RTEMS 6.1
ili9488_ebi_dma.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
37#ifndef _ILI9488_EBI_DMA_H_
38#define _ILI9488_EBI_DMA_H_
39
40/*----------------------------------------------------------------------------
41 * Headers
42 *----------------------------------------------------------------------------*/
43
44#include "board.h"
45#include <stdint.h>
46
47/*----------------------------------------------------------------------------
48 * Exported functions
49 *----------------------------------------------------------------------------*/
50extern uint8_t ILI9488_EbiInitializeWithDma(sXdmad *dmad);
51extern uint8_t ILI9488_EbiDmaTxTransfer(uint16_t *pTxBuffer, uint32_t wTxSize);
52extern uint8_t ILI9488_EbiDmaRxTransfer(uint32_t *pRxBuffer, uint32_t wRxSize);
53extern uint8_t ILI9488_EbiSendCommand(uint16_t Instr, uint16_t *pTxData,
54 uint32_t *pRxData, AccessIli_t ReadWrite, uint32_t size);
55#endif /* #ifndef ILI9488_EBI_DMA */
Definition: xdmad.h:127
