B1_05__LPI2C1_SDA 0x01e8 0x03d8 0x04d0 2 0
1179#define IMXRT_PAD_GPIO_SD_B1_05__SAI1_sai_rx_bclk 0x01e8 0x03d8 0x0590 3 0
1180#define IMXRT_PAD_GPIO_SD_B1_05__FLEXSPI_FLEXSPI_B_SS0_B 0x01e8 0x03d8 0x0000 4 0
1181#define IMXRT_PAD_GPIO_SD_B1_05__GPIO3_gpio_io05 0x01e8 0x03d8 0x0000 5 0
1182
1183/* GPIO_SD_B1_06 */
1184#define IMXRT_PAD_GPIO_SD_B1_06__USDHC2_usdhc_reset_b 0x01ec 0x03dc 0x0000 0 0
1185#define IMXRT_PAD_GPIO_SD_B1_06__FLEXSPI_FLEXSPI_A_SS0_B 0x01ec 0x03dc 0x0000 1 0
1186#define IMXRT_PAD_GPIO_SD_B1_06__LPUART7_CTS_B 0x01ec 0x03dc 0x0000 2 0
1187#define IMXRT_PAD_GPIO_SD_B1_06__SAI1_sai_rx_data0 0x01ec 0x03dc 0x0594 3 0
1188#define IMXRT_PAD_GPIO_SD_B1_06__LPSPI2_PCS0 0x01ec 0x03dc 0x04fc 4 0
1189#define IMXRT_PAD_GPIO_SD_B1_06__GPIO3_gpio_io06 0x01ec 0x03dc 0x0000 5 0
1190
1191/* GPIO_SD_B1_07 */
1192#define IMXRT_PAD_GPIO_SD_B1_07__SEMC_CSX1 0x01f0 0x03e0 0x0000 0 0
1193#define IMXRT_PAD_GPIO_SD_B1_07__FLEXSPI_FLEXSPI_A_SCLK 0x01f0 0x03e0 0x04c8 1 0
1194#define IMXRT_PAD_GPIO_SD_B1_07__LPUART7_RTS_B 0x01f0 0x03e0 0x0000 2 0
1195#define IMXRT_PAD_GPIO_SD_B1_07__SAI1_sai_tx_data0 0x01f0 0x03e0 0x0000 3 0
1196#define IMXRT_PAD_GPIO_SD_B1_07__LPSPI2_SCK 0x01f0 0x03e0 0x0500 4 0
1197#define IMXRT_PAD_GPIO_SD_B1_07__GPIO3_gpio_io07 0x01f0 0x03e0 0x0000 5 0
1198
1199/* GPIO_SD_B1_08 */
1200#define IMXRT_PAD_GPIO_SD_B1_08__USDHC2_usdhc_data4 0x01f4 0x03e4 0x05f8 0 0
1201#define IMXRT_PAD_GPIO_SD_B1_08__FLEXSPI_FLEXSPI_A_DATA0 0x01f4 0x03e4 0x04a8 1 0
1202#define IMXRT_PAD_GPIO_SD_B1_08__LPUART7_TX 0x01f4 0x03e4 0x055c 2 0
1203#define IMXRT_PAD_GPIO_SD_B1_08__SAI1_sai_tx_bclk 0x01f4 0x03e4 0x05a8 3 0
1204#define IMXRT_PAD_GPIO_SD_B1_08__LPSPI2_SDO 0x01f4 0x03e4 0x0508 4 0
1205#define IMXRT_PAD_GPIO_SD_B1_08__GPIO3_gpio_io08 0x01f4 0x03e4 0x0000 5 0
1206#define IMXRT_PAD_GPIO_SD_B1_08__SEMC_CSX2 0x01f4 0x03e4 0x0000 6 0
1207
1208/* GPIO_SD_B1_09 */
1209#define IMXRT_PAD_GPIO_SD_B1_09__USDHC2_usdhc_data5 0x01f8 0x03e8 0x05fc 0 0
1210#define IMXRT_PAD_GPIO_SD_B1_09__FLEXSPI_FLEXSPI_A_DATA1 0x01f8 0x03e8 0x04ac 1 0
1211#define IMXRT_PAD_GPIO_SD_B1_09__LPUART7_RX 0x01f8 0x03e8 0x0558 2 0
1212#define IMXRT_PAD_GPIO_SD_B1_09__SAI1_sai_tx_sync 0x01f8 0x03e8 0x05ac 3 0
1213#define IMXRT_PAD_GPIO_SD_B1_09__LPSPI2_SDI 0x01f8 0x03e8 0x0504 4 0
1214#define IMXRT_PAD_GPIO_SD_B1_09__GPIO3_gpio_io09 0x01f8 0x03e8 0x0000 5 0
1215
1216/* GPIO_SD_B1_10 */
1217#define IMXRT_PAD_GPIO_SD_B1_10__USDHC2_usdhc_data6 0x01fc 0x03ec 0x0600 0 0
1218#define IMXRT_PAD_GPIO_SD_B1_10__FLEXSPI_FLEXSPI_A_DATA2 0x01fc 0x03ec 0x04b0 1 0
1219#define IMXRT_PAD_GPIO_SD_B1_10__LPUART2_RX 0x01fc 0x03ec 0x052c 2 0
1220#define IMXRT_PAD_GPIO_SD_B1_10__LPI2C2_SDA 0x01fc 0x03ec 0x04d8 3 0
1221#define IMXRT_PAD_GPIO_SD_B1_10__LPSPI2_PCS2 0x01fc 0x03ec 0x0000 4 0
1222#define IMXRT_PAD_GPIO_SD_B1_10__GPIO3_gpio_io10 0x01fc 0x03ec 0x0000 5 0
1223
1224/* GPIO_SD_B1_11 */
1225#define IMXRT_PAD_GPIO_SD_B1_11__USDHC2_usdhc_data7 0x0200 0x03f0 0x0604 0 0
1226#define IMXRT_PAD_GPIO_SD_B1_11__FLEXSPI_FLEXSPI_A_DATA3 0x0200 0x03f0 0x04b4 1 0
1227#define IMXRT_PAD_GPIO_SD_B1_11__LPUART2_TX 0x0200 0x03f0 0x0530 2 0
1228#define IMXRT_PAD_GPIO_SD_B1_11__LPI2C2_SCL 0x0200 0x03f0 0x04d4 3 0
1229#define IMXRT_PAD_GPIO_SD_B1_11__LPSPI2_PCS3 0x0200 0x03f0 0x0000 4 0
1230#define IMXRT_PAD_GPIO_SD_B1_11__GPIO3_gpio_io11 0x0200 0x03f0 0x0000 5 0
1231
1232#ifdef __cplusplus
1233}
1234#endif /* __cplusplus */
1235
1236#endif /* LIBBSP_ARM_IMXRT_IMXRT1050_PINFUNC_H */
