RTEMS 6.1
keyboard.h File Reference
Keyboard definitions. More...
#include <rtems/kd.h>
struct  kbd_struct
#define KG_SHIFT   0
#define KG_CTRL   2
#define KG_ALT   3
#define KG_ALTGR   1
#define KG_SHIFTL   4
#define KG_SHIFTR   5
#define KG_CTRLL   6
#define KG_CTRLR   7
#define KG_CAPSSHIFT   8
#define NR_SHIFT   9
#define NR_KEYS   128
#define MAX_NR_KEYMAPS   256
#define MAX_NR_OF_USER_KEYMAPS   256 /* should be at least 7 */
#define MAX_NR_FUNC   256 /* max nr of strings assigned to keys */
#define MAX_NR_CONSOLES   1
#define KT_LATIN   0 /* we depend on this being zero */
#define KT_LETTER   11 /* symbol that can be acted upon by CapsLock */
#define KT_FN   1
#define KT_SPEC   2
#define KT_PAD   3
#define KT_DEAD   4
#define KT_CONS   5
#define KT_CUR   6
#define KT_SHIFT   7
#define KT_META   8
#define KT_ASCII   9
#define KT_LOCK   10
#define KT_SLOCK   12
#define K(t, v)   (((t)<<8)|(v))
#define KTYP(x)   ((x) >> 8)
#define KVAL(x)   ((x) & 0xff)
#define K_F1   K(KT_FN,0)
#define K_F2   K(KT_FN,1)
#define K_F3   K(KT_FN,2)
#define K_F4   K(KT_FN,3)
#define K_F5   K(KT_FN,4)
#define K_F6   K(KT_FN,5)
#define K_F7   K(KT_FN,6)
#define K_F8   K(KT_FN,7)
#define K_F9   K(KT_FN,8)
#define K_F10   K(KT_FN,9)
#define K_F11   K(KT_FN,10)
#define K_F12   K(KT_FN,11)
#define K_F13   K(KT_FN,12)
#define K_F14   K(KT_FN,13)
#define K_F15   K(KT_FN,14)
#define K_F16   K(KT_FN,15)
#define K_F17   K(KT_FN,16)
#define K_F18   K(KT_FN,17)
#define K_F19   K(KT_FN,18)
#define K_F20   K(KT_FN,19)
#define K_FIND   K(KT_FN,20)
#define K_INSERT   K(KT_FN,21)
#define K_REMOVE   K(KT_FN,22)
#define K_SELECT   K(KT_FN,23)
#define K_PGUP   K(KT_FN,24) /* PGUP is a synonym for PRIOR */
#define K_PGDN   K(KT_FN,25) /* PGDN is a synonym for NEXT */
#define K_MACRO   K(KT_FN,26)
#define K_HELP   K(KT_FN,27)
#define K_DO   K(KT_FN,28)
#define K_PAUSE   K(KT_FN,29)
#define K_F21   K(KT_FN,30)
#define K_F22   K(KT_FN,31)
#define K_F23   K(KT_FN,32)
#define K_F24   K(KT_FN,33)
#define K_F25   K(KT_FN,34)
#define K_F26   K(KT_FN,35)
#define K_F27   K(KT_FN,36)
#define K_F28   K(KT_FN,37)
#define K_F29   K(KT_FN,38)
#define K_F30   K(KT_FN,39)
#define K_F31   K(KT_FN,40)
#define K_F32   K(KT_FN,41)
#define K_F33   K(KT_FN,42)
#define K_F34   K(KT_FN,43)
#define K_F35   K(KT_FN,44)
#define K_F36   K(KT_FN,45)
#define K_F37   K(KT_FN,46)
#define K_F38   K(KT_FN,47)
#define K_F39   K(KT_FN,48)
#define K_F40   K(KT_FN,49)
#define K_F41   K(KT_FN,50)
