RTEMS 6.1
cpuimpl.h
2
9/*
10 * Copyright (c) 2013 embedded brains GmbH & Co. KG
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34#ifndef _RTEMS_SCORE_CPUIMPL_H
35#define _RTEMS_SCORE_CPUIMPL_H
36
37#include <rtems/score/cpu.h>
38
49#define CPU_PER_CPU_CONTROL_SIZE 0
50
51#define CPU_INTERRUPT_FRAME_SIZE 52
52
53#define CPU_THREAD_LOCAL_STORAGE_VARIANT 20
54
55#ifndef ASM
56
57#ifdef __cplusplus
58extern "C" {
59#endif
60
61static inline void _CPU_Context_volatile_clobber( uintptr_t pattern )
62{
63 (void) pattern;
64
65 /* TODO */
66}
67
68static inline void _CPU_Context_validate( uintptr_t pattern )
69{
70 (void) pattern;
71
72 while (1) {
73 /* TODO */
74 }
75}
76
77static inline void _CPU_Instruction_illegal( void )
78{
79 __asm__ volatile ( ".word 0" );
80}
81
82static inline void _CPU_Instruction_no_operation( void )
83{
84 __asm__ volatile ( "nop" );
85}
86
87static inline void _CPU_Use_thread_local_storage(
89)
90{
91 uint32_t tmp;
92 uint32_t cpu_index;
93
94#ifdef RTEMS_SMP
95 cpu_index = _CPU_SMP_Get_current_processor();
96#else
97 cpu_index = 0;
98#endif
99
100 __asm__ volatile (
101 "movl " RTEMS_XSTRING( I386_CONTEXT_CONTROL_GS_0_OFFSET ) "(%2), %0\n"
102 "movl %0, _Global_descriptor_table+24(,%1,8)\n"
103 "movl " RTEMS_XSTRING( I386_CONTEXT_CONTROL_GS_1_OFFSET ) "(%2), %0\n"
104 "movl %0, _Global_descriptor_table+28(,%1,8)\n"
105 "leal 24(,%1,8), %0\n"
106 "movl %0, %%gs\n"
107 : "=&r" ( tmp )
108 : "r" ( cpu_index ), "r" ( context )
109 : "memory"
110 );
111}
112
113static inline void *_CPU_Get_TLS_thread_pointer(
115)
116{
117 return (void *) &context->gs;
118}
119
120#ifdef __cplusplus
121}
122#endif
123
124#endif /* ASM */
125
128#endif /* _RTEMS_SCORE_CPUIMPL_H */
#define RTEMS_XSTRING(...)
Stringifies the expansion of the arguments.
Definition: basedefs.h:987
rtems_termios_device_context * context
Definition: console-config.c:62
Thread register context.
Definition: cpu.h:173
