RTEMS 6.1
ili9488_dma.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
37#ifndef _ILI9488_DMA_H_
38#define _ILI9488_DMA_H_
39
40/*----------------------------------------------------------------------------
41 * Headers
42 *----------------------------------------------------------------------------*/
43
44#include "board.h"
45#include <stdint.h>
46
47/*------------------------------------------------------------------------------
48 * Definitions
49 *----------------------------------------------------------------------------*/
51#define ILI9488_ERROR_DMA_ALLOCATE_CHANNEL 1
52#define ILI9488_ERROR_DMA_CONFIGURE 2
53#define ILI9488_ERROR_DMA_TRANSFER 3
54#define ILI9488_ERROR_DMA_SIZE 4
55
56#define ILI9488_SPI SPI0
57#define ILI9488_SPI_ID ID_SPI0
58
59/* EBI BASE ADDRESS for SMC LCD */
60#define ILI9488_BASE_ADDRESS 0x63000000
61
62/*------------------------------------------------------------------------------
63 * Types
64 *----------------------------------------------------------------------------*/
65
66typedef struct _ILI9488_dma {
74 sXdmadCfg xdmadRxCfg, xdmadTxCfg;
76 uint32_t xdmaInt;
80 uint8_t spiId;
82
83typedef struct _ILI9488_ctl {
85 volatile uint32_t cmdOrDataFlag;
87 volatile uint32_t rxDoneFlag;
89 volatile uint32_t txDoneFlag;
91
92#endif /* #ifndef ILI9488_DMA */
Spi hardware registers.
Definition: component_spi.h:41
Definition: ili9488_dma.h:83
Definition: ili9488_dma.h:85
Definition: ili9488_dma.h:89
Definition: ili9488_dma.h:87
Definition: ili9488_dma.h:66
sXdmad * xdmaD
Definition: ili9488_dma.h:68
Definition: ili9488_dma.h:74
uint32_t ili9488DmaRxChannel
Definition: ili9488_dma.h:72
uint32_t xdmaInt
Definition: ili9488_dma.h:76
uint32_t ili9488DmaTxChannel
Definition: ili9488_dma.h:70
Spi * pSpiHw
Definition: ili9488_dma.h:78
uint8_t spiId
Definition: ili9488_dma.h:80
Definition: xdmad.h:135
Definition: xdmad.h:127