#define K_F42   K(KT_FN,51)
#define K_F43   K(KT_FN,52)
#define K_F44   K(KT_FN,53)
#define K_F45   K(KT_FN,54)
#define K_F46   K(KT_FN,55)
#define K_F47   K(KT_FN,56)
#define K_F48   K(KT_FN,57)
#define K_F49   K(KT_FN,58)
#define K_F50   K(KT_FN,59)
#define K_F51   K(KT_FN,60)
#define K_F52   K(KT_FN,61)
#define K_F53   K(KT_FN,62)
#define K_F54   K(KT_FN,63)
#define K_F55   K(KT_FN,64)
#define K_F56   K(KT_FN,65)
#define K_F57   K(KT_FN,66)
#define K_F58   K(KT_FN,67)
#define K_F59   K(KT_FN,68)
#define K_F60   K(KT_FN,69)
#define K_F61   K(KT_FN,70)
#define K_F62   K(KT_FN,71)
#define K_F63   K(KT_FN,72)
#define K_F64   K(KT_FN,73)
#define K_F65   K(KT_FN,74)
#define K_F66   K(KT_FN,75)
#define K_F67   K(KT_FN,76)
#define K_F68   K(KT_FN,77)
#define K_F69   K(KT_FN,78)
#define K_F70   K(KT_FN,79)
#define K_F71   K(KT_FN,80)
#define K_F72   K(KT_FN,81)
#define K_F73   K(KT_FN,82)
#define K_F74   K(KT_FN,83)
#define K_F75   K(KT_FN,84)
#define K_F76   K(KT_FN,85)
#define K_F77   K(KT_FN,86)
#define K_F78   K(KT_FN,87)
#define K_F79   K(KT_FN,88)
#define K_F80   K(KT_FN,89)
#define K_F81   K(KT_FN,90)
#define K_F82   K(KT_FN,91)
#define K_F83   K(KT_FN,92)
#define K_F84   K(KT_FN,93)
#define K_F85   K(KT_FN,94)
#define K_F86   K(KT_FN,95)
#define K_F87   K(KT_FN,96)
#define K_F88   K(KT_FN,97)
#define K_F89   K(KT_FN,98)
#define K_F90   K(KT_FN,99)
#define K_F91   K(KT_FN,100)
#define K_F92   K(KT_FN,101)
#define K_F93   K(KT_FN,102)
#define K_F94   K(KT_FN,103)
#define K_F95   K(KT_FN,104)
#define K_F96   K(KT_FN,105)
#define K_F97   K(KT_FN,106)
#define K_F98   K(KT_FN,107)
#define K_F99   K(KT_FN,108)
#define K_F100   K(KT_FN,109)
#define K_F101   K(KT_FN,110)
#define K_F102   K(KT_FN,111)
#define K_F103   K(KT_FN,112)
#define K_F104   K(KT_FN,113)
#define K_F105   K(KT_FN,114)
#define K_F106   K(KT_FN,115)
#define K_F107   K(KT_FN,116)
#define K_F108   K(KT_FN,117)
#define K_F109   K(KT_FN,118)
#define K_F110   K(KT_FN,119)
#define K_F111   K(KT_FN,120)
#define K_F112   K(KT_FN,121)
#define K_F113   K(KT_FN,122)
#define K_F114   K(KT_FN,123)
#define K_F115   K(KT_FN,124)
#define K_F116   K(KT_FN,125)
#define K_F117   K(KT_FN,126)
#define K_F118   K(KT_FN,127)
#define K_F119   K(KT_FN,128)
#define K_F120   K(KT_FN,129)
#define K_F121   K(KT_FN,130)
#define K_F122   K(KT_FN,131)
#define K_F123   K(KT_FN,132)
#define K_F124   K(KT_FN,133)
#define K_F125   K(KT_FN,134)
#define K_F126   K(KT_FN,135)
#define K_F127   K(KT_FN,136)
