RTEMS 6.1
ili9488_ebi.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
37#ifndef _ILI9488_EBI_H_
38#define _ILI9488_EBI_H_
39
40/*----------------------------------------------------------------------------
41 * Headers
42 *----------------------------------------------------------------------------*/
43
44#include "board.h"
45
46#include <stdint.h>
47
48/*----------------------------------------------------------------------------
49 * Exported functions
50 *----------------------------------------------------------------------------*/
51extern uint32_t ILI9488_EbiReadChipId (void);
52extern uint32_t ILI9488_EbiInitialize(sXdmad *dmad);
53extern void ILI9488_EbiSetPixelFormat(uint16_t format);
54extern void ILI9488_EbiSetCursor(uint16_t x, uint16_t y);
55extern void ILI9488_EbiSetWindow(uint16_t dwX, uint16_t dwY,
56 uint16_t dwWidth, uint16_t dwHeight);
57extern void ILI9488_EbiSetFullWindow(void);
58extern void ILI9488_EbiOn(void);
59extern void ILI9488_EbiOff(void);
60extern void ILI9488_EbiSetDisplayLandscape(uint8_t dwRGB,
61 uint8_t LandscaprMode);
62
63#endif /* #ifndef ILI9488_EBI */
Definition: xdmad.h:127
Definition: mknod-pack_dev.c:254
