RTEMS 6.1
ids_extra.h
2
9/*
10 * Copyright (C) 2011 Daniel Hellstrom Gaisler <daniel@gaisler.com>
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34/* Only included from pci_ids.h */
35#ifndef __PCI_IDS_H__
36#error pci/ids_extra.h should only be included from pci/ids.h
37#endif
38
39/* Gaisler PCI IDs */
40#define PCIID_VENDOR_GAISLER 0x1AC8
41#define PCIID_VENDOR_GAISLER_OLD 0x16E3
42
43/* Gaisler PCI Devices */
44#define PCIID_DEVICE_GR_RASTA_IO 0x0010 /* GR-RASTA-IO */
45#define PCIID_DEVICE_GR_RASTA_IO_OLD 0x0210 /* old GR-RASTA-IO ID*/
46#define PCIID_DEVICE_GR_RASTA_TMTC 0x0011 /* GR-RASTA-TMTC */
47#define PCIID_DEVICE_GR_RASTA_ADCDAC 0x0014 /* GR-RASTA-ADCDAC */
48#define PCIID_DEVICE_GR_701 0x0701 /* GR-701 */
49#define PCIID_DEVICE_GR_TMTC_1553 0x0198 /* GR-TMTC-1553 */
50#define PCIID_DEVICE_GR_RASTA_SPW_RTR 0x0062 /* GR-RASTA-SPW-ROUTER */
51#define PCIID_DEVICE_GR_LEON4_N2X 0x0061 /* GR-CPCI-LEON4-N2X */
52#define PCIID_DEVICE_GR_NGMP_PROTO 0x0064 /* GR-NGMP_PROTO */
53#define PCIID_DEVICE_GR_CPCI_GR740 0x0740 /* GR-CPCI-GR740 */