#define K_F128   K(KT_FN,137)
#define K_F129   K(KT_FN,138)
#define K_F130   K(KT_FN,139)
#define K_F131   K(KT_FN,140)
#define K_F132   K(KT_FN,141)
#define K_F133   K(KT_FN,142)
#define K_F134   K(KT_FN,143)
#define K_F135   K(KT_FN,144)
#define K_F136   K(KT_FN,145)
#define K_F137   K(KT_FN,146)
#define K_F138   K(KT_FN,147)
#define K_F139   K(KT_FN,148)
#define K_F140   K(KT_FN,149)
#define K_F141   K(KT_FN,150)
#define K_F142   K(KT_FN,151)
#define K_F143   K(KT_FN,152)
#define K_F144   K(KT_FN,153)
#define K_F145   K(KT_FN,154)
#define K_F146   K(KT_FN,155)
#define K_F147   K(KT_FN,156)
#define K_F148   K(KT_FN,157)
#define K_F149   K(KT_FN,158)
#define K_F150   K(KT_FN,159)
#define K_F151   K(KT_FN,160)
#define K_F152   K(KT_FN,161)
#define K_F153   K(KT_FN,162)
#define K_F154   K(KT_FN,163)
#define K_F155   K(KT_FN,164)
#define K_F156   K(KT_FN,165)
#define K_F157   K(KT_FN,166)
#define K_F158   K(KT_FN,167)
#define K_F159   K(KT_FN,168)
#define K_F160   K(KT_FN,169)
#define K_F161   K(KT_FN,170)
#define K_F162   K(KT_FN,171)
#define K_F163   K(KT_FN,172)
#define K_F164   K(KT_FN,173)
#define K_F165   K(KT_FN,174)
#define K_F166   K(KT_FN,175)
#define K_F167   K(KT_FN,176)
#define K_F168   K(KT_FN,177)
#define K_F169   K(KT_FN,178)
#define K_F170   K(KT_FN,179)
#define K_F171   K(KT_FN,180)
#define K_F172   K(KT_FN,181)
#define K_F173   K(KT_FN,182)
#define K_F174   K(KT_FN,183)
#define K_F175   K(KT_FN,184)
#define K_F176   K(KT_FN,185)
#define K_F177   K(KT_FN,186)
#define K_F178   K(KT_FN,187)
#define K_F179   K(KT_FN,188)
#define K_F180   K(KT_FN,189)
#define K_F181   K(KT_FN,190)
#define K_F182   K(KT_FN,191)
#define K_F183   K(KT_FN,192)
#define K_F184   K(KT_FN,193)
#define K_F185   K(KT_FN,194)
#define K_F186   K(KT_FN,195)
#define K_F187   K(KT_FN,196)
#define K_F188   K(KT_FN,197)
#define K_F189   K(KT_FN,198)
#define K_F190   K(KT_FN,199)
#define K_F191   K(KT_FN,200)
#define K_F192   K(KT_FN,201)
#define K_F193   K(KT_FN,202)
#define K_F194   K(KT_FN,203)
#define K_F195   K(KT_FN,204)
#define K_F196   K(KT_FN,205)
#define K_F197   K(KT_FN,206)
#define K_F198   K(KT_FN,207)
#define K_F199   K(KT_FN,208)
#define K_F200   K(KT_FN,209)
#define K_F201   K(KT_FN,210)
#define K_F202   K(KT_FN,211)
#define K_F203   K(KT_FN,212)
#define K_F204   K(KT_FN,213)
#define K_F205   K(KT_FN,214)
#define K_F206   K(KT_FN,215)
#define K_F207   K(KT_FN,216)
#define K_F208   K(KT_FN,217)
#define K_F209   K(KT_FN,218)
#define K_F210   K(KT_FN,219)
#define K_F211   K(KT_FN,220)
#define K_F212   K(KT_FN,221)
#define K_F213   K(KT_FN,222)
#define K_F214   K(KT_FN,223)
#define K_F215   K(KT_FN,224)
#define K_F216   K(KT_FN,225)
#define K_F217   K(KT_FN,226)
#define K_F218   K(KT_FN,227)
#define K_F219   K(KT_FN,228)
#define K_F220   K(KT_FN,229)
#define K_F221   K(KT_FN,230)
#define K_F222   K(KT_FN,231)
#define K_F223   K(KT_FN,232)
#define K_F224   K(KT_FN,233)
#define K_F225   K(KT_FN,234)
#define K_F226   K(KT_FN,235)
#define K_F227   K(KT_FN,236)
#define K_F228   K(KT_FN,237)
#define K_F229   K(KT_FN,238)
#define K_F230   K(KT_FN,239)
#define K_F231   K(KT_FN,240)
#define K_F232   K(KT_FN,241)
#define K_F233   K(KT_FN,242)
#define K_F234   K(KT_FN,243)
#define K_F235   K(KT_FN,244)
#define K_F236   K(KT_FN,245)
#define K_F237   K(KT_FN,246)
#define K_F238   K(KT_FN,247)
#define K_F239   K(KT_FN,248)
#define K_F240   K(KT_FN,249)
#define K_F241   K(KT_FN,250)
#define K_F242   K(KT_FN,251)
#define K_F243   K(KT_FN,252)
#define K_F244   K(KT_FN,253)
#define K_F245   K(KT_FN,254)
#define K_UNDO   K(KT_FN,255)
#define K_HOLE   K(KT_SPEC,0)
#define K_ENTER   K(KT_SPEC,1)
#define K_SH_REGS   K(KT_SPEC,2)
#define K_SH_MEM   K(KT_SPEC,3)
#define K_SH_STAT   K(KT_SPEC,4)
#define K_BREAK   K(KT_SPEC,5)
#define K_CONS   K(KT_SPEC,6)
#define K_CAPS   K(KT_SPEC,7)
#define K_NUM   K(KT_SPEC,8)
#define K_HOLD   K(KT_SPEC,9)
#define K_SCROLLFORW   K(KT_SPEC,10)
#define K_SCROLLBACK   K(KT_SPEC,11)
#define K_BOOT   K(KT_SPEC,12)
#define K_CAPSON   K(KT_SPEC,13)
#define K_COMPOSE   K(KT_SPEC,14)
#define K_SAK   K(KT_SPEC,15)
#define K_DECRCONSOLE   K(KT_SPEC,16)
#define K_INCRCONSOLE   K(KT_SPEC,17)
#define K_SPAWNCONSOLE   K(KT_SPEC,18)
#define K_BARENUMLOCK   K(KT_SPEC,19)
#define K_ALLOCATED   K(KT_SPEC,126) /* dynamically allocated keymap */
#define K_NOSUCHMAP   K(KT_SPEC,127) /* returned by KDGKBENT */
#define K_P0   K(KT_PAD,0)
#define K_P1   K(KT_PAD,1)
#define K_P2   K(KT_PAD,2)
#define K_P3   K(KT_PAD,3)
#define K_P4   K(KT_PAD,4)
#define K_P5   K(KT_PAD,5)
#define K_P6   K(KT_PAD,6)
#define K_P7   K(KT_PAD,7)
#define K_P8   K(KT_PAD,8)
#define K_P9   K(KT_PAD,9)
#define K_PPLUS   K(KT_PAD,10) /* key-pad plus */
#define K_PMINUS   K(KT_PAD,11) /* key-pad minus */
#define K_PSTAR   K(KT_PAD,12) /* key-pad asterisk (star) */
#define K_PSLASH   K(KT_PAD,13) /* key-pad slash */
#define K_PENTER   K(KT_PAD,14) /* key-pad enter */
#define K_PCOMMA   K(KT_PAD,15) /* key-pad comma: kludge... */
#define K_PDOT   K(KT_PAD,16) /* key-pad dot (period): kludge... */
#define K_PPLUSMINUS   K(KT_PAD,17) /* key-pad plus/minus */
#define K_PPARENL   K(KT_PAD,18) /* key-pad left parenthesis */
#define K_PPARENR   K(KT_PAD,19) /* key-pad right parenthesis */
#define NR_PAD   20
#define K_DGRAVE   K(KT_DEAD,0)
#define K_DACUTE   K(KT_DEAD,1)
#define K_DCIRCM   K(KT_DEAD,2)
#define K_DTILDE   K(KT_DEAD,3)
#define K_DDIERE   K(KT_DEAD,4)
#define K_DCEDIL   K(KT_DEAD,5)
#define NR_DEAD   6
#define K_DOWN   K(KT_CUR,0)
#define K_LEFT   K(KT_CUR,1)
#define K_RIGHT   K(KT_CUR,2)
#define K_UP   K(KT_CUR,3)
#define K_SHIFT   K(KT_SHIFT,KG_SHIFT)
#define K_CTRL   K(KT_SHIFT,KG_CTRL)
#define K_ALT   K(KT_SHIFT,KG_ALT)
#define K_ALTGR   K(KT_SHIFT,KG_ALTGR)
#define K_SHIFTL   K(KT_SHIFT,KG_SHIFTL)
#define K_SHIFTR   K(KT_SHIFT,KG_SHIFTR)
#define K_CTRLL   K(KT_SHIFT,KG_CTRLL)
#define K_CTRLR   K(KT_SHIFT,KG_CTRLR)
#define K_CAPSSHIFT   K(KT_SHIFT,KG_CAPSSHIFT)
#define K_ASC0   K(KT_ASCII,0)
#define K_ASC1   K(KT_ASCII,1)
#define K_ASC2   K(KT_ASCII,2)
#define K_ASC3   K(KT_ASCII,3)
#define K_ASC4   K(KT_ASCII,4)
#define K_ASC5   K(KT_ASCII,5)
#define K_ASC6   K(KT_ASCII,6)
#define K_ASC7   K(KT_ASCII,7)
#define K_ASC8   K(KT_ASCII,8)
#define K_ASC9   K(KT_ASCII,9)
#define K_HEX0   K(KT_ASCII,10)
#define K_HEX1   K(KT_ASCII,11)
#define K_HEX2   K(KT_ASCII,12)
#define K_HEX3   K(KT_ASCII,13)
#define K_HEX4   K(KT_ASCII,14)
#define K_HEX5   K(KT_ASCII,15)
#define K_HEX6   K(KT_ASCII,16)
#define K_HEX7   K(KT_ASCII,17)
#define K_HEX8   K(KT_ASCII,18)
#define K_HEX9   K(KT_ASCII,19)
#define K_HEXa   K(KT_ASCII,20)
#define K_HEXb   K(KT_ASCII,21)
#define K_HEXc   K(KT_ASCII,22)
#define K_HEXd   K(KT_ASCII,23)
#define K_HEXe   K(KT_ASCII,24)
#define K_HEXf   K(KT_ASCII,25)
#define NR_ASCII   26
#define K_SHIFTLOCK   K(KT_LOCK,KG_SHIFT)
#define K_CTRLLOCK   K(KT_LOCK,KG_CTRL)
#define K_ALTLOCK   K(KT_LOCK,KG_ALT)
#define K_ALTGRLOCK   K(KT_LOCK,KG_ALTGR)
#define K_SHIFTLLOCK   K(KT_LOCK,KG_SHIFTL)
#define K_SHIFTRLOCK   K(KT_LOCK,KG_SHIFTR)
#define K_CTRLLLOCK   K(KT_LOCK,KG_CTRLL)
#define K_CTRLRLOCK   K(KT_LOCK,KG_CTRLR)
#define K_SHIFT_SLOCK   K(KT_SLOCK,KG_SHIFT)
#define K_CTRL_SLOCK   K(KT_SLOCK,KG_CTRL)
#define K_ALT_SLOCK   K(KT_SLOCK,KG_ALT)
#define K_ALTGR_SLOCK   K(KT_SLOCK,KG_ALTGR)
#define K_SHIFTL_SLOCK   K(KT_SLOCK,KG_SHIFTL)
#define K_SHIFTR_SLOCK   K(KT_SLOCK,KG_SHIFTR)
#define K_CTRLL_SLOCK   K(KT_SLOCK,KG_CTRLL)
#define K_CTRLR_SLOCK   K(KT_SLOCK,KG_CTRLR)
#define NR_LOCK   8
#define MAX_DIACR   256
#define VC_SHIFTLOCK   KG_SHIFT /* shift lock mode */
#define VC_ALTGRLOCK   KG_ALTGR /* altgr lock mode */
#define VC_CTRLLOCK   KG_CTRL /* control lock mode */
#define VC_ALTLOCK   KG_ALT /* alt lock mode */
#define VC_SHIFTLLOCK   KG_SHIFTL /* shiftl lock mode */
#define VC_SHIFTRLOCK   KG_SHIFTR /* shiftr lock mode */
#define VC_CTRLLLOCK   KG_CTRLL /* ctrll lock mode */
#define VC_CTRLRLOCK   KG_CTRLR /* ctrlr lock mode */
#define LED_SHOW_FLAGS   0 /* traditional state */
#define LED_SHOW_IOCTL   1 /* only change leds upon ioctl */
#define LED_SHOW_MEM   2 /* `heartbeat': peek into memory */
#define VC_SCROLLOCK   0 /* scroll-lock mode */
#define VC_NUMLOCK   1 /* numeric lock mode */
#define VC_CAPSLOCK   2 /* capslock mode */
#define VC_XLATE   0 /* translate keycodes using keymap */
#define VC_MEDIUMRAW   1 /* medium raw (keycode) mode */
#define VC_RAW   2 /* raw (scancode) mode */
#define VC_UNICODE   3 /* Unicode mode */
#define VC_APPLIC   0 /* application key mode */
#define VC_CKMODE   1 /* cursor key mode */
#define VC_REPEAT   2 /* keyboard repeat */
#define VC_CRLF   3 /* 0 - enter sends CR, 1 - enter sends CRLF */
#define VC_META   4 /* 0 - meta, 1 - meta=prefix with ESC */
#define U(x)   ((x) ^ 0xf000)
void kbd_set_driver_handler (void(*handler)(void *, unsigned short, unsigned long))
void set_leds (void)
int kbd_init (void)
int getkeycode (unsigned int scancode)
int setkeycode (unsigned int scancode, unsigned int keycode)
void compute_shiftstate (void)
unsigned char getledstate (void)
void setledstate (struct kbd_struct *kbd, unsigned int led)
void handle_scancode (unsigned char scancode, int down)
void register_kbd_msg_queue (char *qname, int port)
void unregister_kbd_msg_queue (int port)
void add_to_queue (unsigned short)
int getch (void)
int BSP_wait_polled_input (void)
int rtems_kbpoll (void)
void _IBMPC_initVideo (void)
void keyboard_interrupt (void *unused)
int vt_ioctl (unsigned int cmd, unsigned long arg)
const int NR_TYPES
unsigned short * key_maps [MAX_NR_KEYMAPS]
unsigned short plain_map [NR_KEYS]
unsigned char keyboard_type
char * func_table [MAX_NR_FUNC]
struct kbdiacr accent_table [MAX_DIACR]
unsigned int accent_table_size
int shift_state
char func_buf []
char * funcbufptr
int funcbufsize
int funcbufleft
struct kbd_struct kbd_table []
unsigned int keymap_count
